Question about Haier HPR09XH7 Portable Air Conditioner
E1 error code HWR08XC-7
E1 error code Haier model# HWR08XC-7
  • 2,133 Answers
Replace indoor room temp sensor.
Posted on Jan 01, 2011
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    My air conditioner showing on the display is E1
    The E1 Error Code The most common reason for an E1 error code to be displayed on your air conditioner's front panel is to remind you that the unit's air filter needs to be cleaned. Many models will automatically notify you of this via an E1 error code display after the unit has been operated for a predetermined number of hours. For example, many Sharp models will display an E1 code after 720 hours of use. Alternatively, you could have dirt or moisture in your front button controls, causing them to stick or not function properly. This can be a common problem with many models of Haier air conditioners, but the issue is not restricted to any one manufacturer. Your air conditioner could also have a defective thermistor, which is part of the thermostat.
    For Samsung, the room thermistor needs replacing. This is a device that senses the temperature in the room.
    How to Fix an Air Conditioner When It Gives You an E1 Code eHow
    Jan 24, 2016 | Heating & Cooling
    Haier air conditioner won't run displaying code e1? Do not have remote.
    This is the error code.
    E1 = Room temperature sensor fault Indoor unit
    Even if u had the remote you still have a bad sensor.
    AC Repair Delray Beach
    Sep 03, 2014 | Haier Heating & Cooling
    Haier service manual
    This is what you error code means.
    Haier Air Conditioner Fault Codes
    AC Repair Tamarac
    Aug 25, 2014 | Haier Esax3186 Energy Star 17,000 Btu...
    My ac is showing an E1 code. what can be done to solve this problem?
    Unfortunately, there's not much you can do. The E1 error code indicates a sensor shutdown. However, you can try turning the unit OFF & unplug it for 15 minute. Then plug it back in and turn it ON. If the electronics reset and reverted back to the original factory setting, you can set the controls as you like.
    If you continue to get the E1 error code,, contact Haier Customer Support 1-877-337-3639.
    Hope this helped you and thanks for choosing FixYa.
    Aug 23, 2011 | Haier ESA3125 Wall/Window Air Conditioner
    Error code E1. Please tell me what E1 refers to.
    Unfortunately. Haier does not have an online manual for your model AC. However, if you contact their Customer Support Dept 1-877-337-363, they can tell you what the code means and supply you with an Owner's Manual for future reference.
    Hope this helped you.
    Jun 28, 2011 | Haier ESA3109 WallWindow Air Conditioner
    Haier washing machine keeps stopping and displaying error code E1
    As said in the question you are haier washing machine keeps stopping and displaying error code E1 this is due to the Error signal due to Pr. Sensor.This problem can be solved by only service Engineer.Thanks for your question.
    Jun 20, 2011 | Washing Machines
    Error code
    Do you still the warranty for this unit? maybe you should contact the company which you bought the unit.
    May 31, 2008 | Haier hwr10xc6 Air Conditioner
    Haier HPR09XH7 Portable Air Conditioner Logo
    290 people viewed this question
    Top Haier Heating & Cooling Experts
    Tom Chichester
    Matt
    Matt
    Level 1 Expert
    Edd
    Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
