Question about Ovens
I have whirlpool magicook 22gsi model please tell me how to use baking n convection system.
2 Suggested Answers
Macmarkus
  • 2605 Answers
SOURCE: I have a Thermador electric
Welcome to FixYa.
You have not mentioned if the oven has displayed any error code so I will take that for what it is...there was none shown.
With that, I`d start by looking for an overtemp cut-out tripped. Did this problem start following a self clean cycle ?
Here`s what and where to look for for this,
Fortunately if it is tripped, they are the manual reset type and are accessible behind the black grill/vent just above the door and just below the control panel next to the lock latch assembly.
**Turn off the 40amp breaker at your service panel or sub-panel in the home before attempting any service...safety first**
With the power off, you should be able to remove the grill and push the red button in the center of the thermostat and that should fix your problem...if indeed the hi-limit is tripped you`ll know immediately because you`ll feel it click as you push it down. It will look like the image below...
Ultimately it could be a faulty relay board or related to the timer, but I`d start with the hi-limit cut-out tripped first.
If you feel capable of repairing this yourself I can send you a complete service manual in a "pdf" attachment, however you`d need to provide an email address to where I could send it to you.
Other than that if you call in a pro just be sure they are an authorized B/S/H/ service provider ( B/S/H/ is the parent company for Bosch, Thermador, Gaggenau, Siemens products ).
Let me know and I`ll watch for your reply and respond as soon as I can.
macmarkus :)
Posted on Aug 05, 2010
Whirlpool model YGFE461LBQ1. When I press bake, or convection it says service not available
Hello. There is a thermal fuse located at the rear of the oven, underneath the rear cover. The part number for it is 3196548. If the bake element isn't working, this thermal fuse may have opened. Did you self-clean the oven recently? That is a notorious cause of popped thermal fuses due to lack of adequate ventilation. I hope this helps you!
Aug 26, 2015 | Whirlpool Ovens
I have a double whirlpool fan oven. The fan doesn't always work, seems to stick. What do I need to do to get it working? We've had it less than 3 years but I've never cleaned it. Is this why it doesn't...
Do you mean the fan inside the oven box in the back wall. This is the fan for the Convection bake etc. If so this is how it works..
a) Bake feature - that fan does not come on
b) Convection bake - that fan comes on during bake cycle
So that fan works for several features but not for all. It helps to circulate the hot air inside better for a more even, fast bake.
Do you mean the fan in the control board area. It is there to get the hot air trapped in the oven walls out. Not the heat inside the oven bake box area. This fan works differently depending the model and/or brand. Some models fan works from the time you start. Some models fan comes on only when that area reaches a certain high temperature.
Mar 01, 2015 | Whirlpool Ovens
Instructions for a ignis electric oven as there is no temperature guide or modes on front of oven
I don't see what looks like your model anywhere, or a manual for any model, or a company website, so if no one can help you try this.
The left dial could be- bake, broil, fan, convection cook, now the bottom pan should come out so you can see the bake element.
Turn it one setting and see what happens, either broil (top),,, bake (bottom), convection fan (bottom), turn and wait to see what happens.
Right should be temp, not sure if the dial has a stop or you can spin, but it at 12:00, put at 6:00 I say this maybe 300deg F.
Get over temp gauge (cheap).
If you don't get any help, then you need to try and see what does what and mark it down.
If you can't see top burn, maybe top pan come out so you can see it.
They get red hot, so you can tell which one turn on.
Sorry, can't find any info.
Apr 01, 2013 | Ovens
I have an bajaj oven and im trying to bake a cake and everthg i bake it the sides of the cake get baked and the middle portion remains raw..ive tried all the up flame,down flame and also both the up and...
if your oven is gas its is very difficult to make perfect baking of of the uneven heating,if your oven is elecric is with convection that one good compare to gas oven on an electric oven without convection, the advantage of oven the with convection is even heating.
Dec 24, 2010 | Ovens
My whirlpool range model#rf114px513 started
You will need to press the stop /cancel button this will clear the display
Nov 15, 2009 | Ovens
How do I use this oven? Is it working correctly?
It would seem that the oven is small enough that a fan to flow the heat from the unit would be in use for both convection and bake modes. Usually convection ovens will have a "burst" of fan action during the bake process and it is not a steady fanning of the air that would dry out your cookies, ect. I have a small oven / microwave and my larger oven is a GE that has the "burst" convection that I described. Might not be that much help, but it's hard without more info on your unit. sometimes the model is behind the oven door.
Nov 04, 2009 | Jenn-Air Ovens
Ge profile oven/convection oven humming when on convection settin
ensure that your convection fan is turning
a hum on this model usualy means that the convection motor can seize up a bit
sometimes all you need to do is redjust the fan blade
Oct 13, 2009 | Ovens
Bought oven second hand so no model no. it is a dual belling range with fan. the oven heats up but the fan has stopped working! single parent who hasnt a clue, please help!!!!!
most model numbers are located around the frame of the stove, inside the drawer area or on the oven door, call the manufacturer, most have a toll free number. Check to see if the fuses are okay first, if one is out, that could weaken the system. The fan is probably convection, and your controls will have a convection feature. If the fan has ceased to work, just use the regular bake mode.
Sep 03, 2009 | Belling Ovens
Dont know how to use
Many ranges now have automatic conversion when you use convection feature instead of standard bake, but as a general rule, if your standard baking time in the recipe is over 30 minutes, you can lower the convection setting by 25 degrees F and reduce the time by 25% to get the same results as standard baking settings. Please don't rate this if you don't feel it is a Fix-Ya for you, as other ratings lower my score. Thanks.
Jan 20, 2009 | Ovens
Amana Convection oven not controlling temp
I have just checked the baking guide in the manual and have found that it may not be us after all. (Maybe this is why they telll us to read the whole manual. Well, I never have) According to the cooking time for Baking, the range is very extensive. For example, an angel cake at 350 could take from 28-50 minutes, buscuits at 375-400 could take 8-16 minutes, layer cakes at 350-375 could take 25-40 minutes, pound cakes at 325-350 could take 45-70 minutes and fresh pies at 400-450 could take 35-60 minutes. Basically, the baking directions on the box means absolutely nothing to use Amana oven owners. We have no choice but to cook our food or baked goods until they are cooked, whenever that may be. :) Linda
Dec 11, 2007 | Amana AOCS3040 Electric Single Oven
Ovens Logo
77 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
