Question about Dell Dimension 4550 PC Desktop
Will a memory chip #snpj0202c/512 fit in a Dell Dimension 8200?
  • Dell Master
  • 6,993 Answers
the answer is yes. It will fit in.
You can go ahead and fix the memory chip into your Dell Dimension 8200.
Good luck.
Posted on Jul 15, 2010
What memory (does) it use?
Jokodi Haynes,
The Dimension 8200 memory specs are listed below.
Memory
Architecture RDRAM
Memory connectors four
Memory capacities 64-, 128-, 256-, and 512-MB non-ECC RDRAM
Minimum memory 128 MB
Maximum memory 2 GB with Microsoft® Windows® 2000 and Windows XP; 512 MB with Windows Millennium Edition (Me)
Memory type PC800 (non-ECC)
Memory speed 40 ns or faster
BIOS address F8000h
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Mar 29, 2016 | Dell Dimension 8200 PC Desktop
What is the maximum ram capacity of dimension 8200 motherboard
2 gygabytoes are usually the max, you could upgrade the OS to maybe Windows XP 64 bit, but this isn't worth it in such an olde machine! Throw it out and get yourself an ASUS laptop with Windows 7 64-bit, a solid state HD and 4 or more gigabytes of ram instead!.
http://www.crucial.com/upgrade/Dell-memory/Dimension+%2F+Dimension+XPS/Dimension+8200+Series+%28400MHz+FSB%29-upgrades.html
Mar 16, 2013 | Dell Dimension 8200 AUD System Board...
What size memory card do i need for a dell 8200
the size of your memory card may be of any length but be sure that your system supports it
thanks
May 14, 2010 | Dell Dimension 8200 PC Desktop
I am getting ready to intall additional Rambus memory to my Dell Dimension 8200 and need walked through it... Any help?
Hello d_silverthor,
Here's a video link shoing how to install memory in a Dell Computer:
http://www.memorystock.com/memory/viewvideo.asp?systemtype=Dell+Desktop&Class=Desktop
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Feb 07, 2010 | Dell Dimension 8200 PC Desktop
I want to add more ram. Where do I get it? Dell
I hate to be the bearer of bad news, so don't 'Shoot the Messenger'!
The Dell Dimension 8200 Desktop PC uses RDRAM ram memory.
VERY expensive stuff!
Supporting Data:
This is Dell Support, Manuals, and the Dimension 8200 Service Manual,
http://support.dell.com/support/edocs/systems/dim8200/
Scroll down the list to the heading - Specifications, and left-click on it.
Scroll the page down until you come to the heading - Memory
Now look at the first subheading - Architecture
RDRAM
You have 4 ram memory slots. (memory connectors)
EACH, ram memory slot can support up to a Maximum amount, of 512MB. (512 MegaBytes)
TOTAL Maximum Amount for your computer is 2GB. (Not shouting)
1024MB = 1GB. (1024 MegaBytes = 1 GigaByte)
The type of Rdram ram memory is PC800, and it is Non-ECC.
(Error Correcting Control, or also stated as Error Correcting Code.
Used mostly for Server computers. Your computer does not use ECC ram memory)
In My Humble Opinion, (And again, don't shoot the messenger), it would be better money spent to buy a decent affordable computer, than it would be to upgrade the ram memory in this computer.
This statement is based upon the fact that the Dell Dimension 8200 ships with 128MB's of ram memory.
(Makes it a pretty slow computer. Rdram or not)
The average cost to install, for example, 1GB of ram memory is OUTLANDISH! (Not shouting)
Example 1:
http://www.4allmemory.com/index.cfm?fuseaction=search.memorySearch&model_id=24927
Example 2:
http://www.pcmemorystore.com/Dell-Dimension-8200-ram.htm
For about another $100 you can buy a pretty decent new desktop computer, that will run the one you have in circles.
Just my thoughts.
Dec 07, 2009 | Dell Dimension 8200 PC Desktop
Possibility of using Dimension 8250 memory in a Dimension 8200
Probably not, but to confirm go to this link. When you're there plug in the info for both machines and compare the memory configurations.
May 25, 2009 | Dell Dimension 8250 PC Desktop
"my computer will only beep no screen,it beeps
Hi
You likely have a bad memory module. First, try removing all the memory and putting it back in again. This is called reseating. If you still get the errors, then try removing one stick at a time and testing it with each stick (provided, of course, you have more than one stick installed). If you only have one stick installed, remove it and turn on the computer and it should beep at you as well. That memory stick will need to be replaced.
Thanks and please take a moment to rate this solution as fixya. Thank you.
Mar 14, 2009 | Dell Dimension 8200 PC Desktop
How to add memory to dell dimension 8200
http://www.tigerdirect.com/applications/category/memory_config.asp?ClsId=100
Enter the following information in the blank
and you should come up with which ram is compatible with your computer
then refer to this link on how to install the ram into your computer
http://static.tigerdirect.com/html/guide_installing_desktop_memory.html
Dec 30, 2008 | Dell Dimension 8200 PC Desktop
Dimension 8200 Upgrade Heat Sink Problem
you can contact online for techsupport at dell at www.support.dell.com this a live tech support session totally free they have helped me out numerous times keep me posted on how this goes ok best regards mike
Aug 12, 2008 | Dell Dimension 8200 PC Desktop
Motherboard blew up
I would recommend buying a replacement computer, and install the Dell IDE drive in an external 3.5" IDE hard drive enclosure. This way you can pull your information off the the Dell hard drive, and then blow it away.
Keep in mind that new computers use a SATA drive, your old Dell '8200 has an IDE drive. Also keep in mind that your Dimension 8200 drivers won't work on the new computer.
You might be able to install your Dell drive as a slave if you have an open IDE channel available.
Good news is, your old Dell uses RAMBUS memory, which is worth a lot. It's a good parts computer, and most people who look for computer parts know of the bad capacitor issue on Intel made Dell motherboards from that era.
May 15, 2008 | Dell Dimension 8200 PC Desktop
Dell Dimension 4550 PC Desktop Logo
23 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
