Question about Maytag Electronic Portable Air Conditioner Heat
I had to replace the exhaust hose (the one on the left) because the hot air from the previous season made it very brittle and it cracked when i took it off. Is this normal? Also, I replaced it with an aluminum hose (normally for laundry dryer) and it gets pretty hot. Is this okay?
  • 4 Answers
I insulate the (hot) hose so the heat -- for sure -- goes outside. Any heat that returns into the room defeats the work to get it out of the air in the first place.
Using a dryer hose is fine if air doesn't blow out of the seams. Considering that the unit may cost $300/season to operate (just for the electricity) you might want to be sure the hot air gets out. I wrapped a blanket around the hose.
If the sun is on a hose that is not made of UV-stabilized material, it may become brittle. Side note: venting out to the sunny side of a room hampers the efficiency of the unit. Avoid operating the unit with direct sun on it.
Posted on Jul 15, 2010
P0406 2007 ford mustang
The 406 code is the EGR valve. This valve sends exhaust gas back into the intake for reducing emissions. Take it off and clean it and inspect it for debris that hold it open. IF it is sticking open it would cause the 108 code. The 108 code is the MAP sensor that measures the vacuum on the air intake. Make sure all hoses etc are not cracked or brittle.
Sep 20, 2014 | Cars & Trucks
My air conditioner blows air out on top by the window and on the floor but not in the middle on the dashboard. What part do i need to fix this and where is it located in the dashboard or under the hood?...
  • If the AC/heater air control doesn't work, you most likely have a vacuum line broken. All the air flow doors in the heater system are vacuum operated and without it the air will blow out of the windshield defrost vents. The common place for a vacuum line to break is under the hood where the lines pass near a hot area. The vacuum lines are normally a rigid black plastic tubing about 3/16 inch in diameter. They run across the engine compartment fastened to the section just below the wipers and air vent. The tube goes through the dash, usually near the steering column. When the tubing has been hot for long time it becomes brittle and cracks or breaks. Trace this tubing looking for a crack or break. The easiest repair is to cut out the broken section and replace it with rubber hose of the correct diameter. The hose needs to have an inside diameter that will fit snugly on to the vacuum tubing.
    Thanks for using FixYa.
    Gaker
Jul 26, 2011 | 1996 Buick Park Avenue
Just took my VT750 into shop for backfire issues.
I would probably take it back to the mechanic and ask, the high reving could be loose or cracked inlet manifolds or a clamp left loose, this can cause backfire as well as that cylnder runs lean, other causes of back fire are, lean fuel issues, low ignition voltage, leaks in exhaust gasket or exhaust, incorrect valve clearance, just on downshift try manifolds and exhaust first
Apr 23, 2010 | 2003 Honda VT 750 CD Shadow A.C.E. Deluxe
04 ENVOY,REPLACED SECONDARY AIR PUMP AND BLEW OUT SYSTEM, REPLACED FUSE AND STILL PUMP IS FILLING WITH WATER, CHECKED ALL HOSES AND FOUND NO CRACKS, WHAT ELSE SHOULD I CHECK
The water comes from exhaust system /condense/ because the check valve does work properly. The check valve is located on left top side of the engine where the hoses from the air pump connect to the exhaust.
Apr 01, 2010 | 2004 GMC Envoy
There is a puddle of oil behind the throttle plate in my 97 land rover discovery.why? there is a breather hose that goes from the valve cover to the mantafold plenum is there supposed to be a pcv valve or...
My 96 Discovery has a plastic baffles inside the valve cover port that connects to the hose. If it got brittle and cracked, then oil could leak by. Its cheap and easy to replace, along with the hose. There is a second hose on the other side to replace as well. Land Rover was proud to pass emissions standards without using exhaust gas recirculation (EGR). The whole system is sealed, so all the air entering the engine is being metered by the Mass Air Flow (MAF) sensor, unless your breather hoses crack and leak. Unfortunately, oil in your location might also indicate other engine trouble, such as worn piston rings (causing pressure in the crankcase). I would try replacing the plastic baffle piece first.
Aug 30, 2009 | 1997 Land Rover Discovery
Hot air coming out of back
portable air conditioners mainly have two hoses one hose is exhaust thats the one that is blowing hot air. the one pulling is return.. the hot air blowing out should be exhausted to the outside. the blowing air needs a hose and to be laid out a window the back should have model and serial maybe product number. the two holes are either 4 inch or three inch and most portable units other than hand me downs come with a window frame that allows the hot exchanged air to go outside and cooler air to be used for heat exchange.
May 28, 2009 | Maytag NMPEB08F2A Air Conditioner
Vents blow hot air all the time and heater/ac controls do nothing
I had the exact same problem with my '85 300ZX. Turned out to be a vacuum hose under the dash that had come loose. I noticed that others were brittle and would soon probably crack, so I replaced them all. There is some good info at http://www.thumper300zx.com/z31/vacuum/vacuum.htm
Jan 25, 2009 | 1985 Nissan 300ZX
Blower only coming from defrost and floor vents
Damper is vacuum controlled, check for cracked vacuum line running from manifold to heater control box.
Aug 01, 2008 | 2000 Chevrolet Astro
Heat/ac
You would be wise to check all the small rubber hoses under the hood as it would appear that you have a vacuum leak preventing the airflow door from moving to any other position. Look for cracked /cracking, split hoses or disconnected hoses and replace as necessary.
Good Luck!
Rich Lilja
Jun 04, 2008 | 1999 Ford Taurus
Maytag Electronic Portable Air Conditioner Heat Logo
152 people viewed this question
Top Maytag Heating & Cooling Experts
gbob59
Marvin
Marvin
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
