Question about Weather King 10AJA6001AH Air Conditioner
I have an weather king model # 10 AJB36A01 it stoped and kicked the circuit breaker down i can restart it if I push the fan blade a little bit
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 04, 2010
My weather king will not run on heat or cool. The fan will not run when switched to on. Have proper power to and through the units breaker. Put in new low voltage transformer.
Put the red wire from the secondary/24 side of transformer directly to the green. If blower works the problem is outside of machine. Check for small blade style/ car like fuse inside, check float switches.
Jun 15, 2017 | Weather King Heating & Cooling
I have a Weather King Heat Pump Outdoor Unit, Model 10PJA3101. I noticed that the a/c was on and working fine inside but the fan was NOT moving on the outdoor unit. There are no tripped breakers or...
If you are cool inside and the fan is not running then you are ok... I would however turn the temps. up a bit to eliminate more stress then necessary...
I am surprised that the fan is not working and you are still cooling though.
Was it a windy day? on a still day it may not work...
Are you sure the compressor was running but the fan not???
Some outdoor units do have switches that will turn off the fan if the head pressures are too low if the air temps. are low...
heatman101
Jul 06, 2011 | Weather King 10AJA2501AH Air Conditioner
First time using my air conditioner after winter. my "inside" fan will run but the outside unit is not starting. My weather king is approx 9 years old
Check fuses and circuit breakers to the outdoor unit. Fuses should be right next to the unit in a box on the side of the house. Easiest thing to do is replace them both. Circuit breakers are in you circuit breaker box. There will be two of them, probably 30 or 40 amp maybe 50 amp if a big house. Trip breakers all the way back and then all the way forward. Hope this works.
May 11, 2011 | Heating & Cooling
Outside runs fine but inside squirrel cage motor fails
Go to the thermostat and place the fan switch in "on" and see if the fan runs. If it doesn't then check the circuit breakers. If the circuit breakers are on turn off the power and spin the fan by hand to see if it turns freely. If it does then check the fan capacitor. Let me know what you find.
Sep 26, 2010 | Weather King 10AJA3001AH Air Conditioner
When airconditoner compressor kicks on it blows the circuit breaker whats the problem checked circuut breaker is good.
You may have a overload in that electric line.Example you may have a few appliances running at the same time overloading that breaker. You could replace it with a more capacity. Bad home wiring could contribute to such problem. Check your home for open wiring circuit or bad grounds. Local hardware will sell cheap devices that you plug in your outlet that will light up or even beeb in case of faulty wiring.
Chec your local friend ?...,"THE ELECTRICIAN"
Jun 30, 2010 | Weather King 12AJA6001AH Air Conditioner
Weather King blows fuse in Criterion II furnace
You probably have a shorted wire between the heater and the a/c. There are two wires that conncet the control power to the outdoor a/c from the heater they should be on terminal c & y in the heater. disconect those two wires and try it again if the fuse doesnt blow you have a short in the wire between the a/c & heater
Jun 01, 2009 | Weather King 10AJA2501AH Air Conditioner
Weather king model 10AJA4201
Unit is over heating and setting the internal limit switch. Capacitor an/or outdoor fan could be failing.
Aug 21, 2008 | Weather King 10AJA4201AH Air Conditioner
What part do we replace first?
Door safety switch. You are sure you have power to furnace? jump out the G and R terminals on the furnace control board or turn your thermostat to Fan On to check. Make sure the door safety switch is in the closed position. Fan should come on. No fan, no power to unit. Check Emergency switch, circuit breaker and there may be a fuseable link in the wiring somewhere either above the unit or a condensate safety switch. Get power to the unit. Also check to see if there is a small fuse in the wiring inside the furnace or on the circuit board.
Jan 22, 2008 | Weather King 12AJA4801AH Air Conditioner
Heater works after being off a while
If the unit is remote control try to unplug the supply of the unit(or off and on again circuit breaker) and operate the unit again. If it wont work then call a qualified technician to check the unit, maybe there is a problem with the unit control.
Dec 21, 2007 | Weather King 12AJA4801AH Air Conditioner
Weather King 10AJA6001AH Air Conditioner Logo
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
