Question about Refrigerators
It was getting hot by the door. we were told to take the back panel off and clean. we did that now what do we do
  • 259 Answers
Ok, you want to listen to see if the unit is running. If it is, the fan down by the compressor at the rear of the fridge should also be running. If fro some reason it is not running, you need to make a temporary fix as soon as possible. What you will want to do is to get a small window or box fan to put behind the fridge to make sure that you are able to keep the coils underneath cool.
Check the fan, make sure there is no debris caught in it. See if you spin it by hand if it starts up (don't trust it to stay running).
Make sure all the coils are clean if the fan is in fact running. Heat by the door is usually indicative of restricted air flow across the condenser coils. You will want to remove you front kick plate as well and see if you can vacuum it front the front also.
Reply back with your brand and model number and I will try to offer you some more insight.
Posted on Jul 15, 2010
  • 1 more comment
  • Robert DeStevens
    Robert DeStevens Jul 15, 2010
    I saw one of your other posts for this unit stating it is a hotpoint side by side about three years old. This unit only has the coils located in the rear behind the cover in a "jelly roll" the fan should be mounted on the left side of the roll. Be sure the coils are nice and clean and that the fan is running.
    Take a good look at the fan and see that it is operating at a decent speed. It wont be loud, but should move some air around pretty good. You can test the force of the fan by seeing if the suction it creates will hold a sheet of paper to the outside of the coils.
    If the fan does not appear to be running on this model or running fast enough, replace the main board located on the back of the fridge in a small square recess with a cover over it.
    Make sure the location of this fridge is within specs also. If it fits into an opening, make sure there is at least an inch of space behind it and an inch above it to breath properly.
  • Betty Fox
    Betty Fox Jul 15, 2010
    Thank you.
    We did as you said. the fan is not running at all. we put a window fan behind it
    hotpoint HSS25IFMDWW SD254270
  • Robert DeStevens
    Replace your board, part number WR55X10942 it should not cost you much more than 140$. You can also call ge and see if they will help you out as the fridge is not that old.
    Good luck to you and thanks for using Fixya!!
03 expedition, recently purchased, was told heater needed work, heater was working but when someone switched the control from hot to cool I cannot get the heat to come back on. I was told by the previous...
I think the previous owner needs some heat--inspec system-the vacuum controls on the panel cud hav issues or the heater door or the core itself--get a repair manual from fixya or a parts place
Jan 17, 2011 | 2003 Ford Expedition
Sometimes water doesn't get hot.
Clean the air filter even if it looks clean. The air filter is located in the front panel(unscrew knob to open door)...filter looked ok to me but cleaned it under water and that fixed the problem. Note: I cleaned the water filter first and that did not solve the problem. A simple test to see if the air filter is the problem...take the panel door off, press the filter door button and test hot water usage.
Apr 20, 2010 | Rheem Tankless Hot Water Heater...
My kenmore fridge feels very hot on the panel between the freezer door and the fridge door and also warm on the upper sides of the door
this is your mullina heater, or if its older the yoda loop......
it normal
but if your concerned that its really hot, check you condensor area, it probably needs a good cleaning
make sure the vents on the back are clean
make ssure the condensor fan,, back by compressor is clear as well
Oct 03, 2009 | Refrigerators
Overheating, seals on Roper side by side are hot to the touch
Hi, When that strip gets hot, it is a sign the temperatures are not cold enough. Put a thermomitor in the freezer. You should get a reading of 0 to 5 above. If not, let me know and we can try and get you through this.
Thanks
Vic
May 15, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Refridgerator
Hi. thanks for the question. the heat between the doors is normal . to solve . pull the fridge away from wall .remove back panel. clean all lint in coils .Dust in the coils causes the heat between the doors to get warmer . so cleaning of coils. will solve the problem thanks the appliance doc
Oct 04, 2008 | Jenn-Air JCD2389G Side by Side...
Space between doors on cabnet is very hot to touch ref seems to work ok
hi. thanks for the question .the heat between the doors is normal . its hot to keep condensation from running down the doors .but pull fridge away from wall. remove back panel and clean all the coils. very important. thanks the appliance doc
Sep 30, 2008 | Maytag 23 cu. ft. Side-by-Side...
Kitchenaid KGSA906PSS00
I recently encountered this issue after trying "self clean" on my KitchenAid oven for the first time. I wish I had read these forums and simply avoided the feature. KitchenAid was, of course, completely unhelpful since my warranty was expired. This is the first they've heard of the problem; perhaps search engines are prohibited within the KitchenAid community and they are unable to view the complaints of thousands of other customers as I have... but I digress.
The solution was straight forward: Don't worry about the locked door for now and pull the oven away from the wall. Safety first: unplug your oven and turn off your gas valve. Now remove the back panel. There is a sheet metal strip near the top of the oven that must be removed before the back panel comes loose. With the back panel removed, look for a circular device with a blue and white sticker on it and the part number: 8300802. This is a thermal fuse that blows when the oven gets too hot (apparently "too hot" is a subjective measure as normal operation during self clean will cause this issue). You can check it with a multimeter if you have one... a failed fuse will have a high resistance. To ensure this is your only issue and to immediately unlock your door, adventurous types can bypass the fuse by connecting the two wires that connect to the fuse and hold them together with some electrical tape. WARNING: never operate your oven in this manner. This is a quick test to verify resolution of the issue; not a permanent fix. Apply power to your oven and presto, your door will unlock and your front panel will illuminate.
Now, use the aforementioned search engine KitchenAid has never heard of and search for your new fuse: 8300802. I got mine for $34... you can probably find it for cheaper but my patience was wearing thin by the time I got to ordering a replacement part.
Oh, and one last step: never ever under any circumstances use the self clean feature. Do not take the easy route like I did: get your Brillo Pad and your Easy-Off and get dirty, you lazy bum.
Dec 05, 2007 | KitchenAid KGRT607 Gas Kitchen Range
Frigidaire side by side refridge
pull the kick plate off under the doors. if you look in behind the kick plate youll see alot of dust build up. this area needs to be cleaned once a year to keep air flowing properly over the condenser coils. if the dust build up is minimal then remove back panel of refrigerator and make sure the fan is running behind the refrigerator. if not, or if running real slow replace the fan motor. the heat is the because the condenser is getting too hot. it needs to be fix or the compressor life will be greatly shortend
Nov 20, 2007 | Refrigerators
Refrigerators Logo
20 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
