Question about Akai PT4298HD Rear Projection Television
Same problem with my akai 42inch 98 HD rear projection
Suddenly stopped working timer light blinks but nothing, would it be difficult to fix for someone who has never done it.
  • 9 more comments
  • Wally12 Apr 27, 2008
    I have the same problem with the same rear projection tv - I'm told it might be the bulb, and these are no longer available. Its a PT4298HD.
  • Anonymous May 04, 2008
    same problem whit my tv
  • juanbobo May 06, 2008
    TV AKAI 2003 TURNED OFF, NOW I CAN NOT BRING IT BACK ON
    MODEL PF 3220
    ACCORDING TO TECHNICIAN THE BROKEN PART NAME IS FLIGH BACK OF HIGH VOLTAGE
  • Wayne Ludewig May 10, 2008
    I have the same problem as well, the picture was first turning green and then it just turned off and now will not turn on.
  • cszigiler May 13, 2008
    I have 27inch Akai HD television and it will turn on. Its not even a year old
  • mauipacific May 18, 2008
    have the same problem. when I plug it in I get nothing and when i use the remote to power on the timer light goes on. Thats it. I checked the fuse on the panel and it was OK. Need help or this tv will see the dumpster. Not even a year old- pretty disappointing!
  • mets fan May 20, 2008
    we went to turn ont the tv, and nothing happens, just the red timer lights up.
  • mushroom22 May 27, 2008
    TV won't turn on. Can hear the power go on but no picture. The timer light blinks but thats it.
  • rjpr May 31, 2008
    no picture or sound just the red timer light flashes on and off 10 times
  • Anonymous Jun 13, 2008
    same problem timer light keeps blinking. tv comes on and automatically shuts off ever 2 minutes. I've tried turning the timer off from the main menu, but that doesn't help. If any one knows how to save my tv please help!!!!!!!!!!!!!!!!!!!
  • 1Scoop Jun 24, 2008
    I have a PT4298HD. The timer light will blink 10 times but never come on. I need help any advice out there
    Sergeant:
    Champion:
  • 319 Answers
Never even remove the back panel, if you are not trained. It could be fatal for both you and the TV
Posted on Apr 22, 2008
Akai rear projection tv suddenly stopped working.
This set with Akai is actually made by Samsung (they own and use the Akai name).
If lamp light etc and you have heard a cracking sound it may be the color wheel.
You can remove the lamp and look where it faces--look and the wheel can be seen----is it shattered or missing plastic pieces?
The wheel commonly fails in this fashion and is turning at over 12,000 rpm. The set will detect if the wheel is stopped or moving too slow and just what you describe will happen.
Wheel is widely available and You Tube has video instructions for replacing them by model number.
Questions?
Mar 28, 2012 | Akai PT5492S 54" Rear Projection...
AKAI PT5598HD will not turn on.
if you got to the following link and search by the model number you will find what your looking for.
Http://www.samsungparts.com/search/search.asp
The part number for the service manual is SM-PT5598HD
As the set is showing a blinking red timer light. you can check the following link out.
http://www.techlore.com/article/15444/
May 13, 2008 | Akai PT5598HD 55" Rear Projection...
Akai KC02-E1 Remote with new batteries stopped working.
First, You cannot resync the remote, Second the IR sensor may be bad on the tv and third, the Digital bd may be bad. The IR sensor connects directly to the Digital bd which is the brains of the tv. Also, there maybe a stuck button on the remote or the buttons on the tv.
Jul 13, 2009 | Akai PT4298HD Rear Projection Television
My SONY HD projection TV KDP-51WS550 (2005) suddenly lost the picture and the Stand By /Timer light starting flashing 5x and then repeating. The next morning the TV came on and the flashing stopped. Turned...
Hi, 5 times blink of standby light shows that TV needs White Balance adjustment. No need to dump it, adjustment is also not so difficult. Let me know if you want to give it a try to guide you.
Jun 15, 2009 | Sony Grand WEGA KDP-51WS550 51" Rear...
Akai hdtv 1080i no picture
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Sep 02, 2017 | Akai PTH5498 54" Rear Projection...
50" Akai rear proction tv
you may have a short in your poser supply best thing to do is take it to a shop and have them repair it
Sep 21, 2008 | Akai PT4298HD Rear Projection Television
No power to the television
Dont know if this will help, try leaving it unplugged over night, thaught I saw that solution in a blog somewhere a while ago.
Dec 23, 2007 | Akai PT5598HD 55" Rear Projection...
TV will not turn on...
Convergence board failure. $300 repair
Sep 19, 2007 | Akai PTH5498 54" Rear Projection...
Akai PT4298HD Rear Projection Television Logo
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
