Some pixal channels pixal in and out or don't come
Some channels pixal in and out or don't come in at all. We are on cable. My other tv (different box) works fine on same channel.
  • Anonymous Mar 15, 2014
    only on the channels with 5 in them pixalation occurs
  • 11,361 Answers
It can be that the cable box is not as sensitive as the other box, try swapping the boxes. I had 1 of the three of my Comcast box replaced it three time (thay always replace it with used one which is a problem in itself, just lousy services), same problem as yours. Also check the cable connection to make sure they are clean and tight.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Posted on Jul 15, 2010
I don't have a remote control for my RCA TV and it's on channel 2. It needs to be on channel 3 so that It's compatible with my cable box. How do I change the channel without a remote to channel 3. It
U should have a menu button on your tv.If so try to find the channel setup option if you find this you should b able to manually go through your channels to add & delete the channels you want.If not you will have to go out a buy a universal remote.Make sure that it is compatibl to your tv.They should be a list on the back of the remotes pack stating all the brands that the remote is compatible with.I think you should be able to get one for unde 5 dollars.in the pack it should have an instruction manual.some tvs u can set up very easily & some you might have to keep putting in different codes until it works.Hole this could be some help to you.Good luck.
Apr 19, 2013 | Televison & Video
Hi, I bought this tv at thrift shop last week. No instruction manual available. I got cable from Time Warner. Got the cable signal and got tv working. 3 days later no cable. I don't know how to...
If using a cable box then you want to set the TV to channel 3 or 4 as the cable box will output to one of those. If no cable box then its possible the TV's tuner is bad or your cable company only transmits in digital form requiring a cable box since this TV only has an analog tuner
Jul 19, 2011 | GE 13GP341 13" TV
I have an RCA F31672ET and it works perfectly on channels 51 to 98 but will not recognize the rest of the spectrum. I am on cable. Thanks.
Depends on how your cable provider is distributing the TV channels.
Channel 100 is the line into the Jumboband, and most providers don't distribute analog cable beyond channel 99 since it requires a different type of amplifier. They will generally use Digital Cable for higher number channels, which would require a converter box.
http://en.wikipedia.org/wiki/North_American_cable_television_frequencies
Who is your cable provider?
Apr 24, 2011 | RCA F31672ET TV
I had all 5 terrestrial channels on channels 1 to 5 on my television and Virgin channels on channel 6. I was sitting watching the television when all 5 channels stopped working and I am left with the...
I don,t where you live & therefore I don't know which transmitter you will be picking but this sounds as if your local transmitter has now stopped transmitting the analogue signal. You maybe aware from a lot of advertising that this form of signal will be getting turned off in different areas around the country so unless you have cable or a digi-box or a digital TV then you will not receive any signal. As you have the Virgin box you will still receive channels 1 to 5 on digital but not on analogue.
Oct 15, 2009 | Televison & Video
I dont have continuous reception (picture is fragmented pixals)
Digital TV will do that when antenna does not receive sufficient signal.  You may need a different antenna or have to aim your current antenna differently. Go to www.dtvanswers.com for more info.
Jun 03, 2009 | Insignia 720p Widescreen LCD HDTV
New vizio 26'' hdtv seems sharp from a distance, but pixalated and
it is important to understand the difference in digital cable and high def. high definision is on a fiber optic display alwing milions of pixels per square inch on your tv. the resolution effects your fuzzy picture you are recieving . the only real way to fix that fuzzy dull picture is to get a HD box from your cable provider and an HDMI cable to conect it to your HD TV. this is the only connection you will need for picture and top line sound. In the end the fee is usually $9.95 or less a month and it is well worth the difference in quality of TV viewing.
Mar 16, 2009 | Vizio VA26L 26 in. LCD HDTV
Pixelation
This model has been known for problems with the Hyper module but the picture would be affected with any input source.HD or not.The cable converter box and the cable signal are the only culprits for pixilation.Pixalation is the result of missing digital information via signal.If it is only appears on the HD signal I would suspect the cable signal or the converter box.I assume you are using your component input on your TV or the HDMI input.As a technician I would suspect the cable box or cable for pixalation.
Jan 19, 2009 | Toshiba 46H84 46" Rear Projection...
Techwood LCD TV - picture fault
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. ..
Mar 29, 2017 | Televison & Video
Pixalization
Is the TV connected to both the DVD and the Cable box via component inputs? I gather the cable box is a HD box? If they both show up through component try connecting them to the composite video inputs (yellow connections) and see if the problem still shows up.
Feb 28, 2007 | Toshiba 30HFX84 30" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
