Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Red light came on.replaced lamp,lamp lights for 5 sec.replaced ballast,same result.
  • Mitsubishi Master
  • 1,889 Answers
Check your lamp door interlock switch
Posted on Jul 15, 2010
Look at some of the other posts for a similar problem. Check the power PWB for bulging electrolytic capacitors. I had a very similar problem and that fixed the TV problem. Good luck.
Posted on Jul 22, 2010
When all three lights are blinking what do I do?
If the unit uses a ballast for the lamp, it could be that it needs replacement of the ballast.
Aug 25, 2017 | Office Equipment & Supplies
Sony lcd projection tv (kdf-60wf655) Tv lamp turns off after 30 secs then come back on over and over ,Green light is solid when lamp is on and blinks green when the lamp goes off. Only when I turn off the...
The board that call the Ballast board might dead,require replacing.This Ballast board only job are to ignite the tv projection lamp.The tv projection lamp been inside the tv like 1 1/2 or 2 years already?Yes.Tv used it everyday like 4 or 5 hrs daily?Yes,the tv should be replacing it projection lamp too.Tv projection lamp life are ending too.
Jun 10, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
The unit turns on and off every 40 sec. or so. I have turned the unit off and on and I get a red light blicking 5 times on and off. this happened about 4 to 6 mo. ago and it is happening again...
Below info are related to Sony KDF-E60A20 lcd projection tv.
5 times red light blinking indicates problem with lamp drive circuit (ballast supply board) that is not producing high voltage for lamp to generate high bright white light.
Check/ replace ballast supply board in above mode tv to solve this problem.
If you tv model is different, let me know to provide you related info.
Thanks
Jan 17, 2011 | Sony KDF-E60A20 60 in. LCD HDTV
Panasonic projection TV does not turn on.
Power LED flashes orange 1 x 5 secs. = 1 of 3 fans stopped. TEMP LED flashes 1 x 5 secs, = Temperature error. Lamp LED flashes 1 x 5 secs. = lamp ballast error. (check lamp 1st.)
Hope this helps.
Apr 18, 2010 | Televison & Video
Tv has no picture or sound. replaced bulb no help greenlight blinks 79 times. red lights start blinking
Lamp light flashing once every 5 seconds or twice every 5? Twice every 5 seconds,....lamp failure, once every 5 seconds,...ballast or thermal fuse failure. You have a lamp, ballast or thermal fuse problem. The ballasts are a discontinued part and can only be purchased used at approx. $225.00 or rebuilt for around $175.00 less any service charges to diagnois and repair.
Jan 17, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic pt-50lc13 it just will not turn on,but the red light is on and the lamp was replace
Is the lamp indicator light flashing? A new lamp may not solve the problem. The known problem with lamp failures is poor voltage output from the ballast,.. a problem Panasonic refuses to correct and they decided to no longer provide the repair part through their supplier in an attempt to sweep this problem under the rug.
Jan 09, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Red light 5 blinks
your set needs attention by the authorised service - probably the Vertical scan, horizontal scan or the flyback transformer driver circuits have failed.
Jul 12, 2009 | Sony KDS-R50XBR1 50" HDTV
Red stand by light blinking
5 blinks = lamp driver (ballast) failure.
1-468-798-14 for the 610 model
replacement is done from the back of the set, should be straight forward, keep the red ballast wires apart for best results
if a tech replaced the red tube, you have an older tv where 5 blinks is the AKB error meaning your CRTs are getting old.
Nov 17, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Lamp
I have the CP-X275W that did the same thing. The ballast was bad and I fixed it with a $5 switching regulator. The CP-X327 has the identical ballast.
Details:
The High Intensity Discharge Metal Halide lamp suddenly failed to light up. A new lamp was installed and would not light up either. The fan ran and the lamp LED flashed after a few minutes. Voltage to the ballast module was 368VDC. The ballast did not pulse.
Ballast# PS-226-LS-210 was bad. Hitachi Part# HA01101 has been discontinued and the new part number is HA01102. It was $210USD at Vance Baldwin or $221USD at Part Solver.
The FET series (TR1,5,6,7,8,) seemed good: (drain-source resistance=5Kohm). Bought an identical projector on Ebay to do comparative multimeter measurements. Found resistance differences in IC01 (STRG6153). Swapped good part to bad projector, and it worked. This is a 5-pin Sanken brand switching regulator, US$5 at www.electronix.com. They have the STRTG6153, which is compatible, and may be better. The bad one removed from the circuit measures 15Kohm on pin 3 to pin 5 and the same 15Kohm when the probes are reversed. The good one measures 18Mohm and infinite when the probes are reversed.
If you would like me to fix it for you and clean all your optics, I can do it for $150USD plus $25 return shipping. Contact Chris at chris_goulet@yahoo.ca.
If you have a new lamp for sale I would buy one for $100USD.
Good luck.
Dec 22, 2006 | Hitachi CP-X327 Multimedia Projector
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
414 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
