Question about Kicker KX800.2 Car Audio Amplifier
Wont stay powered up cuts out even when turning up just a little bit
    Sergeant:
  • 356 Answers
You might need a 1.2F, 13.8 V Capacitor to make your power stable and eliminate amp from going to protection mode or from turning off.
Posted on Jul 15, 2010
'93 cutlass ciera 3.3 wont stay on after starting up
ignition module getting warm and cutting of or auto shutoff relay loosing power..
Jan 05, 2014 | 1993 Oldsmobile Cutlass Ciera
93' cutlass ciera 3.3 wont stay on after turning over
run the fault codes
not running indicates that the air/ fuel ratio is incorrect for the ambient temperature so you should be checking the ambient temp sensor /baro sensor and coolant temp sensor
May 28, 2017 | 1993 Oldsmobile Cutlass Ciera
1990 Lexus ls 400 giving me hard time to start
Have the cold start fuel inkector checked for flow.
Nov 12, 2013 | Lexus LS 400 Cars & Trucks
Kitchenaid dishwasher 577
Does it work though? If the light is staying on after you cut power then maybe a genie is living in there :)). Other than that it could be a bulb with bad or loose connection. I do know those touch pads behave weird if there was a power cut/surge. Mine did that bit it still works. I'm just waiting to see if a light blows or if some other short happens. Anthony
Jun 15, 2013 | KitchenAid Dishwashers
My cell phone wont stay on
TRY CHARGING THE BATTERY IT SELF WITH A CHARGER..FOR A BIT ANY OLD CELL PHONE CHARGER U DONT USED CUT IT AND CONNECT THE POSETIVE AND NEGATIVE TO THE BATTERY FOR A LITTLE WHILE THEN INSERTED BACK TO THE PHONE AND PLUG IT IN ...WITH THE REGULAR CHARGER..
May 23, 2013 | Cell Phones
I have a 1991 Firebird and lost the key, i had a key made from the dealer and the dealer could not find the vats key code said it didnt have one, so he cut a key to the specs provided by gm and the key...
You can bypass the vats rather easily. You can also try buffing that key down a little bit. As with any key, sometimes they are cut too sharp and need to be filed or buffed down a little to mimic normal wear and tear. Here is a link on the Vats security system.
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Feb 07, 2012 | 1991 Pontiac Firebird
E machine monitor turns itself off and on
The same thing happened to me today. I was just sitting in my room then i hear a click and the cpu is on it stays on for a while then cuts off. It then cuts on and off with few seconds in between. It then stays in that way cutting and off for about a minite or two and then cuts off completely. A few minutes later it starts again. Also in the time it its off it will not turn on by pressing the power button. Sometimes it completly boots up by itself and then shuts itself down. If I shut it down manually while its on it'll turn itself on immeditaly after. What's going on! Will the warranty cover it? Do I need a new computer?
Feb 01, 2010 | E-Machines eMachines Monitor E15T4
Not warming up or keeping tickover keeps cutting out althoughnot
carb needs a clean , try fireing a bit of injector cleaner into the carb (remove airfilter and spray a little bit at a time !! then try again , if still no good the carb will need to come off and be cleaned ,
hope this helps
kind regards
bert31000
Mar 18, 2009 | 1990 Aprilia AF1 125 Futura
Ps2 slim console wont turn on!
i checked the manual (troubleshooting) 1. turn off PS2 2. unplug it then, plug it back in and turn it on(andprayitstillworks).
Jan 10, 2009 | Sony PlayStation 2 (PS2) Console
Thinkpad lcd wont come on
Hello, It may be the power is set wrong. Click start, control panel, power options. From here you can set the amount of time you want the monitor or hard drive/s to remain on until the shut down or go into hibernation. Hope this helps.
Mar 25, 2008 | Computers & Internet
Kicker KX800.2 Car Audio Amplifier Logo
89 people viewed this question
Top Kicker Car Audio & Video Experts
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
