Question about Garmin Edge 305 GPS Receiver
My garmin 305 edge cuts off while the battery shows full strenght. What could the problem be. i was told this is a problem that alot of cyclists encounter. Greg
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 81 Answers
It is a contact problem inside the device, Details of how to fix at following link
http://blog.mtbguru.com/2008/11/06/surgery-on-the-garmin-edge-305/
Posted on Sep 25, 2010
Changing battery
Not simple. Device needs be open.
Refer to instructions to open at site (edge 305 but similar)
Aug 22, 2010 | Garmin Edge 705 Handheld GPS Receiver
My Garmin 305 edge does not work correctly
Normally with Garmin sat-navs you have to switch the on/off button off and hold for around 8 seconds to reset the device
Feb 01, 2010 | Garmin Edge 305 GPS Receiver
I will be riding a 340km 24 hr mtb stage race consisting of 6 stages in dec. How do I manage charging of my Garmin Edge 305 over what will be some 18hrs of riding with short breaks between stages?
Bring a portable PC device plus your USB cable, and a charged battery on your PC, Edge will charge when connected to PC via USB.
Any other powered USB source would also help charging.
However for a 24 hours trip, it is worth downloading your races on the PC and clearing memory, as otherwise memory will get full and waypoints will stop register.
Nov 09, 2009 | Garmin Edge 305 GPS Receiver
Edge 205 turning off through runs
There is a generic battery contact problem in the body of the gps, same in 305...this link will show you how to remedy it..MTBGurublog i have done it with my 305 and now do not have the shutdown anymore.... But, before you perform surgery try a full reboot... turn unit off then press mode and power together... unit will ask if you want to delete data..select yes and then manually insert all data again
Aug 06, 2009 | Garmin Edge 305 GPS Receiver
Garmin Edge 305 will power off in a min or 2 riding in afternoon
This is a generic problem with the 205 and the 305 go to MTBGurublog and look up 305 problems there is a blog that shows how to open and fix it
Jul 07, 2009 | Garmin Edge 305 GPS Receiver
I am charging the Garmin Edge 305 for 24 hrs or for at least over night, yet the Edge 305 will show 2 to 3 bars of charges and will last maximum 1 hour of riding time. What to do?
Discharge completely device then charge again for 8 hours.
If not working, then attempt Soft reset :
Hold mode and lap/reset for 10 seconds then release.
Start the device then by long press on start. DEvice should start and charge then
Mar 16, 2009 | Garmin Edge 305 GPS Receiver
Garmin 305 Edge and GSC 10 not receiving one another
Solution copied from Garmin
Pairing the Edge 305 and sensors
Once you have installed the Garmin Edge 305 and the cadence sensor they need to be paired. As they communicate wirelessly with each other the Edge needs to connect to each sensor before it can receive input from it.
The initial pairing needs to be done away from other wireless systems this allows the Edge to pick up the sensors it is supposed to be monitoring. This is a little like black magic, but it seems to work quite easily.
The cadence sensor has a small press contact which puts the sensor into pairing mode. The HRM just seemed to connect by itself.
Subsequent pairing is much faster as the Edge 305 seems to remember which sensors it is paired with. If you have problems or need to change one of the sensors then you can use a setup feature to either turn the sensor off or to re-pair it.
Feb 22, 2009 | Garmin Edge 305HR GPS Receiver
False elevation reading with garmin edge 305
perform a software download from Garmin.com by logging onto the site and downloading the webupdater
Aug 23, 2008 | Garmin Edge 305 GPS Receiver
Edge 305 turns off at every little bump in the road?
The above link no longer works.
But this one does (for now): http://blog.mtbguru.com/2008/11/06/surgery-on-the-garmin-edge-305/
I made this surgery and it now works great.
Aug 18, 2008 | Garmin Edge 305 GPS Receiver
Garmin Edge 305 - Uncommanded Power Down
I moved the battery wires to the main board, bypassing the spring contacts. No doubt my warranty is voided but at least the thing works now.
Feb 17, 2008 | Garmin Edge 305 GPS Receiver
Garmin Edge 305 GPS Receiver Logo
137 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
