Question about Car Audio & Video
I have a jvc kameleon kd lx-10 it refuses to move the bottom part out that contain all my buttons it also keeps spitting out error codes such as err 22 err 26 err 24 if you know whats going on or if you have a list of the error codes or where to find them i would be greatly appreciative!!
informatica
  • 1114 Answers
SOURCE: Where to get manual for JVC kd-lhx501
Hi - You can download the manual from the link underlined in blue below:
kd-lhx501
Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Jul 13, 2008
SOURCE: Kyocera 3900DN Error Code
F030 General failure
Miscellaneous failure with the main
PWB, other than F000, F010, F020,
F040 and F226, above.
Defective main-PWB
Turn the power switch off/on to restart the
printer.If the error is not resolved, replace
main PWB
Posted on Sep 16, 2008
SOURCE: jvc kd lx111 deck wont eject cd
I just had this problem today and when I attempted to eject the CD it would give me an error message that stated (ERR 32). Apparently this means that there is something blocking the movement of the screen, a little manipulation should help the issue. Another variable could be the Eject lock feature, essentially a "child lock" for your disc. When this lock is activated it prevents the CD in the deck to be ejected. You can change this by holding down the blue source button and the eject button simultaneously for about 2 or 3 seconds. A message should appear saying "No Eject" and one that repeatedly flashes "Eject on" These two things seemed to help me alot when I had this issue. If those things don't work I would recommend calling JVC, much to my suprise they were actually really helpful. Their number is 1-800-252-5722.
Posted on Jan 24, 2009
SOURCE: Setting the clock on JVC KD-G230
Check out this pdf http://resources.jvc.com/Resources/00/00/91/GET0408-001A.pdf
Posted on Jun 10, 2009
  • 78 Answers
SOURCE: JVC KD-s25
Make sure its grounded properly and has all power, other than that, R.I.P.
Posted on Jul 08, 2009
I have a jvc kd-r45 it keeps on saying warning unit check wiring then reset
The check wiring message suggests a short probably in a speaker wire. Check that the terminal leads for the speakers are properly covered in insulating tape. Check the rest of your wiring, if you can, to check for any section where the insulation is worn and could come into contact with anything. Next remove the faceplate and use a pen to press and hold the reset button. The button is near the bottom of the middle of the receiver.
If the error persists, then another section of the wiring is making metal on metal contact with the car or another wire. You should contact a JVC dealer or the company that provided the kit with the KD-R45.
I hope this helps.
Jan 27, 2015 | JVC Car Audio & Video
My jvc kd-lx100 el kameleon control panel quit working how do i fix it
I think it needs service. If you cannot find a service location, write back.
Nov 13, 2014 | JVC KD-LX100 CD Player
My JVC KD-R426 keeps on saying warning check wiring and reset system. I've tried everthing but it still does the same. What must I do
Not sure if this will help any other owners since my answer is 4 years late, but this is what I found from another user. Apparently if you mess with the wiring too often, it goes in a safe mode which you need to do some button trickery to unlock the device from it's safe mode. These are the Steps.
1.Disconnect power supply
2.Press [MENU] and [UP arrow] buttons and keep holding.
3. While holding the buttons [MENU] / [UP arrow], connect the power plug again
A. The display will show "DC ERR"
*** if it still shows "Chk wiring ..." repeat the steps above until you get "DC ERR."
4. Press [UP arrow]; the display shows "DC1 ERR"
a. Press and hold [UP arrow] and it will show "DC1 OK"
5. Press [Down arrow], the screen will show "DC2"
a. Press and hold [DOWN arrow] and the display will show "DC2 0"
6. Disconnect the power from the back of the unit.
7. Remove the Face Unit.
8. Reconnect the power from the back.
9. Use a sharp object and press the [RESET] hole for 3 seconds and release.
10. Reinstall the face unit and turn on the power.
Oct 04, 2012 | JVC Car Audio & Video
I had cd reciever jvc kd-lh810 my probem is on the screen is EJECT ERROR what i can do?
there is a repair mod for this unit, replacement of motor. try hitting the top of the unit hard. while you push the eject button. this is sometime just enough to get the motor moving again
Dec 12, 2010 | JVC KD-LH810 CD Player
Is there a way to link a JVC Kameleon head unit with my stock CD changer? I have a mercedes slk350, just replaced the audio 20 head unit with the JVC Kameleon. Everything works and looks good, but I want...
The only thing i can suggest is to go to your audio shop and ask the same question to them, as they normally carry many different styles of leads and may have one there that will help you to connect your cd player, Is there a din output on the back of this unit? if so they should be able to help.
Feb 21, 2010 | JVC KD-G310 CD Player
No harness for jvc kd-lx1, require assistance to wire the radio c
Don't know the pin configuration off hand, but you can still buy the harness for the Kameleon from JVC. www.jvc.com the link is here
http://www.jvcservice.com/store/ProductDetail.asp?part=QAM0066-002 and it's $22.48 OUCH!!!
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 26, 2009 | JVC KD-LX1 CD Player
Jvc kd lx111 deck wont eject cd
Nov 07, 2008 | JVC KD-LX111 CD Player
Jvc kd-g200 cd player
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=260a73e6d269444e666771376ad18c85&q=JVC+KD-G200
Type in the code shown at the bottom.
Click "download now"
Click where it says "link" in blue.
Click "save"
Save the pdf to your computer's hard drive.
Instructions are as follows:
Press and hold the "select" button for more than 2 seconds.
Press the "fast forward" icon button.
Turn the dial to appropriate hour.
Turn the dial to appropriate minutes.
Press the select button.
Apr 17, 2008 | JVC KD-G200 CD Player
Car Audio & Video Logo
171 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
