Question about Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet washer is leaking water from the detergent compartment
  • 15,935 Answers
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
The fabric softner compartment of my whirlpool duet washer is completely full of water
Mine is doing the same. For over 2 months now I've been adding fabric softner to the detergent compartment but I broke down and called a repairman to come tomorrow... at a ridiculous repair rate. My washer is less than 3 years old and this will be the 3rd major problem that needed to be fixed. I've seen a lot of people post the same problem - some say all 3 compartments won't drain.
Feb 24, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet washer is leaking water from the detergent compartment. Looks like the water can't get through the hole under the detergent compartment before it gets to where clothes are How can I open...
Jun 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front load leaking water from the detergent dispenser
Could be pressure too high reduce feed to machine only ....Slightly...Also try cleaning just in case its blocked
Sep 28, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Water coming out of the detergent compartment
When you take out the drawer you can reach inside and at the front of that compartment there should be an opening where the water goes into. I have seen many times where something is blocking that opening. The only other thing would be something stuck in the hose that attaches to that opening and feeds water to the tub. It sounds impossible but I have pulled underwear and socks out of that hose several times. Best way to access that hose it to take the outer clamp off of the door boot and reach in there, disconnect the hose and pull it out. Getting the clamp back on can be a little tricky if you haven't done it before so it may be best to call for a technician. Hope this helps.
Dec 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washer is leaking
Check the rubber bellow (gasket) around the door. This is the symptom of a door gasket that it starting to leak. Pull the rubber folds back and check the area where the gasket attaches to the wash tub. You may have a crack or tear. If the gasket is worn please replay back to this post and I can give you advice on how to replace it and where to get a replacement gasket.
May 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Leaking whirlpool duet washer front load
remove and clean any obstruction or deposits around the inner door seal use H.E. detergent over sudsing can cause that too.
Mar 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet frontload washer leak
a quart of water over the course of a cycle is pretty significant, other then trying to remove the fabric softener section looking for a blockage in the dispensor(which is basic and should be real evident ) theres not much more for you the consumer to look for.(or should you have to for that matter its why you bought a NEW appliance). As for the service , you've purchased a Whirlpool product, therefore you can call any whirlpool authorized Company out to service you dont need to wait for Sears!!!!!!!
Mar 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Which compartment is for the laundary soap
According to my information the dispenser drawer has four separate compartments for adding laundry products to the wash load. These compartments are:
1. Prewash Detergent Compartment
2. Main Wash Detergent Compartment
3. Bleach Compartment
4. Fabric Softener Compartment
Laundry products are diluted and dispensed automatically
at the proper time during the wash cycle. The separator in the Prewash and Main Wash Detergent Compartment can be moved to accommodate either liquid or powdered detergents.
Jan 05, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Water leaking
There is a small plastic "gate" that is left down for liquid detergent and moved back and up for powder detergent. If this piece is left down and powder detergent is used, the water leaks and the detergent won't go into the washer properly.
Oct 13, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
315 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
