Question about Amana Haier AP095R Air Conditioner
I have an amana ap095r dont cool ? - Amana Haier AP095R Air Conditioner
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 04, 2010
  • 736 Answers
SOURCE: Amana AP095R Portable Air Conditioner is dripping
all air conditioners condense water .. the water is normally drained to the outside thru a hole near the outside bottom of the unit .. the unit has to be mounted so that it doesnt tilt inward .. the drain hole has to be cleaned once in a while ... if its clogged or if the unit is tilted inward then the water will drain inside the house .. less likely but possible is a cracked or damaged drip pan inside the unit ... thats a shallow pan under the condenser (cold) coil that captures the water and directs it toward the outside drain .. so check the tilt and clean the drain
Posted on Aug 17, 2009
  • 19 Answers
SOURCE: My Amana AP095R is leaking copious amounts of
not sure if it is a split or window unit if ti is a split unit it may be that the unit needs servicing and that the main drain pan has backed up depends on where it is leaking it can be the the secondary drain pan at the back of the unit that has two small ports that gets plugged up at times
Posted on May 03, 2010
  • 102366 Answers
SOURCE: I need to get an on-line manual/problem w/hoses thru window
www.managemylife.com/mmh/owner_manuals/17647/AMANA-Air-Conditioner-Room-(42)-L0523054
Posted on Apr 29, 2011
  • 102366 Answers
SOURCE: Is there a manual for the Amana AP095R portable ai...
You can view the manual at
  • 50 Answers
SOURCE: amana portable air conditioner
you need to empty the drain pan every couple of hours depending on the humidity level
Posted on Jul 21, 2011
Model Amana AP095R - does the water drainage have to be dumped everyday?
There is no right answer to that It gets dumped when its full. The more water the better, the more water the harder its working, the more water the more dehumidification. More water is a good thing, run a permanent drain if need be.
Jul 02, 2018 | Amana Heating & Cooling
Drain is plugged on model Ap095R Amana air cond it is leaking on floor and not commjng out the drain pipe
Did you remove the plug from drain line? If you did then run a small wire thru drain pipe to remove any clogs.
Jun 30, 2018 | Amana Heating & Cooling
Where does water that units makes while cooling go to?
never worked on one of these units my guess is evaporation
Aug 13, 2011 | Amana AP095R Portable Air Conditioner
Amana portable air conditioner ap095r does it need to drain water or evaporates on its own?
Jul 21, 2011 | Amana AP095R Portable Air Conditioner
The amana ap095r drain pan gets very dirty and mucky... but after unscrewing the back cover so I could vacuum both coils I dont see a way to clean the drain pan. The pan is part of the entire bottom (one...
Pour some Mr. Clean in the pan and somehow use anything that will fit to clean the pan. Add more water to thepan and allow it to drain.
As far as why they do that...They want to ensure you take it back for service so they can screw you again. I'll bet it only became an issue after the warranty was up.
ASH
Please vote.
Sep 22, 2010 | Amana AP095R Portable Air Conditioner
Jun 01, 2010 | Amana AP095R Portable Air Conditioner
Is there a manual for the Amana AP095R portable air conditioner? One did not come in the box.
May 20, 2010 | Amana AP095R Portable Air Conditioner
My Amana AP095R is leaking copious amounts of water. Please help.
May 03, 2010 | Amana Haier AP095R Air Conditioner
Heating & Cooling Logo
Top Amana Heating & Cooling Experts
Bill Long
Pete Norton
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
