How do i hook up Altec Lansing AVS500 speakers to my computer
  • Mark Kessler May 11, 2010
    Use the color coded wires to physically connect the speakers to the back of your computer, then run the installation disk to install the drivers.
    President:
  • 2,712 Answers
Hello sweetnikki1,
The Altec Lansing AVS500 are 4.1 channel speakers, meaning 4 speakers (front, rear and 2 satellites) and a subwoofer.
1. Make sure the rear and/or center/sub audio cable is plugged in to the correct port. On most surround sound cards, the rear audio port is black, the front audio port is green, and the satellite cords are similarly color coded. The output from the sub to the front right satellite is a heavy-duty cable that immediately stands out from the rest. This cable is thicker because the right front speaker has most of the system controls on it: power, volume, and surround volume. If you do not have a surround sound card, make sure you obtain the proper adapter or use surround sound emulation if your speaker system offers it. If you are not sure if you have a surround sound card, please check with the manufacturer of your sound card for details.
2. Make sure your sound card supports the same amount of channels as your speaker system contains. For 4.1 systems, it should have a front and rear speaker jack on the card. The card should be properly installed and configured. Please contact your sound card manufacturer for details. If you do not have a surround sound capable sound card, on the left side are the sub level control, the AC jack, satellite outs, and a sound mode switch. With this switch you decide between Gaming and Stereo. In Stereo mode, the normal stereo signal is sent to both the fronts and the rears. In Gaming mode, the speakers use the four-channel signal from your soundcard. Hence if you just hav the regular sound card, do not connect the satellite speakers and use Stereo mode.
3. You can also use an adapter to split the signal for the front and rear speakers. This type of adapter is a 3.5mm male to 2-3.5mm female jacks. You can purchase this adapter at your local electronic store. Please refer to your manual if you do not know if your speaker system can emulate surround sound.
Hope this helps..
Should you have any further questions, please feel free to post them here. Please do not assign a rating until you feel your problem is resolved. I will try my best to help you further, if need be.
If you are satisfied with my solution or have no other questions, please close the problem by assigning a FixYa! rating for my solution. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Apr 20, 2008
  • 1 more comment
  • Swilin Sampson
    Swilin Sampson Apr 23, 2008
    Have you been able to resolve your problem? If you have,
    please close this problem ticket with a Helpful or FixYa! rating. I would be
    very grateful for your gesture of appreciation.
    post them here.
    Cheers!
    IrishDruid
    "Discover
    How to Achieve Your WILDEST DREAMS"...
    Free Download
    FREE SOFTWARE GIVEAWAY
    Windows Utilities
  • Swilin Sampson
    Swilin Sampson May 03, 2008
    Just wanted to inquire if your issue is resolved, or if there is anything
    further I can do to assist you…
    If you find that the solution/answer I provided led you
    to, or resulted in a fix, please take a moment to close the ticket with a FixYa!
    rating under my solution.
    post them here.
    Cheers!
    IrishDruid
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    P.S. -You can rate this solution with one of
    four votes, if you feel your issue is resolved.
    • "FixYa!"
      - The solution provides great advice on how to solve the problem.
      (Positive Rating)
    • "Helpful"
      - The solution provides useful leads that helps solve the problem.
      (Positive Rating)
    • "Thanks
      for Trying
      " - The solution does not solve the problem but the
      effort is appreciated. (Negative Rating)
    • "Inappropriate"
      - The solution has absolutely nothing to do with the problem.
      (Negative
      Rating)
    If your issue is not still not resolved, do not
    assign a rating just yet. Please post back as to what steps you took, results,
    etc, and I will try to assist you further as best I can.
    IrishDruid
When power supply pluged in the wolfer makes loud noise
Try turning the volume down on your computer or on the woofer itself.
Nov 26, 2009 | Altec Lansing AVS 500 Computer Speakers
Altec avs500 speaker sound in 2 speaker only and not the rest
Try making sure the surround sounds knob is turned all the way to the right and that the switch on the subwoofer is on stereo and not gaming.
Mar 13, 2009 | Altec Lansing AVS 500 Computer Speakers
Power supply AVS500-A6860 fried
This one might work, but I'm not 100% sure on the connector:
http://cgi.ebay.com/AULT-041-0001-001-18VDC-1111MA-AC-ADAPTER_W0QQitemZ6741610952QQihZ002QQcategoryZ101265QQtcZphotoQQcmdZViewItemQQ_trksidZp1742.m153.l1262
Feb 16, 2009 | Altec Lansing AVS 500 Computer Speakers
I have altec lansing speakers AVS500 and have no sound
It sounds like the subwoofer speaker has blown. If you are comfortable working with a soldering iron and speakers then you can open the case and replace the speaker with a replacement subwoofer speaker. A good online store for replacement speakers is PartsExpress.com
Dec 28, 2008 | Altec Lansing AVS 500 Computer Speakers
I'vebeen given an Altec Lansing Spealer system, AVS500, for a computer, but it is missing a power supply; 18 volts DC and 1 amp. Altec Lansing no longer make that series or its components Any...
lost instructions on how to hook up. Large speaker makes static. Right speakers work great.
All colors match but can not find the proper jack for the black wire coming out of large speaker
I suspect this is the problem
Oct 17, 2008 | Altec Lansing AVS 500 Computer Speakers
Altec Lansing Altec AVS 500
If you are using windows media player check if your player is configured to have an echo. If it is configured remove it. If it is not configured to have an echo and if you are using any soundcard have that sound card check by an expert or by your vendor and let them check it out if it is still under warranty.
Jun 24, 2008 | Altec Lansing AVS 500 Computer Speakers
Altec Lansing computer speakers model AVS500
18VDC 1000mA Center Positive.
Altec-Lansing
Part Number: AVS500-A6860
Model Number: 9701-00648-1UND
Jun 02, 2008 | Altec Lansing AVS 500 Computer Speakers
AVS500 altec lansing speakers
Here is the link to the product manual. Hope this helps. :}
http://www.altecmm.com/downloads/LAT/AVS500B%20manual.pdf
There is a wiring diagram in it.
Nov 23, 2007 | Altec Lansing 621 Computer Speakers
AVS500 altec lansing computer speaker system powered subwoofer
Its due to your speaker power supply failure or switch! get them checked your speakers will be ready!
Nov 02, 2007 | Altec Lansing 621 Computer Speakers
Computers & Internet Logo
211 people viewed this question
David Payne
David Payne
