Question about Carrier 38CKC060 Air Conditioner
M/n 38brb060300 carrier
Is my unit a heat pump or a/c
    President:
  • 1,515 Answers
Hi, to tell if your unit is a heat-pump or not, if the indoor unit is not gas fired, it is a split system heat pump. If it uses gas or propane gas, its a split system gas/elect unit. Look at your thermostat also. It should have aux heat, emergency heat on it also. Maybe not both, but you will know if you have a heat pump. Please don't forget to rate me. Please be kind, as I know you will. Just remember, no gas, its a heat pump, gas fired furnace indoors, its not a heat pump.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor.
Posted on Jul 15, 2010
My(38ycc030340)carrier heat Pump ac unit blows 5 amp fuse on board in handler in attic when switch stat to heat.
Miss wired or shorted low voltage wiring. Have you changed stat? Animal chewed wires at foundation wall or in attic?
Oct 10, 2016 | Carrier Heating & Cooling
Carrier heat pump
Expansion valve is sticking shut
Jun 13, 2013 | Carrier 5 Ton Complete Split System Heat...
Carrier OEM to Honeywell Programmable Tstat - NEED HELP
you likely have a "two stage" system, but not a two stage heat pump. the first stage is probably the heat pump itself, and the second stage is the auxilliary resistance heat that suppliments the heat pump at lower temps. if i knew the terminals that are available on the new stat, i could advise you on the proper wiring.
Jan 27, 2013 | Carrier Heating & Cooling
Carrier 38CKC042300. oUTSIDE UNIT FAN WAS TURNING REAL SLOW. ac UNIT IS OFF BUT FAN TO OUTSIDE UNIT IS STILL TURNING. sHOULD NOT BE TURNING AT ALL WITH AC UNIT OFF
The outside fan may run if the unit is in defrost mode this is normal for most heat pumps it is there way of trying to keep the outside unit from staying iced over so the next time the unit runs it will have air flow through the coil and the ice will not be there to prevent air flow.
Jan 12, 2010 | Carrier 38CKC042 Air Conditioner
I have a Carrier model 38ycc048320. Does anyone
On Carrier.com. All units are listed there. You can call your local Carrier office and they can get that for you as well
Sep 28, 2009 | Carrier Heating & Cooling
Hi i need to know the ton of the unit
TYou can find that information on the steel plate on the back of the unit, if it's a heat pump you will find it on the sied where tubing comes out of heat pump. It will have serial Number and model number and you can take that information and go to Carrier and find thw tonage list.
Aug 31, 2009 | Carrier Heating & Cooling
3 amp fuse blows on a carrier 58mcb furnace board
Hi!!! Does your ac unit work fine?If not check your low voltage problem..You have a low voltage problem check the wire going out to your condensor make sure that they are not touching..Good luck..Check low voltage wires..short in progress..
Jan 04, 2009 | Carrier 52CQ-312-4 Comfort Series Heat...
Problem with carrier heat pump
Check the relays on the main board of your blower/furnace. If one is stuck, then the unit will not change from ac to heat. You may need to replace the entire board.
Dec 11, 2008 | Carrier 38CKC042 Air Conditioner
Hi- Can not tell if my unites are straight cool / heat or a heat pump.
if you look inside the condenser unit outside,see if you see the big reversing valve,if not it is a straight cool,heat, the heat strip ins in the air handler so you would have to take the side panel off and look for the heat stripe,my the way heat pumps also have a aux.heat stripe just in case it does not get cold enough outside,hope this helps you-mike
Oct 25, 2008 | Carrier 38CKC042 Air Conditioner
Carrier 38CKC060 Air Conditioner Logo
271 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Dennis Boxerman
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
