Question about Ruud UBHC Air Conditioner
I have a RUDD Achiever 11. The outside fan only intermittently runs and seems to quit in the evening (overtime for the air condo techs). It won't start again until the morning but when it runs, it blows nice, cold air. The HVAC unit in the attic runs fine and responds with the thermostat controls. It seems to have a mind of its own. Help!
    Scholar:
  • 39 Answers
Two possible problems here.
1. you have a bad condenser fan motor. average cost $140.00 for the part plus installation if you can't do it. just buy the motor you most likely will be able to use the existing fan blades.
2. you have a bad run capacitor on that fan. avg cost $5.00 - $35.00 plus installation
In my opinion if you're handy and safe with electicity save some money, if not have it done.
check out grainger.com for the parts they're very reasonable. for the fan you'll need to get specs from the defective unit like amp. voltage rpm. its all on the unit itself. for the run capacitor you'll need the same. all the info u need is on the parts. search the site for run capacitor or condenser fan motor.
good luck hope this helps
Posted on Jul 16, 2010
  • finsterfart Sep 07, 2010
    very helpful!!!
    Where is capacitor located?
When air handling unit stops it would make a shuddering sound.Now it won't run at all. Outside fan is working Tried to run just fan on the thermostat still will not run .It is a RUDD model...
hi,
The indoor blower squirrel cage or the motor went bad....
Open up the air handler and check the blower... you will find the problem right there...
heatman101
Aug 21, 2011 | Ruud Heating & Cooling
I have a Rudd Achiever 10 . The unit was working yesterday morning, it stopped in the afternoon , and is still not working. The fan in the unit in the basement is working fine. Do you think it could just...
you will need to check you condenser unit(the outside unit) here is a website that may help,Tim:
http://www.air-conditioning-and-refrigeration-guide.com/air-conditioning-troubleshooting.html
May 30, 2011 | Ruud UBHC Air Conditioner
Rudd Achiever series model RQNJ-AO42JK 000 mfg
Turn the thermostat as low as it will go and have someone stand out side, they should here the condensor fan and compressor come on at the same time. They are two distinctive sounds so you should
be able to tell if the compressor is running.
If nothing happens and you are skilled with electrical
you can turn power off and remove the electrical
cover to the outside unit. Restore power and carefully
push in the contactor, if the fan and compressor
starts you have a thermostat or low voltage problem.
If just the outdoor fan runs on any attempt, more than likely you need a new capacitor.
Jun 18, 2010 | Ruud Central System Air Conditioner
I have a Rudd Achiever 14 and I want to know if
Take the front panel off the air handler and look for a heat element. You should notice controls and relays with larger wiring to it. It may not have any heat but you can add it.
Jan 05, 2010 | Ruud Handler Air Conditioner
Hello, I have a 1.5 ton rudd ac/heat pump
Your outside unit is not defrosting. You need to call a service tech to check it out. Defrost board sensor or low on gas. Also you amy have an outside tstat that is not working correctly. Rus
Dec 06, 2009 | Ruud UAMB042 Air Conditioner
I have a RUUD Achiever 11 and the outside fan does not come on, and house won't cool. Was told I need a condenser unit. Perhaps I'm overly skeptical, but wouldn't replacing the fan be an easier (and less...
depends on the condition of the unit and if the condenser fan motor is the only problem?
whoever told you that you need a condenser he or she needs to tell you why and point out the issues with what you have seems to me.
to answer your question it would be yes to the fan motor vs.condenser
Jul 05, 2009 | Ruud UBHC Air Conditioner
Replace Rudd Achiever 10 ???
if the fan motor outside let go it could overheat the compressor which he should have known before he replaced the motor. also there is no way of knowing if there is enough freon in the system if the compressor does not start,your best bet is to get another repairman as a second opinion
May 12, 2009 | Ruud UBHC Air Conditioner
Ruud Achiever 10 heat pump - outside fan won't shut off
Definately get this checked out. Some thing has shorted just enough to let voltage "Feed back" and keep the fan running. Could be capacitor, wires rubbed through each other, etc. A reset is a safety that is used when there is an overcurrent or over pressure situation. No reset set for this situation.
There is always an outside chance that if you touch the unit while standing on wet ground, you may get shocked. I firmly believe that something is allowing power to the fan in a feedback condition so don't let this go as it may cause damage to other parts.
Good Luck and let me know how you make out on this.
May 11, 2009 | Ruud UBHC Air Conditioner
RUDD A/C not running, only fan
ok it unit is a central I'm suspecting a voltage transformer is defective you see these units need 24v to turn on certain components but if your air handler turns on, your getting 24v to the fan relay, the problem would be elsewhere. if your handy with a volt meter open the thermostat(if applicable) put the meter on ac volts and measure to see if there's 24v between the R and Y terminals
if so your cooling contactor is defective. (If you get 24 v and unit outside dosen't turn on) if there isn't some fuse on the air handler control board blew out.
you can e-mail me @ hvac.tech7872pr@gmail.com if you need more info
Jun 16, 2008 | Ruud Heating & Cooling
Ruud UBHC Air Conditioner Logo
287 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
