Question about Canon PIXMA MP150 All-In-One InkJet Printer
My printer is not detecting black carteg when i put out color carteg then it detected.
  • 524 Answers
Hi...
this may the problem with catridge only because when you put the clour catridge it is detecting it.the contacting surface may be damaged in the black catridge. so please get the new catridge and repalce it. the problem will be solved
Posted on Jul 15, 2010
Error 163 on oki c5500 printer
163 Toner Sensor Error, Color: Black An error has been detected in your printer's Toner Sensor.
1 Machine Check Exception A problem has been detected in the printer hardware
2 DSI Exception The printers main logic has attempted to look up an invalid address.
3 ISI Exception The printers main logic has attempted to read the next instruction, which has failed to execute for some reason.
4 Alignment Exception The printers main logic cannot access the memory for some reason.
5 Program Exception The printers main logic has issued an exception code.
6 Floating-point Unavailable Exception A floating-point instruction is executed when the MSR floating point enable bit is set to Disable.
7 Instruction Address Breakpoint Exception The printers main logic has attempted to look up an invalid address.
20 CU ROM Hash Check Error 1 CU ROM hash check error has been found. Check reproducibility if possible.
21 CU ROM Hash Check Error 2 The printers CPU has a checksum error in it's memory.
23 CU ROM Hash Check Error (resident) Seek service if restarting the printer does not correct the problem.
25 CU ROM Hash Check Error (DIMM2) Seek service if restarting the printer does not correct the problem.
30 CU Slot1 DIMM RAM Check Error An error has been detected in operation checks on the RAM in slot 1
31 CU Slot2 DIMM RAM Check Error An error has been detected in operation checks on the RAM in slot 2
35 Slot1 RAM Spec Error Check the specification and install in slot 1 RAMs supported by the product
40 CU EEPROM Error The EEPROM mounted on the CU board needs to be replaced
41 CU Flash Error The CU Flash needs to be replaced
43 Flash File System Version Mismatch Seek Service if restarting the printer and initialising the flash memory does not correct the problem
42 Flash File System Error Seek Service if restarting the printer and initialising the flash memory does not correct the problem
43 PS Flash File System Error An Flash Memory error has occured and the printer needs to be serviced if restarting the printer does not correct the problem
