Question about Encore 54MBPS 802.11G WIRELESS PCI ADAPTER (ENLWIG2)
Why does my adapter connect to the internet then disconnect for no reason?
    Guru:
  • 551 Answers
Please check out the setup of your wireless internet. And then the settings of your adapter. They should have the same settings. If not, follow the settings of the wireless setup.
Posted on Jul 15, 2010
2 Suggested Answers
vincent721
  • 240 Answers
SOURCE: netgear wireless adapter disconnects from router randomly
check for firmware update for your adapter...since it usb..u need to put it in open..i believed the USB extension is included when u purchased that.
do not connect the USB adapter to a USB hub unless the HUB is powered so that it can performed better. Connect it directly to your PC slot
Posted on Mar 13, 2009
Keeps disconnecting
What disconnects?
1) wireless adapter
1b) internet connection
2) wired connection
2b) internet connection
3) power adapter
4) monitor
5) other connects
Nov 07, 2013 | Computers & Internet
Wont turn on
Hello.
The most common reasons are your batter and power adapter.
Disconnect all cables, flip the laptop, unlock and remove the battery. Reinsert and lock, connect the power adapter and try again.
If still a problem, disconnect all cables, flip the laptop, unlock and remove the battery. Connect the power adapter again. If it works, your battery is faulty and needs replacement. if it doesn't work and there is no light on the adapter, your adapter is probably faulty.
Also, try this: wiggle the power adapter where it connects to the laptop. If the power goes on and off, the power jack is faulty and needs soldering or replacement. Leave that job to an experienced tech.
Hope this helps.
Dec 02, 2010 | Dell Latitude D600 Notebook
Netgear wireless adapter disconnects from router randomly
Mar 13, 2009 | NetGear WPN111 RangeMax Wireless USB 2.0...
Truemobile 1300 w/l usb adapter problem
hi..
if i understand your issue your computer connected to the internet using the wireless adapter but get disconnected after rebooting...right?
did u try updating the software for the wireless card..
here is the link trying updating the drivers for the wireless usb adapter..
here is the link for the download--
http://www.softwaredriverdownload.com/download.php?file=2nxZnRwOi8vZnRwLnVzLmRlbGwuY29tL25ldHdvcmsvUjE0MzM1NS5FWEU%3D..
good luck........
vedhick
Feb 03, 2009 | Dell TrueMobile 1300 802.11g/b Wireless...
Connects to Access Point but the internet cannot be found
The main reason why you have this error message because your computer is not getting a valid IP address from teh wireless network, and the reason why its not getting a valid IP address is the wireless security or sometimes called WEP/WPA kay are not type in to the correct place, If you have a WEP enable on your wireless network you will have two option on the Linksys WLAN monitor where you can type in teh security key, you will see two boxes there when you try to connect to the secured network one says Passohrase and one says WEP key1 and if yuo have a wireless key that has a total of 10 or 26 key character you need to type that on the WEP key1 box leave the passphrase blank...But if it still didn't work you can contact this number for help 1-877-787-8749....
Oct 15, 2008 | Linksys WUSB54GSC Compact Wireless-G USB...
Acer eNet Management
Do you have "What do you suggest I do to stop the alternating messages? It's almost as annoying as popups." I get an alternating popup (actually fade in fade out) message. the alternating message says "Acer eNet Management Internet Disconnected" Here is my solution!!! :)
First 'Right-click on task bar', TASK BAR IS AT THE BOTTOM OF YOUR SCREEN' then click on 'Properties'. Click on 'Notification Area', Click on 'Customize', Look for WLAN(disconnected), Click on it and choose 'HIDE', Click 'OK', then click 'APPLY', then click 'OK' and now you have no more annoying message. TOO EASY MATE ;)
Jul 25, 2008 | Microsoft Office Outlook 2003 for PC
Connection problem
if it's going offline, then it's losing the signal, or is recieving a low signal, it should be at 54mbps but when it gets below around 24mbps, it will disconnect and look for a stronger connection in your area, or disconnect from the net altogether.
Put your router in a higher and better line of sight to your adapter, walls and floors can block the signal and check that it's not your router that is losing the connection.
Oct 16, 2007 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Lose wireless internet when printer is on.
the only thing that connects the printer to the internet fault is the fact that the printer and your belkin are both usb connected. If you are using a laptop then it could be a usb power problem and the motherboard is disconnecting the belkin adapter for some reason, the only one i can think of is a power problem. The same can apply to a desktop pc if there is a usb problem Firsly i assume you are using the belkin software to connect the usb adapter to the router, so on your taskbar on the right there is normally the little aerial type icon for the belkin adapter and a little pc screen showing the connection also, if you right click on one of theses icons you should get a line reading 'enable windows WZC', if you do get the option enable it and try using the windows connection software instead of the belkin as it may stop the disconnecting. Also ensure that when you installed the software to your printer your firewall and antivirus was dissabled as certain elements to the driver may not have been installed. Lasly, try using different usb ports if you have spare ones, with both the printer and the adapter as sometimes the chip on the board may be instructing the usb ports incorrectly as to which is required first, as windows asks for certain things eg input/output ports to be used first,in other words the IRQ (interupt request) may be causing the problem.
Jun 23, 2007 | Belkin F8T003 Bluetooth (F8T003V) Wireless...
When you say home bases, i assume you mean desktop pc's. If the channel you mention is the channel that the router works off eg channel 11 then all wireless adapters have to be set to channel 11, or the same channel as the router. The reason for one disconnecting from the internet will probably be the adapter losing the signal because of obstacles like walls and doors, as if the signal gets too low then the reciever cannot connect properly with the router, hence dropping the connection. Try the router in a different higher position or at a phone socket nearer the troubled pc. The connection accross the network should be atleast good and at 54 MBPS, anything less may not connect properly. The laptops will tend to have a stronger connection as most have a signal up booster built in the screen.
Apr 11, 2007 | NetGear WG111 802.11g/b Wireless Adapter
Encore 54MBPS 802.11G WIRELESS PCI ADAPTER (ENLWIG2) Logo
188 people viewed this question
Top Encore Computers & Internet Experts
Prashant M
Prashant M
Are you an Encore Computer and Internet Expert? Answer questions, earn points and help others
