Question about Bosch Classixx WFL 2066 Front Load Washer
All of a sudden my machine will not spin or drain
  • Bosch Master
  • 2,605 Answers
Hi, welcome to fixya.
If your washer is indeed a WFL2066, than the not spinning is directly related to the unit not draining.
These machines by design cannot spin if the drain is inadequate.
Here is the first step in resolving the problem, you need to access the drain pump/filter to clean it.
To reach the filter and clean it...
**Unplug the washer from the dryer or wall, or turn off the 30amp breaker at the home service panel...safety first**
1) Open the small square plastic door at the right bottom of the washer.
2) Via the small hose drain any access water from the pump...this is where a wet/dry shop-vac comes in handy, or a shallow pan with a few towels works as well.
3) Then turn the pump insert/button trap counter clock-wise and pull out. Clean the trap out thoroughly running it under hot water and mild soap or your washer detergent and inspect inside the pump for any other foreign objects/obstructions.
4) Re-install the lint trap insuring it is good and snug/tight. Before closing up the small access door, run a short rinse spin cycle to check for leaks.
Let me know how you make out, or if you require further assistance.
Thank you for visiting "fixya", please take a moment to rate the info provided for you here.
Good luck.
macmarkus :)
Posted on Jul 15, 2010
I did everything you stated and my machine still will not pump water out but the tub spins. what do you think?I think the pump is clogged. how do i unclog it?<!-- from fixya rte -->
Posted on Aug 15, 2010
  • slowride Aug 15, 2010
    how do i get the pump out of my Bosch Nexxt front load washing machine?
  • prem mathew Aug 31, 2010
    Type "Bosch Nexxt pump" on the blue banner, below Fixya on the top of the page, and click 'search' You will get over 50 solutions. Examine which one suits your query.
Washing machine wont drain
Does the washer spin when in spin cycle ? If it does spin and there is no water coming out of the drain then you most likely have a bad wa
Aug 07, 2012 | GE Washing Machines
Displays PFE
The washer will stop during spinning .
Spinning is insufficient. Error display PFE
Is the filter of the drain pump clogged?
Is the drain pump operated?
Did you use the proper amount of detergent?
Is the drain hose placed higher than 1m above floor?
Mar 11, 2012 | Washing Machines
My washer will wash and rinse but wont spin all of a sudden
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 04, 2011 | Washing Machines
Hi I have a 5 cycle 2 speed top load whirpool washer and it all of a sudden will not go to the Spin Cycle and drain out the water. It stops in the rinse cycle. I need help!
heatman101
Jun 25, 2011 | Washing Machines
GE model wwse5240G washer suddenly stopped working full of water
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Feb 19, 2011 | GE WWSE5240G
Roper washing machine agitates but will not drain or spin
its your lid switch. it cant spin til that switch is closed,and they break all the time.its thru that hole where the lid seats on the top of the washer.also some times the switch actuator on the lid breaks,but not as offten.inspect that area and you will see issue.you can cut and connect the wires underthere in a pinch[there are three wires to the lid switch.dont connect the green ground its the other two]but you must be careful if you have children they will be curious and lift the lid and it wont stop spinning,so if they reach in with there arm,their has been cases of arms being torn of from spinning tub.how this helps God bless ,tom
Jan 26, 2009 | Washing Machines
MACHINE RUNNIMG STOPPED SUDDENLY WITH THE LIGHTS BLINKING AND WE TRIED TO RESTART IT AGAIN AFTER DRAINING THE WATER THROUGH THE OUTLET PIPE &OPENED THE DOOR REMOVED THE CLOTHES AND RESTARTED IT AGAIN BUT...
turn on power switch,then press the spin speed button then push start, the water should drain then spin. if the water does not drain chech the drain pump button trap, located lower left front panel.
Dec 30, 2008 | LG WM-2277HW Front Load Washer
Washer not spinning
check the sensor switch located underneath the the top washer where the door closes , make sure contacts are clean (or align for magnetic SWITCH)
May 05, 2008 | Kenmore 3.5 cu. ft. Front Load Electric...
Hitachi SF-H900TPX Washing Machine not working properly
Open machine's service panel and check whether the motor spins. Let us know with your results and we will see how could we assiste you further.
Aug 31, 2007 | Washing Machines
Bosch Classixx WFL 2066 Front Load Washer Logo
1,153 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
