I am repairing my home ac thermostat and need one with a color scheme for 7 wire colors
  • 456 Answers
If you go to the air handler that you have and follow the thermostat wires to the control board they should match up to your thermostat
Posted on Jul 15, 2010
I want to change the font on windows 7
1.If you have Windows 7 Starter or Home Basic:
Open the Control Panel (icons view), and click on the Display icon.
In the left blue pane, click on the Change color scheme link
Click on the Advanced button.
2.If you have Windows 7 Home Premium, Professional, Ultimate, or Enterprise:
Right click on a empty space on the desktop and click on Personalize.
Click on the Window Color link at the bottom of the window.
Click on the Advanced appearance settings link.
3.Select a Item that you want to change the font for.
4. To Change the Item Font
Click on the Font drop down menu and select a font.
**If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Mar 14, 2013 | Computers & Internet
Tip
How to Crimping Network Cables
Tools and Materials You Will Need
Crimper with RJ-45 die.
Wire stripper
Wire cutter
RJ-45 plugs
Cat-5 UTP cable
Optional Tools
Wire Tester
Procedure
1. Strip off insulation
2. Untangle wires
3. Place wires in correct order &
straighten.
4. Trim wires to desired length.
Note:
If the wires are too long the plug will not
crimp onto the insulation for strength.
5. Slide wires all the way into the plug.
Make sure not to disrupt the color
scheme.
6. Crimp plug.
7. Repeat steps 1-6 for the other end.
8. Test wire using optional test equipment
or between working computer and hub
for patch (straight through) cables ,or
between switches for crossover cables.
Wire Color Scheme
Pin Color Diagram
1. Orange / White
2. Orange
3. Green / White
4. Blue
5. Blue / White
6. Green
7. Brown / White
Patch Cable
(Straight Through)
Both ends follow this
format.
8. Brown
Pin Color Diagram
1. Green / White
2. Green
3. Orange / White
4. Blue
5. Blue / White
6. Orange
7. Brown / White
Crossover Cable
One end as a patch cable
and the other as follows
8. Brown
on Dec 08, 2009 | Computers & Internet
Havc thermostats
I will assume you did not write down what color wire you took of each letter on old thermostat? Sometimes color of wire doesn't matter as some installers will use whatever color. If you noted where each wire was on old thermostat, just put same color wire to same letter on new one. Under normal situation. y is for compressor (cool) G, is for fan (on AC) , RC is 24 volts from transformer for AC side, RH is 24 volt transformer from heat/furnace, and W is for other wire from furnace, is furnace is only 2 wire system. Was there any wire connected to A on old thermostat?
Apr 11, 2012 | Heating & Cooling
Panduit mini-com tx6 cjs688tgy how can punch cable and what is the color coding
The colours refer to the (usually) colored pairs of wire in a Cat5, 6 or 7 cable. There are two schemes called 568A and 568B, where some wire are different. Since these jacks are used for permanent wiring, you can choose one of the schemes and use it at both sides of the cable. Watch out if someone has already installed network-cables in the same building and use the same scheme!
You dont need to "punch" the wires. This old method (LSA+) is not good enough, if you have very high bitrates, like we use today. Go to the panduit-website and download a data-sheet of your jack - it should include wiring directions.
hth, Karl
Oct 18, 2011 | Panduit Mini-Com TX-6 Plus (cj688tpor)
I have a 1993 wild-wood RV and there is no thermostat for the ac. Ac and Heat are separate. It has a plug sticking out of the wall. the plug has 6 colored wires with black plug. How do I find a thermostat...
I would suggest going to an RV place of business to get one. The stat should or will be like a home stat, if I knew the wire colors I could walk you through wiring it up.Normally, only 4 to 5 wires are used. Red would be hot, white heat, green, for the fan, yellow for cool. You are going to need a voltage meter and some help to check for power at these wires. Being a RV, it might be 12 volts. Could be wired for 24 volts ac when you plug the master cord in. I would need more information from you to solve this.
Shastalaker7
Sep 29, 2011 | Dometic Rooftop RV Air Conditioner
My iphone suddenly changed colors. The pictures all look like b/w negatives. The icons are really weird colors. Help. Thank you.
Hello Michel,
In the iphone 3GS there is hidden feature called the "White on Black". It completely inverts the color scheme of your iPhone. The background on the home screen will be white, and the text will be black.All of your native apps will have an inverted color scheme. to disable this feature, Go to Settings then General then Accessibility then Turn of White on Black.wirelessage.jpg
May 19, 2011 | Apple iPhone 3G
Need color scheme identifying wire colors and use
Have you tried auto electrician or autobarn car audio dept but a store that does installs on site??
They are very knowledgeable & could more than likely write it out for u if they not flat out which is mainly on weekends
May 03, 2009 | Car Audio & Video
Softwares and colour schemes
i have to new color scheme to on my motoroker E6 smart phone.
I am board to inbild color scheme
Jun 05, 2008 | Motorola Mobility ROKR E6 Smartphone
Dubbing home videos to pioneer dvdr-rw
Should be just as simple as plugging in the RCA jacks from the output of the VCR to the input of the DVD recorder. Make sure you pass the first grade color scheme and match the colors up! Yellow to yellow....red to red.....white to white...you get the idea.
Mar 13, 2008 | Televison & Video
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
