Jamed, won't go forward or back, how to take apart and repair?
I got it working by using WD-40. Soaked the cutters and switch which basket pushes against and it started working again just great.
Posted on Apr 21, 2008
My Victa push lawn mower won't shut off. Throttle cable pulls back but won't push forward and springs underneath housing seem extremely loose. What do I need to repair/replace?
Sounds like the inner throttle cable is binding with the outer casing,
This coule be caused by dust and moisture causing rust on the inner cable. I would firstly try to get a light spray lubricant into the outer casing .
I would disconnect it from the throttle lever and spray lubricant onto the inner cable and progressively work the throttle lever to draw the fluid into the outer case. Elevate the lower end so gravity will assist you.
Feb 03, 2013 | Garden
I dropped the feed dogs and they won't come back up.
Ignore all the other comments, they are wrong.
The feed dogs are driven by the feed driver mechanism, turn the hand-wheel forward and the feed dogs will come up. (Providing you have the feed dog switch to the up position).
Aug 28, 2012 | Brother PC-420
The flywheel on my elna special sewing machine won't tighten after winding on thread to the bobbin.
it's very possible that a part could be worn or jamed or even broken
only a sewing machine repair shop can tell what wrong
Feb 02, 2012 | Elna Sewing Machines
I have paper jamed in my shredder, I can't reverse or forward. How can I clear the jam?
You may have to take it apart to clear it by hand...remove the bin, remove th screws from underneath inside the cabinet and take the cutting head off the cabinet. Turn it over and remove the screws, turn it bak over and take the top off to see the insides.
Oct 01, 2010 | Royal 160MX Shredder
I have a Campbell Hausfeld PL1502. Air flow from the compressor is good, it won't go forward or backwards, won't even try. Air just whistles through it. I took it apart and didn't find anything obvious,...
oiling thing? thats the easy part,,its oiled every time you use it,
now it wont start then,,,ok its jamed up or the air flow and presher is to low for it,,,look under the handle were the hose fits to the gun there should be a big screw there on this screw there should be 1-2-3-4? turn it to 4,,now try it???
Aug 18, 2010 | Campbell Manufacturing Campbell Hausfeld...
Hello. My 02 grand cherokee has power seats.
THE GEARS ON THE SEAT TRACK MOTOR ARE PROBLY JAMED TRY PUSHING BACK ON THE SEAT WHILE PUSHING THE SWITCH
May 26, 2010 | 1994 Jeep Grand Cherokee
Cassette does not eject
Either the tape is jamed round sound head, or the door is stuck with somthing like a handle of the case on side of camera, but sounds like tape stuck, run film backward a little (not forward) as more tape will get stuck in forward motion.
May 24, 2010 | Sony Handycam DCR-TRV280 Digital Camcorder
My 308 winchester 99e lever action jamed, had to
found someone on internet that sent me the plan for free. by searching you can save money.
Oct 24, 2009 | Sport & Outdoor - Others
Cds in changer STUCK!
There is a Manual Magazine release on the bottom back right corner. Pushing the lever back will release the Magazine.
Aug 08, 2008 | Bose Lifestyle 20 System
Wii console
Im not familiar with the Wii but i will try to help.
Is it just not opening or is it actually physically Jamed?
If its jamed, try turning it upside down and then back to right side up, then try ejecting it.
There may be a pin hole on the front of the drive, just like a computer cd drive, get a thick paper clip and insert it, push hard till the drive pops slightly open, then pull it the rest of the way and remove the disk.
Last resort is to open her up and remove the disk drive altogether and then take apart the case, then you can use your finger to move the disk back onto the carasel and then eject it once its plugged back in.
Mar 25, 2008 | Nintendo Wii Console
jasbo
jasbo
