Question about Nintendo Wii Console
The wii remotes wont connect with the console.... wha can i do
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 242 Answers
First hit the button on the wii then on the remote.
Posted on Jul 17, 2010
Wii remote lights 3 and 4 stay on
The wiimote is busted. Sorry.
Jun 13, 2012 | Nintendo Wii Console
Wii remote wont connect ?
if it wont sync after using the red buttons then its just bad batteries from the sound of it or the remote has gone bad.
Try fresh batteries or let the rechargeables charge (assuming they arent bad)
Apr 30, 2010 | Nintendo Wii Console
Remotes wont work light up but wont stay on ,hit
The red button, is a sync button and not a reset button. You can try resyncing your wii remotes to your wii follow these steps:
  1. Press the Power button on the Wii console to turn it on.
  2. Open the SD Card Slot cover on the front of the Wii console. Remove the battery cover on the back of the Wii Remote you wish to sync up.
  3. Press and release the SYNC button on the inside of the SD Card compartment on the console. Press and release the SYNC button just below the batteries on the Wii Remote.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
You must have batteries in when pressing the red sync button on the wii remote, if your using the wii remote charger system, you must remove it and use batteries until this step is done
Hope this helps. Owen
Apr 20, 2010 | Nintendo Wii Console
My controller wont hook up with the wii
In the battery area of the qii remote and inside the front panel of the wii console, there are connect buttons, push the red button on the console and remote to sync them together
Jan 01, 2010 | Nintendo Wii Console
My wii isnt registering my remote - i have checked the batteries and all the connections it just wont awknoledge my remotes
Try unplug the AC adapter from power cord.Wait 30 min and plug it again.Then open the front cover on your Wii, then push the red button there, then open the batteries cover on your Wii Remote and push the red button there.If the Wii Remote does't connected may you have problem on bluethoot device and your Wii need service.
Oct 16, 2009 | Nintendo Wii Console
Remote wont work when trying to connect to wii menu
There's two things I know of that could be causing this: either the batteries are too low, or the remote is no longer synced to your console for some reason. The batteries are easy enough to check--just replace them and see if the problem is fixed. If that doesn't work, try resyncing your remote. Each remote has to be synced to your particular console, and won't work on any others. There are buttons you have to press on both the remote and the console that sync the two together--there should be detailed instructions in the Wii manual.
May 09, 2009 | Nintendo Big Brain Academy: Wii Degree for...
2nd wii remote wont connect
Wii Remote Syncing problem is one of the common problem of Nintendo Wii. You may check out the DIY Wii Fix Guide, that explains step by step to fix the problem without any technical knowledge. I hope this guide will solve your problem. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.
Dec 28, 2008 | Nintendo Wii Console
Wii remote
mine does the same thing. all u have to do i open the back of the Wii remote where you put in the batteries. then all you have to do is press the red button in the bottom right hand corner and wha lah it is a synced!!!!!!!!!!!!!!!
Aug 06, 2008 | Nintendo Wii Console
HELP PLEASE!!!!!!!
I've had this same problem. Remove the batteries from the remotes. Then disconnct the power cord from the back of the Wii and disconnect the power cord from the wall. Let it sit for 5 min. Double check that the sensor bar is plugged into the Wii and check the cord for any breaks that might stop the signal. After you are sure that the sensor bar is connected and the 5 min. have gone by plug it all back in, install your batteries and re-sync it.
Mar 28, 2008 | Nintendo Wii Console
Wii sensor bar
possibly, or low batteries in the remote. Try placing the bar under the tv if its above at the moment, or vice versa if currently below. Also make sure sensor bar overhangs tv slightly too...
Mar 08, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
22 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
