Question about Motorola Mobility Droid Multimedia Docking Station (89395N)
Droid does not charge when in docking station.
Motorola xt875 unlock code
Hi, You can get the unlock code for a Motorola XT875 ( DROID BIONIC 4G ) from www.simpleunlocking.com/motorola-droid-bionic-4g/rs16wp9/ at low cost.
UNLOCKING STEPS FOR MOTOROLA XT875 ( DROID BIONIC 4G )
1 - Switch ON your Motorola Droid Bionic 4G with a NOT ACCEPTED SIM Card,
2 - Phone will display "Enter Special Code",
3 - You can now enter the Unlock Code.
Oct 11, 2012 | Motorola Mobility Droid Multimedia Docking...
Wont charge my iphone
The adapter off the docking station can be faulty and so that must be checked for working voltage.
If there is voltage on the adapter then the socking station charging section can be faulty.
The failure of the regulator IC in the docking station cannot be ruled out. You will need to remove the docking station after making sure there is no voltage to the docking section to the phone.
Nov 19, 2010 | RCA RP5500I Docking Station
After receiving the 2.2 android update for my Droid the docking station will not work as before. The weather station and clock does not work properly.
A rule to updating firmware is " If It Ain't Broke Don't Fix IT!"
What you can do is roll back the update to the previous edition.
Aug 12, 2010 | Motorola Mobility Droid Multimedia Docking...
How can i unlock my motorola droid for free
Use this steps to unlock your mobile
1 - Switch ON your Motorola Droid with a NOT ACCEPTED SIM Card,
If you need unlock code means you can get the unlock code here theunlockarena.com
Jun 28, 2010 | Motorola Mobility Droid Multimedia Docking...
Is there anything you need to do to get the docking station to charge the phone? Or do I have a deffective docking station?
There is nothing special to do to the docking station. I have had some problems with mine not charging also. What I do if not charging is remove the phone and reconnect. Also look to make sure the power cord did not make its way loose some how.
Good Luck and please rate 4 thumbs for the free answer
Mar 30, 2010 | Motorola Mobility Droid Multimedia Docking...
I unplugged the docking station and now does not work
I actually had the same issue with mine.. it was 6 years old and just stopped finding the docking station. Also wouldnt take a charge. So I just eliminated the docking station. The stations power cord will charge the unit. Hope this helps.
Sep 12, 2009 | Roomba Robotic Floor Bagless Vacuum
Docking station
Hi!
I would suggest that you by-pass any docking stations and connect it directly via usb charger as most ipods do. And also, try to update Itunes and your Ipod Nano software.
Thanks and good luck! =)
Jan 04, 2009 | Apple iPod nano
Ipod nano not charging on docking system, it has low battery if none, can play with a little charge on ipod but has to be charged with plug first, the docking system is brand new aswell and is charging...
for some **** reason the new ipod nano (4th generation) does not support FireWire and therefore will not charge on any docking station that is a FireWire power sorce - which seems to be most of them out there!
have same problem so will end up charging from computer as docking station still plays the new nano, no point in buying new docking station just for sake of charging!
Aug 01, 2008 | Audio Players & Recorders
Charging Camera
I would test the docking station first. Do you have a way of charging the camera without using the docking station?
Thought I'd ask because some can and some can't.
Jun 21, 2008 | Casio Exilim Card EX-S600 Digital Camera
Motorola Mobility Droid Multimedia Docking Station (89395N) Logo
171 people viewed this question
Top Motorola Mobility Audio Players & Recorders Experts
Motorola Mobility
Motorola Mobility
xiangnia
xiangnia
Are you a Motorola Mobility Audio Player and Recorder Expert? Answer questions, earn points and help others
