Question about Bose SoundDock Portable Music Pack Docking Station for iPod Black (309220-1100)
I have had the Bose Portable Sounddock Station and the 1st Gen iphone for a little over 3 years, took it all over Europe and played it 24/7 almost the ENTIRE time I travelled with it without a single problem! So....one day last month I woke up and my iphone was dead in the Sounddock station, so I figured the battery finally died in my 2G, so I put my name on the list for the new iphone 4. I have now been using the iphone 4 on my docking station for almost a month now with no problems. But now yesterday, I'm getting distorted clicking sounds from it while I play music. I have tried a few troubleshooting techniques, and at first I thought maybe it wasn't making good contact with the new iphone with the new rubber case on the iphone, so I took the case off....still does it. It will do it at any volume level, although I'm still trying to determine if pushing down with slight pressure on the iphone will stop this occasional popping sound, but no clear opinion on this yet. Another point, when I removed it from the docking station earlier today, the iphone was unusually hot where the battery is located. My concern is, maybe my first iphone battery didn't die, maybe the Bose killed it? Is this possible? I don't really relish the idea of it killing my new iphone and has it already caused damage with this new popping sound do you think? Sorry for the long winded explanation, but I figured all the facts would make it easier to diagnose. Thanks,
  • 4,323 Answers
Hi
Your explanation helped me to analyze the issue pretty well. When the iPhone is being used excessively the iPhone case tends to get hotter. Sometimes the iPhone also gets hot due to the casing being used. The issue with your iPhone may or may not be due to your Bose Sounddock Station.
The interference/noise you are getting while using Soundock with iPhone is due to Phone's network Interference with the music. To hear without interference put the iPhone in Airplane Mode and then you'll be able to hear the music without any interference or noise.
Hope this resolves the issue, else post back for assistance.
Daniel
Posted on Jul 15, 2010
  • airforce1eng
    airforce1eng Jul 15, 2010
    Daniel:
    I probably should have clarified things even better for you, as I had a feeling you would suggest the "Network interference" issue. Having the Sounddocking station for over 3 years, I'm very well aware of what the networking interference sounds like. In fact, I count myself rather fortunate, as the network interference I get is rather minimal compared to other folks. Network interference is more like a repeatative blurping noise that follows a random set of tones grouped together. I am aware of the sucseptable noise with keeping the iphone in normal transmission mode while in the docking station and I've disabled it to verify the problem continues.
    The noise I'm getting is definitely more an actual "break" in the music, causing a destinctive break in the song and the break is consideraly louder than any kind of interference, with a distinctive "crackling" sound, consistent with a voltage induced peak to peak spike or runaway sine wave. Unfortunately it's not a break long enough to cause the ipod portion to shut off (like when you unplug it from the docking station manually or from a headset). That would be too easy.
    I am trying to duplicate the noise by holding the base of the Bose and gently wiggling the iphone without much success in duplicating. As well as applying gentle but consistent pressure on the top of the iphone while in the docking station, to see if it suddenly stops, has proven not to be producible on each occasion. There are times when it will silence when I apply pressure, then there are times when it will not.
    I'm in the Electronics field myself and very competent in Consumer Electronics, so I was hoping to get some expert advice on this issue on a deeper level that may help me understand if I may need to send this Bose in for service. Your suggestion on it being Network Interference is something I expect my Cell phone carrier to come up with, not an expert on Consumer Electronics. Please don't take offense, but your suggestion is somewhat kneejerk.
    If you are more experienced in the connections of this kind of equipment, the stability of the battery upon a possible short circuit across two voltage pins of the Bose, or able to provide additional "real" technical advice, I would be very much appreciative.
    Thanks,
    David
  • Daniel Scott
    Daniel Scott Jul 17, 2010
    Hi David,
    I didn't give much of technical stuff as I was unaware of your expertise in this field. This kind of noise usually happens due to increase in capacitance value of a component beyond its threshold value. This component (transistor,IC,etc) will be present in voice processing or amplifying circuit of the Bose SoundDock Station.
    And other thing you are correct about is that this may also happen due to an internal short circuit between the Bose Dock's Pins. I wont suggest you to mess with Bose SoundDock Station instead you should ask Bose guys to service it. Before, going to Bose service center I'll suggest you to check your SoundDock with an ipod iPhone from one of your friend.
    Please let me know in case of any concerns or query.
