Question about JVC TH-A25 System
I have an XV-THA25 dvd center system. But now the "source" button on the system panel does not work properly. It just acts like the fast forward button beside. All buttons on the remote are working correctly. What could be wrong? Please advice. Thanks
2 Suggested Answers
SOURCE: JVC XV-THA25
Fixed it by replacing a burned resistor.
100ohm 1 wat designation PR010 on the main pcb.
Posted on Aug 11, 2008
Hi, I am seeking the region free code for a Samsung DVD-D530? Thanks!
I tried the above steps, but each time when restarting the DVD player, it said 'reset' and asked for the language to be selected again. Pressing the "Fast Forward Fast Rewind Fast Forward Up Down" sequence caused the player to lock up and require powering off at the wall.
I found on another web site that there are different initial sequences. Once I use the one for Region 2, it worked fine.
I found the instructions below on another web site, but it worked for me...
  • Make sure there is no disc in the player.
  • Turn on the player (you can use remote control or front panel, it doesn't matter)
  • Wait for "No Disc" message to appear on the TV screen.
  • Press the Repeat button on remote (plain, not A-B).
  • Press the correct sequence of buttons of remote according to the original region code of your player (it's on the sticker on the back panel of the player). FF = fast forward, FR = fast rewind.
    • Region 2 players: FF, FR, FF, UP, DOWN
    • Region 3 players: FF, PLAY, FR, UP, LEFT
    • Region 4 players: FR, PLAY, DOWN, DOWN, RIGHT
    • Region 5 players: FF, UP, DOWN, STOP, RIGHT
    • Region 6 players: LEFT, RIGHT, RIGHT, PLAY, LEFT
  • If you pressed the correct sequence, a small white number 0 will appear somewhere on the top right of the screen. The white number 0 of the same font and size as the "No Disc" message, so don't confuse with the red "not allowed" sign that would appear when you press a function that's not available.
  • Turn the player off and on again, then you can pop in a DVD of any region and watch immediately.
Apr 30, 2011 | Samsung Televison & Video
DVD player will not recognize DVDs
restoring the factory setting may solve your problem
for your model you should press Fast Forward and fast Rewind buttons at front panel simultaneously for at least fifteen seconds
i hope this will work
regards,
cseian
Jun 14, 2010 | Samsung DVD-V4600 DVD Player/VCR
No sound from front center and rear speakers on my xv-dv55
Hi
1st check your cables are inserted into the subwofer (which is the powersource)
however it sounds as though you have switched the player to mono mode to reset it try this
2. On your remote press the system button with the green ring around it 3. Then press the dts button (number 7) keep pressing it until the auto option appears (watch the little black display screen)
hope fully that should fix it
I am assuming that you no longer have the manual other wise you would have checked in there? But if you do and this does not work try read the first few pages on setting up the sound for your system.
Lou
Apr 05, 2010 | Pioneer DV-340 DVD Player
JVC TH 53 Dvd surround sound system. System locked
Dear friend,
Press and hold stop+play button on the front panel of the dvd player more than 15 sec the player will be resetting
Feb 17, 2009 | JVC XV-N320 DVD Player
Media center 2005 won't let me fast forward
If you asking about avi file there is no easy solution of this problem because Windows Medai Player as well as Windows Media Center can not fast forward and rewind avi file only DVD support fast forward - you need to use 3th part software (player) to be able to do fast forward,
I spent a lot of time trying to force WMCE and WMP to FF all files no lack so far
Jan 16, 2009 | Microsoft Windows XP Media Center Edition...
Remote problem
Hi There,
On the front panel:
REV Button (DVD)
Press to view the DVD picture in fast reverse motion
or to reverse playback of an Audio CD.
Press to skip Chapters or Tracks.
FWD Button (DVD)
Press to fast forward the Disc. Press PAUSE, then
press this button to begin slow motion playback.
Press this button repeatedly to change the forward
speed of slow motion.
I hope this helps,.
If not, feel free to conact me.
Thanks,
Mike
Nov 03, 2008 | Emerson EWD2203 DVD Player/VCR
Sound and video playback do not match
No button or any control to rectifier this problem. Depend the movies quality when you fast forward the system control and audio video processing or it call out MPEG2 chipset they run like double speed sometimes it not fast enough then you end up with sound and video not SYNC however you can fix that by remove AC lead for 30sec then plug in back now it should work OK or when you fast forward use X8 or X16 NOT X32 times specialy with DVD copy
Alternatifly if your DVD player still under warranty it might have a update firmware to correct this problem
Cheers
Nov 01, 2008 | Philips DVP5140 DVD Player
No audio from dvd player
you wil get the sound from the surround speakers only but not from tv first connect all the speakers that are given to the player correctly then you can get perfect sounds with dts...
May 04, 2008 | JVC TH-A25 System
JVC XV-THA25
Feb 09, 2008 | JVC TH-A25 System
JVC TH-A25 System Logo
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
