Question about kawasaki Full Suspension Mountain Bike Men
I have an 08 650 brute force. put it in 4wd n went into the mud. i noticed the rear was pulling n sinking but the front was not pulling. i turned the wheels to where there was little resistance from the mud n they started to turn. My belt light is on also, could that be my problem?
  • patrick sapp Jul 15, 2010
    im still not clear on the problem. do i need to change the belt n reset the light or just reset the light? the rear pulls like hell but front only pulls with little or no resistance.
  • 532 Answers
The belt light that is on is causing the problem.
Thanks
Posted on Jul 15, 2010
    ok' do this mean i need to change the belt n reset the light or just reset the light?
  • Rahman Rufai Jul 15, 2010
    You need
    Thanks
  • 6,826 Answers
Http://www.kawasaki.com/Products/product-specifications.aspx?id=320
The above is a video of the '09 Brute Force.
Back to your problem.
If there is a loose bet light is on, this could be your problem.
But, I read it is shaft driven (2x4/4x4 shaft) and
Transmission Dual-range CVT plus reverse with Kawasaki Engine Brake Control
Also you listed your '08 650 brute force under a bicycle listing.
How do you get the tire off a 2005 Dakota once the lug nuts have all been taken off.
Hi Richard:
These can be a PITA!
The diameter of the centre of the wheel can be a nasty tight fit.
Here's a couple of techniques:
- Old brute force trick......... use spare tire as "pendulum" hammer and smack the stuck tire... front.back.front.back
- If front tire, turn all the way to side being removed.... but block of wood between rim and frame.... turn back against rim.
- Put lug nuts back on leave slack. Lower vehicle back to ground and drive slowly forward and back. If front tire, turn back and forth.
Sometimes this will loosen them
- If rear tire, slide 4X4 across from under vehicle. block so it is against rim, then smack 4X4 with LARGE sledge hammer.
- Some people apply heat to the centre of the wheel where it is jammed. I don't like doing that.
BRUTE FORCE is much more satisfying.
Cheers.
Nov 08, 2015 | Cars & Trucks
I was mud riding on my 2010 brute force. Well when I was in a hole it died when I came out it started knocking on the front of the motor by the cylinder real bad.
may have got some water/mud sucked into the engine via exhaust if you did'nt keep the revs well up , take out the plug and check , and drain the oil to see if the crankcase isn't contaminated also
Jul 24, 2014 | Cars & Trucks
97 sierra put truck in 2wd have clicking drivers front put back in 4wd went away
First guess would be to check the drivers side, CV-joint assembly. After that is "OKed" then I would move to the front output shaft and then onto the rear drive-shaft. Checking for bad U-joints. Let me know if that helped.
Feb 16, 2014 | 1997 GMC Sierra
Vibrating at 50 mph
It's likely a tire balance issue. One of the wheel weights may have fallen off. You could try swapping the tires front and rear to see if the issue goes away, or take the tires back to where you last bought them and see if they'll rebalance for free.
Also, if you ever drive thru mud, the mud could have dried to the inside of the wheel causing an imbalance.
GL,
Td
Nov 06, 2013 | 1998 Dodge Ram 1500 4WD
I have a 94 mitsubishi montero ls. it started making a noise as if it were throwing a front wheel bearing. I pulled over and check the front hubs for heat. None was found. So with hopes it would change...
Possible, but any noise should be investigated fully. Start by checking front diff oil, then transfer case oil. Best to just drain both then look for any metal in oil.
Jul 10, 2011 | 1993 Mitsubishi Montero
My 2002 2500HD Silverado diesel wont engage the front wheels in 4wd. I jacked the front wheels off the ground and put it in 4wd. The wheels turn and so does the front drive shaft. I found this out when I...
if you had the rear wheels still on the ground in 4WD and it never drove the vehicle off the jacks or stands , you have a problem in the transfer case
in other words the transfer case is not selecting WD
Aug 15, 2017 | 2002 Chevrolet Silverado 2500HD
When i put into 4 wheel drive high,it chugs and fights with me when i turn replaced u joints and tierods under truck
they all do that when you are on a dry cement surface. The truck is designed for sloppy mud or snow, and 4H. 4Low is for straight slow pulling, or climbing. Use 4 H and don't turn too much on dry surfaces. You won't notice it in the snow. Its like a locked axle.
Oct 15, 2009 | 1998 Dodge Ram 1500 4WD
When i have my 4 wheel drive engaged making turns
If you are in 4WD, and not on a slippery surface, the tires may be having an effect called "scrubbing" where the tire on the outside of the turn is not rotating at the same rpms as the tire on the inside of the curve. I have noticed this on my jeep wrangler in 4wd.
Using 4wd on dry or non-slippery surfaces can cause this problem, and also will cause excessive tire wear.
Try the same manuever on a gravel road or a ice patch (it's been in 90s here in Texas, so good luck on that one) and see if it is improved.
Also, would probably expect a little more effort to steer when in 4wd because the universal joints or CV joints are not in perfect alignment during a turn.
Sep 11, 2009 | 2001 Dodge Ram 2500 Truck
kawasaki Full Suspension Mountain Bike Men Logo
434 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Wayne McNeil
Marvin
Marvin
obsteiner
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