    Thanks
    Daniel
Speakers bose docking station make a noise
Have two Bose docking stations and the oldest (white) one have some problems now. When I put in one of my iPods in the docking, the speakers make some weird, creaky noises. Kind of a sound, when I'm looking for a channel on the radio. When I wiggle a little bit the connector from the docking station, it will play some music for a short time. Still it is not the same quality sound, it used to be. Also, some times the sound is too loud and when I touch ONE time the volume minus (-) button, you can hardly hear the music, it is too soft. Hope somebody can solve this problem.
Sep 10, 2012 | Bose SoundDock digital music system...
Bose SoundDock got wet
No! the Bose unit would need to be serviced by them, there are no authorized technicians outside of the factory, plus they have the needed parts.
Apr 08, 2012 | Bose SoundDock Portable Digital Music...
Bose sounddock portable problem
You can now order a new PCB for the Bose Sounddock PORTABLE at http://www.chargeconverter.com/store/sounddock/portable_repair
Jul 11, 2010 | Bose SoundDock Portable Digital Music...
My Bose Sounddock stopped playing. I believe
mostly the flatcable from the dockingplug to the ampifier has a bad connection ,try to connect it again or resolder the contacts
Apr 19, 2010 | Bose SoundDock Portable Digital Music...
I pod charges, plays, but no sound
Easy, I had this problem too. The reason it isn't playing is because its not in all the way. I was getting very frustrated with this, so I kept trying to push it onto the dock to get it all the way down.
Solution:
1. Play a song on your ipod/iphone so you can hear it through the device.
2. Connect your ipod/iphone to the docking station(Bose) so that you hear the chime(This lets you know its charging).
3. Pick up the docking station and firmly press the ipod/iphone down on the connector.
4. Keep pressing it and wiggling around until you hear the music begin to play through the docking station.
It may take a few tries, but you will get it.
Hope this helped!
~ Jake
Oct 05, 2009 | Bose SoundDock digital music system...
Bose Sounddock won't play iPod touch
You probably have a broken docking connector or bad power supply. Contact www.invebo.com to get a replacement board. It takes minutes to fit. They also sell the USB charge upgrade to enable you dock to charge the IPHONE on the Soundock original.
Sep 13, 2009 | Bose SoundDock Portable Music Pack Docking...
Our sound dock does not charge our ipod touch 2nd gen. Bose manual says it does charge. The sound dock is not series 2. Are they not compatible? Thanks, Mark
The original SoundDock will not charge the iPod touch 2nd gen, or the iPhone 3G, or the new nano either. This is because Apple changed the way their new iPod products charge. (via USB only now)
There is 1 solution- Call Bose tech support. They can replace the 30 pin metal connector for a new one that will charge this. If this is not under warranty, it will cost $99, but it's worth it. New 1 year warranty, and compatibility with all iPods (except much older- non-clickwheel iPods)
Jun 21, 2009 | Bose SoundDock digital music system...
Does the new bose dock station charge the new ipod touch (32g)?
The new SoundDock II charges your new iPod touch and is fully compatible all iPods and the iPhone 3G. Also the SoundDock Portable will do this. But..
Better news-> Call Bose. They can upgrade the 30-pin connector to charge via USB-only and function with the remote as well. $99. This will make your iPod touch 100% compatible and somewhat future-proof your SoundDock. If the SoundDock was purchased within 90 days (at full retail price), they will do the upgrade for a smaller fee or even free I think.. (new 1 year warranty given with repair/mod) btw- This is an Apple issue, not a Bose issue. All 3rd party iPod connection devices had to make this change at some point.
May 31, 2009 | Bose SoundDock digital music system...
Plastic shroud pulled out of docking station power port.
If the 4 input jacks on the back of the SoundDock seem to be okay, then just order a new power supply. If this is not the case, send it in for repair ($100) which upgrades the SoundDock to be able to use the newer iPods (iPod touch 2nd gen, new nano, iPhone 3G)
They give you a new 1 year warranty as well.
May 27, 2009 | Bose SoundDock digital music system...
Gen 3 nano and bose docking station
Have you tried another iPod on it?? I suspect that if you do, that one won't work either. If it's a Bose SoundDock then they are well known for having problems with the iPod connector getting loose. Try with another iPod. If results are the same, take your SoundDock back. Bose should exchange it straight away.
Aug 06, 2008 | Apple iPod nano 3rd Generation
Bose SoundDock Portable Music Pack Docking Station for iPod Black (309220-1100) Logo
123 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
