Question about Linksys SLM224G 24-Port Ethernet Switch
SLM224G SYSTEM LED flashes green constantly
SLM224G stuck in the system check at boot (the SYSTEM LED flashes green constantly) holding the reset in doesn't bring it up to factory defaults and I have no idea what IP it's configured for - not that it matters it won't load the firmware anyways.
My question is there a way to force it into a recovery mode? I know with some of the home models of the Linksys (this switch is Linksys) that you can short a pin on the chip and it goes into a mode where you can TFTP firmware and restore that way, my question is there any workaround like that for this model?
Benimur
  • 6966 Answers
SOURCE: Green Power light flashing
Hi, Have you tried a hard reset? Your model has a small reset button at the rear between the Internet/WAN connection and one of the antennas (Press for 10 seconds +). Also flashing power led is an indicator of firmware problem which might have been caused by a failed firmware upgrade/update. Instruction on how to correct this problem is also included in the firmware upgrade/update. A more detailed instruction is in the User Manual. With regards to firmware update/upgrade , pls be reminded that firmware is very version specific. To locate the version number, you have to look underneath the unit and download the appropriate firmware from LinkSys website. (http://www.linksys.com/servlet/Satellite?c=L_CASupport_C2&childpagename=US%2FLayout&cid=1166859878881&packedargs=sku%3D1115416826220&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=7888126220B03&displaypage=download) The download is a zip file which you have to extract to a folder. The .bin file plus instructions as well as specific instructions on how to make the power led stop flashing. Hope this works out for you. Pls post again how things turn up. Good luck and kind regards.
Posted on Jul 28, 2007
devverma143
  • 163 Answers
SOURCE: http access on the slm224g is not working via
May ur nat is supporting secure http try using
https://
Posted on Apr 29, 2010
benjwgarner
  • 5 Answers
SOURCE: how can i reset the linksys ef3116 to default if
You can use a port scanner to find its IP address, such as Angry IP Scanner http://www.angryip.org/w/Download and reset it from there. It is most likely 192.168.1.x or 10.0.0.x.
Posted on Jul 07, 2010
AbhiRay
  • 124 Answers
SOURCE: we have lost the password for Linksys srw2008mp
To reset to factory Default settings you need to do the below steps
1. Look for the reset button. The reset button is a tiny black button on the back of the switch.
2. Power Off the switch.
3. Press the reset button (preferably with help of a ball point pen or a small head scew driver) keep the tiny black button pressed and do not release that.
4. Power On the switch and the sys LED will blink slowly and then rapidly. 5. Now release the black button
6. Wait for 5 minutes. The switch will boot up with factory default settings.
Best Regards
Posted on Nov 15, 2010
SOURCE: My Linksys WAG160N doesn't work,
try 30 ser reset
Posted on Oct 10, 2011
Two of my smoke alarms went off (no fire/smoke in or near house), one has a green light blinking and one has a solid green light, which need a new battery/reset?
The constant green LED means the alarm has AC power.
A flashing green light every 2 seconds without an audible alert means the unit recently sounded ( was the one activated ) and is now in latching mode to let you know that it was the unit that detected the problem. To clear the latching mode hold down the test button for 5 seconds.
Red LED flashing once per minute means that the back-up battery is connected and functioning.
Red light flashing constantly during alarm means that it is the unit that initiated the alarm siren.
Sep 04, 2014 | Cars & Trucks
Timer is on and Tv will not come on
Press the System Reset Button which is on the RHS on control panel
If the TV fails to respond to the remote control, control panel
buttons, or will not power on/off, press the SYSTEM RESET button on the control panel.
The green LED on the front panel will flash quickly for up to one and a half minutes. When the green LED stops flashing, you may turn on the TV. Recent setting changes you made before using SYSTEM RESET may be lost.
