Question about iRiver H10 MP3 Player
The scroll bar stopped working all of a sudden... it will not scroll up, and only sometimes does it scroll down,and will get jammed scrolling down and will not stop... how can i fix this?
Hi! I'm having the same problem. Have you managed to work through it?
Posted on Sep 02, 2010
How do you stop scroll from sliding down on its own on acer laptop aspire 4250?
Go to your control panel then choose the mouse option. Under the wheel tab you should see scrolling options.
Aug 17, 2014 | Acer Aspire Computers & Internet
Scroll bar
Most modern laptops with touchpads offer vertical scrolling, horizontal scrolling or both. These features are located along the right-hand and bottom edges of the touchpad, respectively, and are activated when you swipe your finger along the touchpad edge. Scrolling functionality is nearly always enabled by default, but some users find the feature an annoyance and elect to turn it off. In most cases you can simply turn the feature back on using the Windows Control Panel.
Click the Windows Start button, select "Settings," and then click "Control Panel." Double-click the icon labeled "Mouse." Select the Touchpad properties tab. The labeling of this tab varies, depending on your computer manufacturer, operating system version and the device drivers installed on your machine. Common labels include "Touch Pad," "Device Settings" and "Dell Touchpad." If you do not see this option, you may not be able to turn on scrolling for your laptop; skip the remaining steps and refer to the "Warnings" section below. Click the "Settings" button within the Touchpad Properties menu and look for the section labeled "Scrolling Settings" or similar. Enable scrolling within this section and define other scroll settings, such as scroll zone width and scrolling speed. Click "OK" to confirm your changes, and then close the Control Panel windows opened in the previous steps. The scrollbar on your laptop is now enabled.
Scroll Is Not Working With Windows 7 b> Certain computer touchpads have a vertical section on the pad itself that is used to scroll through the page or program window that you are currently viewing on your computer. If the scroll functionality suddenly stops working but the actual touchpad is still fine, this means that the part of the software for the device that controls the ability to use the scroll has been disabled. You can enable it again in the Control Panel.
Click "Start." Click "Control Panel." Click "Mouse." Select the "Enable Scroll" option (or whatever similarly named option is available on your specific model of laptop computer). Click "Apply." The scroll bar on your touchpad will now work again.
Feb 03, 2013 | Acer Aspire Computers & Internet
My blackberry scroll bar is malfunctioning - sometimes I cannot get it to scroll up and down only scrolls side to side.
You can try removing the scroll ball and cleaning it, that could be the reason why it wont scroll up and down.
www.usedcellphoneshop.com
Jun 07, 2010 | RIM BlackBerry Pearl 8100
The roller bar area is not working
It sounds like the touchpad needs replacing. Contact me if you can't get it repaired locally.
Jan 09, 2010 | HP Compaq 236076-001 Touchpad
Scroll bar on my HP dv6700 laptop stopped
The keypad may need to be replaced ,if the scroll bar stopped working and everything else works ok.Probably a keypad malfunction.
Oct 09, 2009 | HP Pavilion dv6000z Notebook
Cordless mouse, model A1197 will not scroll downward
mouse model a 1197, new battery still don't work
Jul 04, 2009 | Apple Mighty MA086LL/A Mouse
Microsoft Wireless Laser Mouse 6000 v2.0 Scrolling has gone awry
This may not be a solution for you but at least it may explain the cause of the problem. I recently had the same problem - the scroll wheel suddenly began to go crazy, jumping all the way to the bottom or the top of a document, or randomly skipping around. The unit was still under warranty, and Microsoft sent me a new mouse. Since they did not require me to return the old mouse, I decided to take it apart to see if I could find the problem. I found poorly soldered electrical joints to the optical sensor & LED which convert the scroll wheel movement to electrical signals. After I resoldered these connections the mouse worked fine again.
Feb 03, 2009 | Microsoft Wireless Laser Mouse 6000 v2.0
"Scroll Bar"
try to reinstall the the touch -pat and function key software one more time.
Dec 27, 2008 | Computers & Internet
Scroll bar not scrolling
hey just format the set...it ll work..
Jun 22, 2008 | LG Shine KE970 Cellular Phone
Cursor Will Not Stay Put
Try uninstalling the drivers from the device manager, then do a hardware search. It will automatically find the touch pad and reinstall the drivers. If this doesn't work, then check the connector under the keyboard. Disconnect it and reconnect it, they sometimes work loose. If these don't correct the problem, then you have a faulty touch pad and you'll have to replace it.
Jun 20, 2008 | Toshiba Satellite A45-S250 Notebook
iRiver H10 MP3 Player Logo
124 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Mohamed Ismail
Mohamed Ismail
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
