Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
Dryer not generating adequate heat. needing multiple cycles to dry. cleaned out the vent but no improvement. heating element??
    Sergeant:
  • 338 Answers
I would check heating element also on the heating element box is a thermostat probably need to check that also take the wires off the heating element and use an ohm meter to check it out it should register and not go to infinity. Same for the heating thermostat.
Posted on Jul 15, 2010
The top right side and the right side of the get very hot when drying clothes
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
GOD IS still GOOD !!!! SO MY ADIVE IS FREE
Apr 26, 2015 | Dryers
My miele drying machine shut off after a few use then wait for a few days to work again suspect that it got moisture inside.what to do
DRYER OVERHEATING:
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
Mar 01, 2015 | Miele Dryers
I have a Samsung DV330AEB XAA 04 dryer. It has been turning off during loads on high heat timed dry. Any ideas as to why?
DRYER OVERHEATING:
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
Nov 19, 2014 | Samsung Dryers
I have a TDC6 drier. It starts drying and dryer light is on, but light goes out and it stops drying? Will you be able to tell me what the problem is?
DRYER OVERHEATING:
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
Electric dryer no start does nothing
Oct 10, 2014 | Dryers
Our dryer shuts off completely when we dry several loads in a row. It restarts when we allow it to cool down. What is the problem?
Dryer runs then shuts down wont start up for an hour:
Bad motor windings OR DRYER OVERHEATING:
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
Sep 30, 2014 | Dryers
My whirlpool duet dryer will dry one load of
DRYER OVERHEATING:
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
Sep 14, 2014 | Dryers
Why does my Whirlpool electric dryer - model SEDS800JQ0, shut off after 2 minutes?
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
Aug 09, 2014 | Whirlpool Dryers
Dryer wont heat. we have cleaned out all the lint, replaced the top thermostat and are frustrated. seems like it heats for a couple minutes then nothing.
Sounds like a bad heating element . Many dryers use a dual coil setup ( one coil for low to med, both for high heat). Also check your dryer discharge vent. A blocked vent will not allow the humidity to escape, which will result in your clothes not drying or taking multiple cycles to dry. Turn the dryer on, and find the vent discharge on the outside of your home and just hold your hand there. If you do not feel substantial airflow you have a blocked vent or blocked discharge tube. But from what you described, I would bet on either a bad heating element or failed heating element relay.
Sep 12, 2013 | Maytag Dryers
How long should the heating element heat before kicking off?
??? no real set time for how long itll stay on, it cycles on/off through tempature, if your issue is that it seams to heat but the clothes dont dry?? then i woulsd loook to cleaning your vent... restricted vents restrict amount of heat generated especially usinf enrgy saving cycles..
Oct 09, 2010 | Whirlpool LER4634J Electric Dryer
My kenmore 400 dryer takes for ever to dry clothes, does it need a new heating element?
Have you ever cleaned it out? If not, that is the most common problem with dryers. It can't breathe and takes multiple cycles to dry the clothes. Unplug the dryer and pull it out. Disconnect the vent from the back of the dryer. Clean out lint from dryer and vent. Take the vent outside if you have to and blow it out with air compressor, if you can. Now check the other end of the vent outside at the vent cap. Clean it out and make sure the vent cap flap is not stuck closed. After reassembling vent, turn on dryer and check for heat at outside vent. You also may need to clean it out more if lint has traveled down the vent. Also, clean out your lint filter religiously for more efficient drying. Those are the easy things to look for and fix on your own. If it still does not improve drying, you made need a repairman to trouble shoot it. Good luck!
May 15, 2010 | Kenmore 400 6942 Dryer
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
241 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
