Question about Caroma 270W-RF Reflection Round Front Dual Flush Toilet - White
Caroma dual flush toilet is only 2 years old and leaking down the overflow. Unlike the older ones that had a ball adjustment screw can these be adjusted?
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 7 Answers
Yes, these can be adjusted. However you may want to make sure the inlet valve isn't just leaking and filling the tank, causing it to overfill. Call the guys at Plumbingmall.com 1-888-595-1122. They stock every part Caroma has available and have tons of answers. https://www.plumbingmall.com/Caroma-Spare-Parts
Posted on Oct 03, 2017
  • 760 Answers
How to adjust to lower the water level in caroma caravelle system
Adjusting Water Levels in a Caroma Dual Flush Tank (with Caroma ...
? 0:34
www.caromausa.com/resources/videos/articles/27.php
Feb 12, 2013 - Uploaded by caromausa
Comparing the Caroma Toilet Footprint to the Standard North American Toilet ... Adjusting Water Levels in a ...
FAQs - Caroma
www.caromausa.com/resources/faq.php How do I adjust the water level on a Caravelle tank? ... toilets have been subject to clogging due to the lower volumes of water used in ultra low flow toilets.
Troubleshooting the fill valve on a Caroma toilet '
? 0:50
www.caromausa.com/resources/videos/articles/49.php
Feb 12, 2013 - Uploaded by CaromaBathrooms
Adjusting Water Levels in a Caroma Dual Flush Tank (with Fluidmaster Fill Valve) · Adjusting Water Levels ...
Caroma Information and Installation Videos '
www.sustainablesolutions.com/resources/tips_and_techniques/articles/477.php Comparison of Caroma toilet bowl footprint to standard North American Bowl · Caroma ADA ... How to adjust the water level in your Caroma dual flush tank (with Fluidmaster Fill valve) ... NEVER use a reducing type wax ring on Caroma toilets.
Jun 08, 2018 | Caroma Home
How to adjust to lower the water level in caroma Caravelle system
? 0:34
FAQs - Caroma
? 0:50
caroma caravelle system reduce level Google Search
Both of my Caroma toilets constantly "run",water is trickling constantly. How to stop those leaks? labels on toilets say: Caroma C Velle 305 EL SNV PAN made in PRC. Maintenance people from the...
Constant running can be due to a defective fill valve or faulty flapper. Try replacing either or both before discarding the entire toilet. One other possibility is that poor design results in poor operation.
Aug 07, 2017 | Caroma CARAVELLE270ADAW-EL Caravelle...
Toilet will not Shut off!
the rubber flapper on the bottom of the tank is not seating on the drain and it is allowing water to leak out to the sewer, also check to see if water is too high in the tank and flowing out of the center overflow tube, if so adjust the height of the water level
Aug 19, 2010 | Caroma CARAVELLE270ADAW-EL Caravelle...
Water is leaking out , close water off then water in tank goes empty. when water on you can hear water runing in tank
Your flush valve (flapper) is leaking. Some of these rubber flappers snap on to posts. Others, slide down the overflow tube. Others are the plunger type that lift straight up and down (some of these have a gasket on the bottom that go bad.) In any case be sure flapper closes properly. Make sure the chain to the handle isn't so long as to get between valve and seat holding flapper open. If all else fails buy a fluidmasgter flush fixer repair kit and follow directions. I had a similar problem one winter and wasted about 200.00 on water.,
Jul 10, 2010 | Caroma 270W-RF Reflection Round Front...
I have an old Caroma Dual flush ( 15-20 years) and the washers on the inlet valve dont seem to be able to regualate the flow in, after the toilet has been flushed, as a result water sprays up out of the...
Well luckly the velve can be replaced by a modern 1. iets not exspensive and dosent take long to do, u will get a step by step apon perches.
Plz rate my advice
Jun 16, 2010 | Caroma 270W-RF Reflection Round Front...
Cistern leak
The flapper valve(ball)seat is not sealing. Needs a new seat and flapperat bottom of tank. -Ned-
May 26, 2010 | Caroma CARAVELLE270ADAW-EL Caravelle...
Hi, i have a caroma duel flush toilet possibly 10 years old, it is leaking into the bowl and then constantly re filling, i replaced the washer/ring/ thing at the point where the water exits into the bowl...
First make sure it is not overfilling. The water level must stop before it reaches the overflow pipe. If it continues to run it will overflow into the bowl and continue to run. Adjust the fill level to the mark inside the tank. Make sure nothing is getting under the flapper and holding it open. You replaced the flapper so we know that is not the problem. Just make sure the flapper is centered on the drain hole.
Jan 09, 2010 | Caroma 270W-RF Reflection Round Front...
Caroma 270W-RF  Reflection Round Front Dual Flush Toilet - White Logo
2,141 people viewed this question
Top Caroma Home Experts
john h
Andrew Taylor
Andrew Taylor
Are you a Caroma Home Expert? Answer questions, earn points and help others
