Question about Maytag SAV571EEWW Washer
My water is leaking a little bit of water while it is running. The water hoses and the drain hose is not leaking. What else do suggest it may be?
    Sergeant:
  • 338 Answers
Check your pump I just replaced mine for the same reason.
Posted on Jul 15, 2010
Coolant blockage
the only thing I could suggest is to take bottom hose off of radiator. run water hose through until you see clear water. put hose back on refill with water, let run, and repeat. after you do this a few times it may flush out quite a bit of trash.
Feb 02, 2013 | 2005 Chevrolet Equinox
Water is draining inside the car on the passenger side when I run the air. When I take a right turn it leaks onto the drivers side. I am wondering where the drain hose is located. 1997 Buick LeSabre
find the rubber drain hose under the hood, coming out of the fire wall, its stopped up, clear or cut a little bit off the end of the hose.
Jun 18, 2011 | 1997 Buick LeSabre
Leaking coolant but not overheating
Can you identify WHERE it is leaking from? Is it just a slight dribble and a bit of steam, of a major leak where it is running out?
If it is from the rubber hoses or near the clamps? Your vehicle is quite old and the upper/lower radiator hoses may have to be replaced. A fairly simple loosening of hose clamps with a screwdriver or with a pair of pliers and then just levering them off their housings.
But first get a large sheet of cardboard or plastic and a shallow pan to catch the coolant as you let it drain. Let the engine cool first... test if the internal pressure has gone down by squeezing on the upper radiator hose... if it is easy to squeeze then it is safe to drain and empty the radiator with the little winged tap that is just on the lower, inside of the radiator. Loosen the radiator cap to allow air to enter the system and let the coolant flow out. (Careful with pets... they seem to love drinking the coolant... but it is poison!)
You can now change the upper/lower rad hoses and heater hoses and maybe a short by-pass hose.
IF the leak is just a minor seepage from the radiator or inside the heat core (you likely can smell the vapours of the steam of the leaking coolant inside, the likely cure is to my some "radiator stop leak" from an auto supply store. Follow the directions on the bottle, but most have a syrupy liquid and little metal pellets. You open the radiator cap (when it is cool or depressurized) then add the small bottle of radiator repair solution. Put the rad cap back on and then you have to go for a reasonably long drive (usually 30 minutes or so) to heat up the pellets and have them "melt" as little flecks of soft metal in the solution. The idea is that as the coolant attempts to leak out... these little metal flecks block the leak.
IF you have the coolant totally dumping out and it is not a leaking hose, it may be the water pump and seal. I think I'd suggest that you get a mechanic to deal with that.... it is not an easy task for a DIYer !
I sincerely hope this helps. Please let me know...
/denis
Dec 15, 2010 | 1995 Chevrolet Caprice
Water leaks out all over the floor from the window air conditioner
you need to make sure of two things.
1) the AC is 'tilted backwards' just a little bit - to allow the water (condensate water from the evap coil) to drip from the bottom of the AC - out the 'condensate drain hole' - sometimes into a drain hose (usually rubber) or just through the hole to somewhere outside where it doesn't hurt anything.
2) make sure the - condensate drain hole, and drain hose - (if one is used) is clear and not clogged up - to allow the condensate water to drain.
hope this helps
Jun 26, 2010 | Haier hwr10xc6 Air Conditioner
After a load is finished and drained properly, several hours later the washing machine has filled with water again. I then have to run a drain cycle to use it.
This sounds like the valves that let the water in are leaking, just a little bit. Over several hours, they leak enough to be noticed.
You can have those valves replaced, or you could shut off the water going into the washer with the valves in your water supply. (the one's that are usually right next to where your hoses connect)
Oct 02, 2009 | Kenmore Elite 45986 Front Load Washer
Where to hook up drain hose
On the bucket there should be a cap. If you remove it your hose can attach to it. Run the hose top a drain. If possible, raise the dehumidifier so the water drains properly. From time to time, pour a little bit of bleach into the hose to keep mold away.
Sep 29, 2009 | LG LHD65EBL Dehumidifier
Water leak from bottom freezer door
If you remove the back cover off the unit, you will see the compressor with an evaporator tray, make sure the little drain hose isn't plugged and that there is water in the evap tray from drain hose.
Jul 22, 2009 | Refrigerators
Water leaking on floor from my front loader
it sounds like it's a prob from the water solenoid to the drum and/or the soap box there is a hose that runs between these items to get the water into the drum
Jun 11, 2009 | GE WSXH208A Front Load Washer
Lots of tiny bits of rubber flakes have comeoff door seal and are stiuck to washing
hi Most dishwashers discharge used water through a pipe or a hose connected to the drain or garbage disposer under the kitchen sink. If the drain line is made of flexible hosing, it may have cracked from prolonged exposure to hot water. Examine the hose; if it's damaged, replace it. If the hose is leaking at its connections with the disposer or dishwasher, tighten the fittings or clamps at the connections, or replace the clamps. Also check for water leaks around inlet valves, drain valves, and anywhere you see flexible hoses and hose connections. Leaks at clamps can be stopped by tightening or replacing the clamps. Leaks in hoses can be eliminated by replacing the hoses.
Sep 13, 2008 | Washing Machines
Maytag Performa Washer
when you put the drain hose on the floor the water will ALWAYS drain out. When the drain is in the proper location (above the height of the tub) and the water is still leaking, if its leaking as it fills you might have a loose hose,or a cracked water inlet valve. If after the water is in the tub and its still leaking you have a bad seal.
Jul 03, 2007 | Maytag Performa PAV2200
Maytag SAV571EEWW Washer Logo
91 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
