50 inch Zenith Plasma tv. Screen comes on and accepts video input but is very dark and has colored lines dispersed that go from top to middle and middle to bottom.
    Guru:
  • 551 Answers
There is a problem on the display. My suggestion is send it to a technician. They fix that problem. They will replace a component parts of your Flat Panel. You cannot do the DIY thing. You might have a bigger problem.
Posted on Jul 15, 2010
Which is the energy consmption
TV type ......................plasma TV
Screen size ..................50 in
Viewing Angle ....................160 degrees
Color .......................dark silver, silver
Video............. Interface Component, composite, HDMI, S-Video
PC Interface ..............VGA (HD-15)
Timer Functions................ Sleep, wake
HDMI Ports Qty ...................1 port(s)
Power Consumption Operational .................450 Watt
www.electro-medical.blogspot.com
Oct 04, 2015 | Zenith Z50PX2D 50 in. Plasma HDTV
LG plasma 50 inch tv with a fine vertical black line in the center of the screen that runs from the top of the screen to the bottom
Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 25, 2012 | LG 50PG20 50 in. Plasma HDTV
After warm-up screen flashes and loses color but comes back on and off intermittidly. This is a 50" Zenith Plasma tv. thanks.
Sounds as if a cable connection is bad. Check the cables first. If cable are good, change inputs, if cables are bad replace cables. If it's component, make sure that red, blue or green didn't come loose on both sides...the tv and the source. If you still have problems, check for red video noise on the screen itself, preferably when it's on but with on input (black) If you notice this, your plasma is failing.
Mar 23, 2011 | Zenith Z50P3 50 in. Plasma TV
Samsung Plasma 52 inch flatscreen vintage 2004 - black line
Hi my name is Roety,
I can help you with your issue ,
If the line is present on all inputs, and effects the TV menu you most likely need a new screen.
You can try changing buffers, reseating cables.
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Nov 09, 2009 | Samsung HPN5039 50 in. Plasma HDTV
Black line down screen
hello, your tv has either the lower or the upper buffer defective, worst case scenario is the screen but only a tech with the skills can determine wich one is bad.
good luck
caypianan@yahoo.com
May 20, 2009 | Zenith Z50PX2D 50 in. Plasma HDTV
Dark band 6 inches wide middle of the screen
YOU MAY HAVE A DEFECTIVE Y DRIVER BOARD OR A RIBBON CABLE THAT HAS COME DISCONNECTED. THIS NOT USUALLY THE PANEL SINCE THE PANEL DOES TURN ON. TAKE IT TO AN AUTHORIZED SERVICER.
Apr 10, 2009 | Televison & Video
Zenith P42W34P Plasma Display Panel
Hello, My name is Dave and I can help you fix your Plasma TV. Do you have Black vertical 1.5 inch line or lines on your screen that come and go? Then give me a call. Please feel free to give me a call @ 1-503-432-9904 or message me at pleasefixitdave@yahoo.com
Thank you!
Dave,
Nov 20, 2008 | Akai PDP-4247 Television
Sony plasma 50 inch has lines in the middle of screen
It sounds like a bad plasma panel but I would have to see a picture to be sure
Oct 19, 2008 | Televison & Video
Phillips 50 inch Plasma
Philips 50 inch plasma tv no video but has sound
Sep 28, 2008 | Philips 50PFP5332D 50 in. Plasma...
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
Electro Med Services...