51 CU Fan Error The CU cooling fan needs to be replaced if restarting the printer does not correct the problem
70 Postscript Failure An error has been detected in your printer's Postscript Core.
72 Engine Communication Error A communications error has occurred between CU and PU boards.
73 H/W Overrun Detect An error has been detected in your printer's hardware input area.
74 F/W Overrun Detect Occurs when the firmware is unable to set video data in response to video DMA's data request.
75 VIC Limiter An error has been detected in your printer's
80 Parameter I/O Error An error has been detected in your printer's Input/Output area.
81 Parameter Consistency Check Error The EEPROM and flash memory reformatted and initialized.
102 Engine RAM Error An error has been detected in your printer's engine RAM.
103 Engine SRAM Error An error has been detected in your printer's engine SRAM.
104 Engine EEPROM Error An error has been detected in your printer's engine reading/writing the EEPROM at power-up.
105 Engine EEPROM Missing Error An error has been detected in your printer's Engine
106 Engine Control Error An error has been detected in your printer's Engine Controller.
122 Power Supply Fan Motor Error An error has been detected in your printer's Power Supply Fan Motor.
123 Humidity Sensor An error. has been detected in your printer's Humidity Sensor
124 Temperature Sensor An error has been detected in your printer's Temperature Sensor.
127 Fuser Unit Fan Error An error has been detected in your printer's Fuser Unit Fan Error.
131 LED Head Missing, Color: Yellow When yellow LED head connection cannot be detected
132 LED Head Missing, Color: Magenta When magenta LED head connection cannot be detected
133 LED Head Missing, Color: Cyan When cyan LED head connection cannot be detected.
134 LED Head Missing, Color: Black When black LED head connection cannot be detected.
140 Drum Up/Down, Color: Yellow An error has been detected in your printer's Yellow Drum
141 Drum Up/Down, Color: Magenta An error has been detected in your printer's Magenta Drum.
142 Drum Up/Down, Color: Cyan An error has been detected in your printer's Cyan Drum.
150 Drum Fuse cut NG, Color: Yellow An error has been detected in your printer's Drum Fuse.
152 Drum Fuse cut NG, Color: Cyan An error has been detected in your printer's Drum Fuse.
153 Drum Fuse cut NG, Color: Black An error has been detected in your printer's Drum Fuse.
155 Fuser Unit Fuse cut NG An error has been detected in your printer's Fuser Unit.
154 Belt Unit Fuse cut NG An error has been detected in your printer's Belt Unit.
160 Toner Sensor Error, Color: Yellow An error has been detected in your printer's Toner Sensor.
161 Toner Sensor Error, Color: Magenta An error has been detected in your printer's Toner Sensor.
162 Toner Sensor Error, Color: Cyan An error has been detected in your printer's Toner Sensor.
170 Upper Thermistor, State: Short An error has been detected in your printer's Upper Thermistor.
171 Upper Thermistor, State: Open Restart the printer. If the problem continues the printer will need to be serviced
172 Upper Heat Temp, State: High An error has been detected in your printer's Upper Heat Temp.
173 Upper Heat Temp, State: Low Turn the printer off to let it cool down, then restart the printer.
181 I/F Error, Loc. Duplex An error has been detected in your printer's Duplexer.
182 I/F Error, Loc. Tray2 An error has been detected in your printer's Tray2.
187 I/F Error, Loc. Control Pnale An error has been detected in your printer's Control Panel.
190 System Memory Overflow An error has been detected in your printer's System Memory Overflow.
191 Page Memory Overflow An error has been detected in your printer's Page Memory Overflow.
200 PU F/W download Check Sum Error Error during PU flash download
201 PU F/W Flash Write Error An error has been detected in your printer's PU F/W Flash Write Error.
202 PU F/W Flash Data Missing An error has been detected in your printer's PU F/W download Check Sum Error.
203 Engine Page Sequences IMAGACK Error An error has been detected in your printer's Engine Page Sequences IMAGACK Error.
204 EnginePageSequences IMGSET Error An error has been detected in your printer's Engine Page Sequences IMGSET Error.
2005 Oki Data Americas, Inc.
Sep 14, 2012 | OKI C5500n Printer
Ink cartridge not properly installed
I have gone through all the forums but none of them worked...
The correct solution for the problem is the canon printer needs to have both the color and black catridges present in the printer...
So even if you purchased new black catridge only you need to have the old color catridge to be placed in the place of color catridge....
So it will detect the catridges and if any of the one is empty it asks to select black at the time of printing and simply select it you will get a black print...
So make sure both the catridges either empty or full need to be placed to detect the catridges....
I hope it will be helpful.....
Feb 18, 2011 | Canon PIXMA iP1300 Printer
My HP Deskjet F2480 is all set up but won't print. I don't have any ink in the colour cartridge. Could this be the problem?
If there's no ink in the color cartridge and the printer detects it and prompts you to replace the cartridge, you'll never be able to print unless you replace it. Sometimes only with the Color cartridge, we can make print outs, while the black cartridge is still installed (but the printer shouldn't detect it, if it does detect, there's no way to do this either) but only with black cartridge filled and no color is not possible.
It should work fine after it's replaced, if the problem persists, let me know.
Good luck.
Thanks for using FixYa.
Sep 07, 2010 | HP DeskJet F380 All-In-One Printer
Keeps on saying cannot detect ink
if your Brother's printer is anything like mine, it won't print in any color (or black/white) if any one ink cartridge is empty. I just put any color cartridge I had in the empty slot to force it to print black and white.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Sep 01, 2010 | Brother MFC 6490CW InkJet Printer
Black not printing
My refill my printer ink (i remove it) but still the screen appear to ask me "cannot detect black ink, reinstall slowly"
Apr 05, 2010 | Brother DCP 165C Compact Color Inkjet...
How to refill 818 black cartridge
818 blake cartege Error problam not opret my cartege f4200
Aug 27, 2009 | HP DeskJet F380 All-In-One Printer
Yellow ink cannot be recognize by the printer
The problem is that the priter can't detect the ink, because the cartridge has low level ink. I put scotch tape and colored it yellow- on the part where the ink is detected - so the printer will detect the color I put on the tape. BUT as others said it can damage your printer if you will always do this.
Jun 24, 2009 | Brother DCP 130C All-In-One InkJet Printer
My problem is i have a new cartridge then i was put the printer not detect new cartridge the cartridge is not recognized black and colored. what we do my printer please help me my problem because my n
Take out the catridge and check for the following:
1. At the base of the cartridge where a chip like item is, take off or strip off a glue like label if its on the chip surface of the cartridge.
2. Make sure you place the black and colour cartridge at the right positions.
3. Check the Cartridge bay in the printer (i.e where you place the cartridge in the printer) for the right color description to help you place the cartridge properly.
4. Lastly check the cartridge pack or printer manual to make sure the cartridges are compactible with the printer, else return them to the shop for replacement
May 22, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Align page not detected
when it prints the align page, take a look at the carriage. Do you see it stop and shine a blue light every so often? That is what detects the alignment. If you do not see a light, call HP support.
Jun 19, 2008 | HP OfficeJet 4215 All-In-One InkJet...
Doesn't detect color cartridge
If you still have the old cartridge try reinstalling it to see if it recognizes it. If it does then the cartridge is defective and return it.
If that does not work, try cleaning the connectors on the ink carriage (the area you install the cartridge) with DISTILLED water. Make sure it is distilled. Then try reinstalling the cartridge.
Hope this helps!
Nov 27, 2007 | Dell Inkjet 720 Printer
Canon PIXMA MP150 All-In-One InkJet Printer Logo
98 people viewed this question
old marine
old marine