If that fails try pressing and holding the menu button for 8 secs
user manual is here:
http://content.abt.com/documents/19051/WD_C-735-736-835-series_om.pdf
Apr 03, 2014 | Mitsubishi WD-60735 Projection Television
On one of our HP DL360 G5 systems every time after soft reboot the server cannot be booted back. This is 100% reproducible also with Cold boot. Can someone help us find what internal component is...
The simplest way is to check Insight Manager. Type localhost:2301 on a web browser locally. Or, servername:2301 for remote access. You need local Administrator password.
Insight is only available if it was set up with a Smart Start disk. It's that pack that comes with all HP servers, but can be downloaded as well. Best practice is always install.
Don' know what IML is, and ILO has no baring to problems.
There is Insight Manager link on specs.
http://h18004.www1.hp.com/products/quickspecs/12476_na/12476_na.html
Nov 12, 2012 | HP ProLiant DL360 G5 Server
My unit indicates a system error due to amber LED was lit whenever I press the power button. I tried to press the remind button in the operator panel but no LED will lit to indicate what maybe the problem....
Interesting, sound like a failure of the button because most system either work with a greeg lit up led or fail with an amber or orange lit or flashing.
In this instance the amber could mean something has gone bad but the fact you can hold the button and have it boot up is strange.
Does the led turn green after holding the button for a while to let the machine boot?
regards,
mike
Oct 19, 2012 | IBM System x3500 (7977F2U) Server
Hi, the lights on my circiut board are flashing the one on the left is on all the time and the one to the right of it flashes two times and then waits and then flashes two times again
Error Codes
A green LED indicates system faults
Steady On: System OK
Steady OFF: Board control fault or no power applied
1 Flash: Ignition failure (control in one-hour lockout)
2 Flashes: Pressure switch fault, fails open (switch is
stuck open)
3 Flashes: Limit switch open (main or auxiliary)
4 Flashes: Pressure switch fault, fails closed (switch is
stuck closed)
A yellow LED indicates flame status
Steady on: Normal flame is sensed
Flashes: As flame weakens, frequency of LED flashes
increases
hope this is helpful.
Dec 21, 2010 | Ruud Central System Air Conditioner
I have a flashing orange light and cant find the manual, I have changed the inks but its still flashing?
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
Dec 02, 2010 | Canon Office Equipment & Supplies
Front right led flashes 3 orange 1 green ,system starts to boot and then goes to a grey screen with curser i upper right corner and just sits there. i can just touch pwr button and computor shuts down
the flashing Orange and Green LED is a terminal battery failure:
http://www.fixya.com/support/r3696096-dell_portable_battery_led_flashes_orange
The system not booting to the hard drive could be a HDD failure or a corrupt operating system. Boot to the XP CD, Press R at the 1st prompt to access recovery console, then run CHKDSK /R
Oct 12, 2010 | Dell Inspiron 5160 Notebook
Screen will not come on hard drive light no light checked power supply is ok
Things to check:
  1. Power led on the front of the tower, it should be solid green when on. Flashing Amber is generally an indication of a bad power supply inside the tower
  2. Power LED Solid AMBER indicates system is not finishing the power on self test (POST) and you remove all connections from the tower except power and try turning on again. If no change, remove all PCI and PCI-E cards from system, try again, no change replace motherboard.
  3. On the back of the tower are 4 diagnostic LEDs near the ps2 ports marked ABCD, after the POST, during a normal boot the will flash in several sequences and with boot is finished all 4 should be green. If they stop an a different pattern, then that indicates a failure Yellow Yellow Green Green indicate bad RAM for example
  4. If the LEDs on front and back are Green then the system appears to be booting but the monitor display is not functional
Feb 05, 2010 | Dell Dimension 4600 PC Desktop
Meaning of rudd furnace trouble codes
Error Codes
stuck open)
stuck closed)
increases
Dec 12, 2009 | Heating & Cooling
Acer Ferrari 3200 won't boot
Try different memory just to be sure its not that and if still no boot then its the motherboard.
Feb 10, 2009 | Dell Inspiron 2200 Notebook
Linksys SLM224G 24-Port Ethernet Switch Logo
126 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
