Question about RIM BlackBerry Bold 9000 Smartphone
RINGING TONES ARE NOT RINGING AND MUSIC IS ALSO NOT PLAYING AND IT DISPLAYS VOICE ACTIVATED DIALLING IS ACTIVE BUT ITS OFF FROM THE FUNCTION MENU
    Novelist:
  • 144 Answers
Your rear speaker is broken.
actually the pins that attach the back of the speaker have been squashed down and now are instead flush with the connector instead of touching it.
it is what we call classic Chip Creep.
(FYI http://en.wikipedia.org/wiki/Chip_creep)
it is caused by putting pressure on the back of the speaker, and you will notice if you press in on the speaker hole, while holding the same place at the back of the phone , the sound will come back to normal volume.
some have suggested wedging a piece of paper in the gap between, but it isn't guarenteed.
so to fix it, you have to actually take off the back of the phone,
unscrew the 4 screws holding the front face plate to the main chassis of the phone,
and carefully pull it apart.
you will see the speaker near the top of the phone, it just sits there, with two copper pins sticking out of it, and it should sit against the female side of the connector.
you can unbend the pins so they sit in a L shape now, and reattach it back in.
and to alleviate the pressure, you can insert a piece of paper, card, plastic from an ID card etc, behind the battery which makes a bit of gap.
I hope this helps. i managed to get it working better without the paper insert, just by resetting the pins on the speaker itself.
Posted on Jul 15, 2010
How do i make a hands free call on my head set i have a plantronics explorer 200 series?
To use Voice Dialing:
With the headset on, press the call controlbutton for 2 seconds to activate the voice dialling.
NOTE To use voice-activated dialling, the voice-dialling feature must be enabled on your phone. See your Bluetooth Phone Manual for instructions.
Good luck from Headsets Direct!
Aug 22, 2011 | Plantronics Explorer 240 Bluetooth Headset
My phone is not ringing when I get incoming calls, beeping when I get txts, and it won't go on loud speaker. The volume is high. Its set to normal profile, with ringing volume high. Please advise.
Some how your phone was reset or had the tone turned off. Just follow the below guide and your audio should come back on. I would do a soft reset (turn off the handset, remove the battery then reinsert) before performing the instructions.
Tone settings
To select a ringing tone for voice calls, select Tones >
Ringing tone.
To select a ringing tone for video calls, select Tones > Video
call tone.
To set the ringing type, select Tones > Ringing type. You
can also set the device to sound a ringing tone that is a
combination of the spoken name of the caller and the
selected ringing tone, when someone from your contacts list
calls you. Select Tones > Say caller's name.
To set the volume level of the ringing tone, select Tones >
Ringing volume.
To set the various alert tones, select Tones > Message alert
tone, E-mail alert tone, Calendar alarm tone, or Clock
alarm tone.
To set the device to vibrate when you receive a call, select
Tones > Vibrating alert.
To set the volume level of the device keypad tones, select
Tones > Keypad tones.
I have included a link to download your user manual if needed, it comes as a PDF file so you need to have adobe PDF down loader
http://nds1.nokia.com/phones/files/guides/Nokia_E63-1_UG_en.pdf
Apr 23, 2011 | Nokia E63 Cell Phone
The phone talks to me when i scrole thru the menu how do i turn this off. my display is showing a speaker with lips abovew it i want to remove from my display and turn this function off
In the menu you can find the link to settings/ tones in which the voice prompt could have been activated.
you can chnage the settings to reset it. Also a reset to factory default can also bring this about.
Sep 25, 2010 | LG Cell Phones
Nokia 6300 has stopped ringing anyone any ideas?
o.k. does it vibrate?
have you dropped it?
You may have accidentally put it on silent mode:
HERE IS HOW TO CHECK YOUR TONES OR PROFILE:
10. Settings
Profiles
Your phone has various setting groups called profiles, which you can customize with
ringing tones for different events and environments.
Select Menu > Settings > Profiles, the desired profile, and from the following
options:
● Activate — to activate the selected profile
● Personalise — to change the profile settings
● Timed — to set the profile to be active until an end time. When the time set for the
profile expires, the previous profile that was not timed becomes active.
Themes
A theme contains elements for personalizing your phone.
Select Menu > Settings > Themes and from the following options:
● Select theme — Open the Themes folder, and select a theme.
● Theme downloads — Open a list of links to download more themes.
Tones
You can change the tone settings of the selected active profile.
Select Menu > Settings > Tones. You can find the same settings in the Profiles menu.
If you select the highest ringing
all this can be found in your manual:
here is a link to the manual for: nokia 6300
please remember to rate my help if it was of assistance it helps me too.
Mar 26, 2010 | Nokia 6300 Cellular Phone
Voice dial?
Voice Command
To activate voice commands:
1. In your menu, go to MY STUFF MENU
2. select TOOLS
3. select Voice Command
4. Enable the on/off option
How to use it:
Call <Name or Number>: This function is activated only when if user says command “Call” and name stored in address book or specified phone number. Handset, voice engine inside recognize users utterance handset, displays name lists from your phone’s address book or phone number, however noise might caused to display candidates. Additionally user can superimpose number type at the end optionally, such as “mobile”, “home” or “office”.
Hope this helps & happy holidays!
-TJ
Dec 15, 2008 | LG Vu CU920 Cellular Phone
Speaker key and deleting voice mails
you hit the speaker button on the left side of the phone and the pad shows up...
Apr 22, 2008 | LG Prada KE850 Cellular Phone
MP3 ringtones sound 'funny' on my N73!
ur speaker must be containg dirt or water must have entered in ur speaker if ur cell is in validity period then go to nearest nokia care n tell them ur problem they will solve it surely
Apr 14, 2008 | Nokia N73 Cellular Phone
How to turn vibrate on?
You can change the settings of the selected active profile.
Select Menu > Settings > Tones > Incoming call alert, Ringing tone,
Ringing volume, Vibrating alert, Push to talk settings, Message alert
tone
, Instant msg. alert tone, Keypad tones, or Warning tones. You can
Jan 16, 2008 | Nokia 6288 Cellular Phone
Recording music
The phone has a Voice Record feature, but I think it's only for a couple of seconds of audio for the voice dialling feature.
Anyways, go to Menu > Office Tools > Voice Records and press the Voice button, located on the right-side of the flip display.
Nov 07, 2007 | Motorola Mobility RAZR V3
RIM BlackBerry Bold 9000 Smartphone Logo
208 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
ismael castillo
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
