Question about RIM BlackBerry 8800
Need help i have the blackberry 8800 and i'm trying to charge it with my usb wire but my phone is saying "usb charing is not sufficient. verify that your handheld is connected to a powered usb charging source and that the proper usb driver is installed" what do i do from hear
  • 97 Answers
You will have to install blackberry desktop manager in order to route enough sufficient power to your blackberry device. you can download that software from the CD rom that came with your phone or by going to the following link:
http://na.blackberry.com/eng/services/desktop/
as soon as you download that software go to options, connection settings and change the connection type from NONE to USB PIN: ^^^^^^^ and it will charge just fine! :)
Posted on Apr 30, 2008
I changed my data plan 2 days ago to unlimited plan, now my internet wont work. it worked fine before. also my phone a is a AT&t unlocked and now used on t-mobile. t-mobile has tried everything. please...
You must using blackberry 8800 unlock code for att network before you can used t-mobile sim card in your phone, that unlock code can be obtained from your network provider in this case att, or you can buy blackberry network unlock code from third party sites.
Apr 06, 2011 | RIM BlackBerry 8800
Blackberry storm charging problem is plugged into the computer to
I've had this problem just since the last software upgrade. New charger, cable & battery haven't solved it.
Dec 14, 2009 | RIM BlackBerry Storm 9530 Smartphone
Not charging
Go to your cell phone store and have them try another charger.
If that doesn't work your phone is damaged and needs to be repaired.
I hope this helps.
Jul 17, 2009 | RIM BlackBerry 8800
Blackberry 8800 will not charge on wall charger
You need to find out if the problem is with your current AV charger - the battery or the phone.
Clean the battery and the metal connection with a dry cloth, and try to charge using a USB charger.
May 21, 2009 | RIM BlackBerry 8800
My NEW Blackberry 8310 won't charge! Red light flashes just once.
get a message saying my USB is not sufficient enough to charge phone ???? It works on other computers just not the one I need it to work on.
May 09, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
Free unlock codes for blackberry 8800
No one can give you unlock code for free. and dont try to enter unlock code. because it will block your blackberry. if you want to unlock your blackberry only use trusted sites. order your Blackberry unlock code here http://blackberrymep.com/unlock-blackber... this site charge very reasonable price.
Dec 08, 2008 | RIM BlackBerry 8800
I have BlackBery 8800
If your phone is a GSM phone meaning the phone has a SIM card usually T-mobile or At&t, tell your son to call customer service and tell them that he needs the unlock code for his phone, if he has been with the company for more than 90 days they will give it to you with out any hassle, they might ask why you need it, tell them he is traveling over seas, they will email you the unlock code wihin 48 hours, free of charge, when you get your new service provider they will issue you a new SIM card which you will put in the phone once it powers up it will ask you for the unlock code.
There is another way if you dont mind paying a few bucks, check out this link. let me know if this helps
Nov 21, 2008 | RIM BlackBerry 8800
USB connection failure to Blackberry 8800
I have the same problem.  The following solution may apply; here is how to IDENTIFY the problem: (1) Phone doesn't connect to desktop software through USB but will through BT (if setup) (2) Phone doesn't charge whether USB-computer, USB-wall, USB-carcharger or does sometimes but you are not sure why it works sometimes but not all the time (3) If you hold, lean, twist, or jiggle the plug at the phone, it may charge or the charge icon may show briefly (Also) Plug is noticeably loose or comes out Solution: if plug is torn loose, damaged, or comes all the way out, go to this site and follow along in kind http://computerguru365.blogspot.com/2006/02/diy-blackberry-usb-repair.html If plug is simply intermittant: remove all power and the battery, open your phone, and carefully redo the solder joints of the plug.  If you don't have a SMT (surface mount) rated soldering iron w/ tip, you can use the radio shack standard but be sure to only apply the hot tip in pulses (less than/up to 50% of time, less than 3sec each touch) so you don't heat damage the surrounding components. Why: Because the plug gets tugged to the sides causing the solder joints to crack (microscopically).  At first I had to lean books against the plug but then that quit working as well.
This approach also worked on my laptop which quit charging when plug torque flexed the motherboard and cracked the solder at some surface components near the plug.  I found out which components when the varying the force of my multimeter tip cause the component to show open and normal across the solder joint
Nov 20, 2008 | RIM BlackBerry 8800
My usb
I had the same problem - you need to install the latest Blackberry USB driver software on the PC/laptop you are trying to charge it with. They should be on the CD you got with the Blackberry (you don't need to install all the software if you don't want to - just the USB drivers). This enables the USB ports to allow enough power to charge the device when it's connected.
If you don't have the CD, do a quick Google for "Blackberry USB driver" and download the most up-to-date ones you can find.
Nov 04, 2008 | RIM BlackBerry Pearl 8100
RIM BlackBerry 8800 Logo
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
David
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
