Question about Thermador SC302T Electric Double Oven
I have a Thermador CM302ZS (double Oven - Microwave/convection on top and convection on bottom). The Microwave no longer works. I tested by placing a cup of water in the microwave and programmed the microwave to heat the water. Water remained cool. Is there a fuse or easy way to fix this?
  • 1314 Answers
SOURCE: Thermador Convection Oven
well im not terribly familer with thermadors wiring but pull the top off and find the tech sheet then look for a device call a thermal fuse or tco thermal cut off most times they are on top or on the back of the oven yours should have one for each oven bet the one for the top is open can happen if there installed in to close a space
Posted on Jan 30, 2008
huuum
  • 750 Answers
SOURCE: Thermador CMT227N
Hello air pro AC,
Welcome
You said, In the microwave mode - immediate clicking noise at start up. Oven, Convect modes work
Oh there are many things to check here.
1.look at the wheel base turning the plate that rotates your food for crumbs or sticking pieces of food.
2.check that the wheels are not worn down.
3.There can be a problem in the bearing, or linkage, or motor that spins the plate!
Do you get a error code?
How old is it ?
huuum
Waiting your response!
Posted on Oct 17, 2008
barkencoa
  • 3463 Answers
SOURCE: The lower door does not close firmly. It seems
There is no provision made for adjustment of springs,
I'm afraid the only solution is to replace both door springs.
Trust this helps solve your priblem.
Posted on Dec 21, 2009
Daniel S
  • 4323 Answers
SOURCE: when trying to use microwave
Hi
The loud buzzing sound is due to a faulty magnetron. Please check part#33 in the diagram---
Before disassembling the microwave please unplug it for one hour to let the current drain. Use a metal screwdriver and touch the both terminals of the voltage capacitor to drain current from the capacitor. You can check the magnetron resistance using multimeter, resistance between filament to chassis should be infinite (will show OL on multimeter, on Rx1000 scale) and filament terminal resistance should be less than 1 ohm (on Rx1 scale). Hope this helps... Please post back if you need more information.
Daniel
Posted on Nov 11, 2010
Macmarkus
  • 2605 Answers
SOURCE: How do I replace the
Welcome to FixYa.
WOW ! An oldie but a goodie. This is when Thermador made the best ovens money could buy, in my opinion.
To replace the roller will require pulling the oven from the wall, likely obvious by now. Since you've indicated you do have the part I'll assume you are confident this is what is worn...these are pretty simple devices with many components is the best way to describe them.
Have a look at this illustration below and see if this will help identify how you may change them and then I can explain what to do without having to describe from afar what goes where and confuse terminology.
I also have a complete folder of your model in a "pdf" if you'd like it. I'd need an email address to send it to though so you'd need to post it here.
I'll watch for your reply and then we can proceed if you need further assistance. Thank you for choosing FixYa and good luck going forward.
Regards,
Macmarkus :)
Posted on Nov 21, 2010
Trying to use self clean feature on my 2009 themador wall oven and E106 code appears?
Are you sure of the error code number? A list that I found only goes from E1 to E15 and F0 thru F9 & also a Fd code. Double check the code and respond back to me and I will see if I can help you further.
Aug 01, 2014 | Thermador Masterpiece MEDMCW71JS 27"...
F5 error code
F5 = EOC electronic control failure replace electronic control is stated in the service manual. If you have any further questions message me them back. Thank you
Rick
Nov 28, 2011 | Thermador SC302T Electric Double Oven
After self cleaning my Thermador double oven, it does not heat up anymore The elements are not working. Is there a fuse, switch or something that I can do or check to make it heat up again.
Never use Self-Cleaning!!! It will fry components, melt connectors, and burn wires. If you have violated this rule and an oven no longer works, it is probably not a bad element if neither the bake nor the broil work. It is likely the high heat cut out breaker.
On a Thermador CT 227 double oven, there is a panel on the right side (facing the unit) that is about 3 inches wide and runs from top to bottom held in place by about 6 or 8 screws. Turn off the power, slide the unit out of the kitchen cabinet, remove the sheet metal panel and you will see two high heat cut out breakers. They have a small red button in the center that resets the breaker. Push firmly and you should hear a click. If there is no click, check the unit for continuity. If it is open and the button push does not reset it, the unit may be fried. These breakers trip with high heat and will prevent both elements in an oven from heating. If the breaker is good, you'll have to test the leads to each element and then trace the dead lead to the problem.
Aug 01, 2010 | Thermador SC272T Electric Double Oven
Bake element does not work during convection cooking
Hello and welcome to Fixya.
I hadn't seen your post prior to today, so perhaps you've had a remedy presented to you already.
If you have not, reply to this post and I can recommend a few test to perform that will determine the issue with your oven.
Off the top it sounds like a possible faulty convection heating element or the K3 relay on the board is defective.
I'll watch for your reply.
Thank's,
macmarkus :)
Jun 07, 2010 | Thermador SC302T Electric Double Oven
The lower door does not close firmly. It seems like the spring load is weak. Is there a way to improve the spring tension? I have model CM302ZS (Microwave/convection oven on top and convection oven on...
Dec 21, 2009 | Thermador SC302T Electric Double Oven
Thermador over/microwave/heating drawer model SMW272YP Bake bottom element will not heat up. I have replaced the element. The display pannel has been replaced in the past, but still keep having the same...
I just found out my baking oven doesn't work and I hear the fan for the convection roast, but no heat. I had the appliance man out and he said that I need a relay board! Big bucks and they don't make this model anymore. Moreover, the microwave and warming drawer work fine. This is ridiculous!
Mar 07, 2009 | Thermador C302U Electric Double Oven
Thermador oven control panel light is not working
Please see post by bonanzsapilot on 14 March 2009; he gives exact & easy to follow directions for making this repair for <$10. It's listed uner 'Thermador SC301IT oven - FixYa'. In a separate post I added the correct capacitor numbers from Newark.com. I made the fix in abt 30 min & it's good as new. Thermador no longer makes control panels for this oven & no wiring diagram is available to help. Shop price was estimated at $500.
Nov 16, 2008 | Thermador SMW272 Electric Double Oven
Jan 30, 2008 | Thermador SC302T Electric Double Oven
Open Questions:
See all Thermador SC302T Electric Double Oven Questions
Thermador SC302T Electric Double Oven Logo
221 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a Thermador Oven Expert? Answer questions, earn points and help others
