Question about Microsoft Xbox 360 Console
Rolling picture i thought that but its not changing and i have since tried it on scart and thats ok
    Problem Solver:
  • 13 Answers
Ah, okay, now that you say scart I am guessing you are in europe. It could be that the update or use of HD cables changed your xbox setting to NTSC as opposed to PAL and using the scart cable probably automatically sets it to PAL as scart is not used in north america. check the settings tab to see if there is a manual selection for NTSC/PAL television types.
Posted on Apr 24, 2008
Try unplugging everything take out your hardrive then plug the stuff back in
Posted on Apr 23, 2008
When I switch on my dvd even the set up page is in black and white. Originally I was getting no picture so I made sure everything was plugged in. Then I got the black and white.
Check the scart cable , try connecting it to another scart socket on the tv. I would even change the scart lead to make sure its ok. I have had loads of similar problems like that caused by scart leads faulty or connected to the wrong socket.
pete.
Nov 27, 2010 | Philips DVDR3380/05 DVD Recorder
NTSC connection with satellite
interchange the wires probably they could be broken when the movement occured.good luck
Jun 16, 2007 | Samsung SV5000W VHS VCR
TH-37PE30 - DVD picture now lousy (herringbone?)
Do you have an S Video cable connection on the DVD player? I'd try that If you have one or component (red green blue) cable or even the composite (yellow) connection. The SCART connection on the input PCB of the tv could be damaged. The cost of this board may be pricey so if you can use the other type of connections with the DVD player I'd recommend that or get a DVD player that has one of those. Your model does not have HDMI so those are your only other options. Hope this helped
Feb 08, 2010 | Panasonic TH-37PE30 37 in. Plasma...
Sound but no picture
ok make sure all the cables are plugged in properly and into the correct slot, Check all the channels and make sure that it is not on AV If this doesn't work try new cables or scart leads, if you use a scart lead plug it into a differnt location E.G Some T.V's Have more than one scart lead socket
Feb 06, 2010 | Televison & Video
Faulty TV ( CRT type)Television blue hayse over the picture on digital
hi there
the blue haze is probably down to the scart lead ( it splits the r.g.b. signal) try getting a scart lead that is 'wired to all pins', you can tell by looking at the scart plug, if it is full of pins it is normaly o.k
if it is missing some pins i.e. there are spaces which look like there should have pins there, then try my suggestion.
hope it helps
beergut707
Oct 08, 2008 | Televison & Video
Dotted screen when turning on my console
hace you tried plugging it into a vcr, then the vcr to the tv...sometime the tv itself can be the problem....
Jun 30, 2008 | Microsoft Xbox 360 Console
Rolling white lines
sometimes this can be caused by two connected devices being on the same av channel,try connecting one at a time,also check your tv is set for your region etc,pal or ntsc.and you could look in your tv settings menu and check your output ie rgb scart,forgot the other options,,hope this helps
May 25, 2008 | Hitachi 53UDX10B 53" Rear Projection...
DVD playback no playback
Sounds like the scart lead is not in straight. Scart connectors have the audio pins at one end, and the video pins at the other. If the lead isn't in straight then you often get sound and no picture and vice versa.
Check the connection by pushing the scart lead in securely. (Both DVD and TV end of the lead)
Failing that could be a dodgy lead.
Mar 17, 2008 | Philips DVDR3380/05 DVD Recorder
Lgrz37lz55
I have the same problem amongst others, including rolling squares over the picture, but i cured the buzz by using scart connection 2 instead of connection 1; that is assuming you use a scart.
Mar 16, 2007 | LG RZ32LZ50 32 in. LCD Television
Rolling picture
Try the free view and see if the box is bad, then if it still does the sane thing, I bet theres a bad connection on the driver IC board, on a connecting ribbon cable, or a bad drive ic. These are things that a user should not attempt to repai, as there are no user replaceable parts inside this set and should be serviced by a train tech. Good Luck
Oct 10, 2006 | LG 37LP1D 37 in. LCD Television
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
