Question about Dryers
Dryer works fine but we have no heat.Have check the gas line all is good. see no flame.?
  • sonyandtom Jul 16, 2010
    Kenmore dryer model #11078712895 has no heat have checked the gas from the house have checked house breakers.All is good.Dryer starts and stops fine with the new timer we installed but still no heat.Is the thermal fuse i see in the diagram part of the heating. Or should i look 2 the ignitor or gas valve?
    Thanks for the help this gives me some areas 2 check
    President:
  • 1,891 Answers
Most dryers use a ignitor and when heat is called for you can see a glow form it next to the where the flame would be / if no glow no heat .. other causes are hi limit thermo on top of the heater . if you find this bad you need to ck the air flow of system as you may have a pluged vent .. most need cleaning anyway . other device is a one time saftey and if its bad there is a fault in air flow like the fan or pluged vent .now if the glow fromthe ignitor is working and when it goes out the flame does not light then the coils on the valve have failed .. hope some of these helped mm
Posted on Jul 16, 2010
  • 10,319 Answers
If gas fired check the spark ignitor. If no click is heard upon starting the ignitor is at fault. If electric the relay may have gone bad for the timer
Posted on Jul 15, 2010
  • sonyandtom Jul 15, 2010
    The timer unit stopped working at the same time the heat stopped.So we replaced the timer assemble now the timmer works and shuts off the dryer but no heat. You said listen for a clicking noise if not it may be the ignitor?
    On the dryer it has gas from the wall. Tried to lite with a match seems there is no gas to fire. Would the ignitor control the gas valve or is the gas valve a stand alone unit.Like I said earlier the timer is new. is there a thermal fuse that runs the gas Valve?
Ge gas dryer heats but doesnt dry
if the flame is lighting you have lint blocking the air flow either in the dryer or in the vent line,also if you have a flame for the first 10 to 20 minutes and then the flame doesn't light you have bad gas coils located on top of the gas valve,when the coils are bad they can work for the first 10 to 20 minutes until the coils get hot and then they fail and you'll see the ignitor glowing orange but no flame,bad gas coils.then when the coils cool down they can work again.hope this helps.you can try removing the vent line from the back of the dryer and see if the flame stays on,if lint is blocking the air from blowing out the flame won't stay lit long enough to dry the clothes.
Dec 01, 2013 | Kenmore 73952 Gas Dryer
I have a Maytag Neptune model number MDG9700A gas dryer...When I first turn the dryer on the dryer will get hot for about minute then the gas turns off and will not heat up again...It glows fine after...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 01, 2011 | Maytag Neptune MDG9700A Gas Dryer
Gas dryer not heating checked thermo fuse ignighter both good
Than its going to be in your heat coil/ valves and your flame sensor. The flame sensor is a rectangle box on the flame tube. Your heater coils are on the gas valve they are two round silinoids one with two pins to it and one wwith three. Follow the gas line to the gas valve on the gas valve you will see two quick connects that run to it. There is one screw and the plate cover will come off to give you access to the heater coils.
If you have anymore question please comment me back
Jul 31, 2011 | Roper RGX4634KQ Gas Dryer
No Heat - Maytag Dryer - Model# SDG3606AWW - Gas Line OK - Clear Vent - Do not see any flame after removing front panel. Igniter glows but then cools down no flame
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 10, 2010 | Dryers
My maytag dryer is taking more time than usual to dry up clothing. Can anyone help identifying the problem and possible solution? Thank
you have to clean out the dryer and the vent line,unplug the dryer,remove the lint filter and then you need to remove and clean out the duct that the filter slides into,then vac out the cabinet where the motor is,go outside and check the vent,make sure it's clear,then remove the vent line from the back of the dryer,if it's a long vent line i use a leaf blower to blow out the line.also if you have a gas dryer,check it after 15 to 30 minutes to make sure the flame is still igniting,if the gas coils are bad they will fail when they heat up,when they heat up the flame doesn't lite until the coils cool down and your clothes will be warm but wet.you should clean the dryer once a year if it's gas and once every two years if it's electric,gas dryers have an open flame and the lint can catch fire easier than electric dryers,do this and your clothes will dry on time,no fires,save energy and money on your bill.good luck
Oct 10, 2010 | Maytag Dryers
GAS LG DRYER TUMBLES BUT DOES NOT HEAT, WHAT COULD BE WRONG? CHECKED THE BREAKER AND GAS LINE, BOTH ARE ON AND GOOD.
Pilot light (flame) may have gone out..Dont know if you are on gas bottle or mains,if on bottle make sure not empty..most likely Pilot Light (flame).cheers
May 28, 2010 | LG DLG5932W Gas Dryer
No heat, no flame, temperature based high heat
if the dryer doesn't shut off you need a new timer. have you replaced the igniter or glow coil? it needs to glow white not orange in order to ignite the gas.
Oct 11, 2009 | Whirlpool LGR5636PQ Gas Dryer
Gas dryer heat is intermediate
does the igniter glow white or orange? if it is orange you need to replace it. has to be white hot to ignite. if the igniter is white it could be the coils not opening the gas valve all the time - an intermittent problem.
Oct 04, 2009 | Kenmore 73952 Gas Dryer
I have a gas Gas dryer with low heat. The igniter is good, the gas valve opens and I get a flame, but it never heats up past 89 degrees. I'm guessing there is a secondary gas valve or something that kicks...
if the vent line is blocked or lint is built up in the duct where the lint filter slides into the flame will only stay on for like 5 to 10 seconds or the gas coils are bad,when the coils are starting to fail you'll have heat for the first 10 to 15 minutes and then no heat,when the coils cool down they will work again,these are the two most common problems with a gas dryer,try removing the vent line from the back of dryer and run it to see if it heats any better if so you have a block in the vent line.or run the dryer for 15 minutes and look at the flame and see if it still ignites,if not the coils are bad.next time send the brand name and model number off of the dryer,open the door look around the opening where you put the clothes in and you'll see the model number good luck.if those two things check good you could have a bad cycling thermostat located on the blower wheel housing but i would check for a block in the pipe or lint filter duct.
Nov 29, 2017 | Maytag Neptune MDG5500AW Gas Dryer
Intermitten Heat up
make sure that your vent is not plug up can you go outside your house and feel good air coming out the vent when the dryer is turn on if so the only other things it could be is the coils that sit on the ignotor assmebly or the high limit termistat is not working properly the coils are little black circle coils that sit in the ignitor assmly should have a metal braket across the top of them holding them in you can check resistance on these coils if you have an meter
Mar 22, 2008 | Kenmore 72802 Gas Dryer
Dryers Logo
Top Dryers Experts
Marvin
Marvin
