Question about Dell Studio 1535 Notebook
Dell studio laptop won't boot - alll 3 sound leds flashing. What do flashing sound lights mean - is there a way to lookup as an error code?
  • 305 Answers
It seems u have got into a hardware failure or physical ram prob
Posted on Jul 15, 2010
  • cspcrepair Sep 19, 2010
    I had the exact same problem with a customer's laptop studio 1535..
    But it seems that after I removed the battery and power plug, and held the power button for 10 seconds. Then leaving the battery out I removed the back panel. Noted that the back panel was large and very easy to remove.
    I removed the CMOS battery (Looks like a quarter) from the clips. Pressed and held the power button again for 10 seconds. Placed the battery back into the slot. Replaced the cover. Put the Notebook battery back in. Plugged in the power. And WALLA, It worked. Still had to go into the F2 or bios setup options to reset the time and date. But it solved the problem.
What is Flash-Off-On error code?
those are the LED ERROR CODES
page 22 on the manual
states the error codes click on this link to go to the manual
click here to go to manual Product Support Dell US
click here
  • PDF (7682 KB)
  • page 22
Aug 01, 2014 | Dell Latitude E5410 Notebook Pc
Replacement motherboard not rebooting
If you did not change the CPU the the BIOS is not seeing it correctly. You can update the BIOS or you should be able to press F1 to continue to boot.
Apr 09, 2014 | Dell Studio 17 (1749) Laptop black -...
My dell inspiron mini 10 won't boot.There is just a flash of white light then a flash of amber light when I press the power button. That's it, nothing else.
Remove the main battery and try again, also! the power adapter charger should be checked for correct voltage, if okay! pull one stick of ram and test, and the second piece not forgetting to put the first one back and power up, if all this fails you will need to get it assessed.
Mar 25, 2012 | Dell Inspiron Mini Netbooks
What does diagnostic lights mean in dell studio 1535? How do I understand what the problem is by looking at the flashing lights? For instance, what is the problem if mute and volume up lights are blinking...
I have seen questions about the diagnostic codes (volume/mute LEDs) on Dell Studio 1735 1737 laptops where the Mute and Volume up lights stay on while the Volume down Blinks. So far as I can tell, by searching the web, no one has posted the meaning of these lights.
Well here is a link to tell what the light codes mean. If your system has power but is not performing a POST just check if the mute, volume up, and volume down multimedia buttons are lit in a sequence indicating a system problem.
Here is the wesite to explain those POST failure codes.......
http://www.techmonsters.com/DellTraining/bin/Foundation2010/Portables_Foundation_2010/Studio/Studio_1737/1737/general_ts.htm
Dec 08, 2011 | Dell Computers & Internet
Hp dv5020us won't boot. upon power up I get some brief hard drive activity and fan noise. No blinking LED error codes. Caps and/or Num lock LED's do not light. Power LED will glow and HD...
step one, big battery out? skipped that?
step 2, a good power pack , that means 19vdc on those 2 pins.
bingo BIOS screen now work ,yes?
step 3, try an external VGA screen at the P15 VGA jack there
screens work now (BIOS first) yes/no?
remove DVD, drive
and all USB devices
there booting with only 1 memory stick. (got more?, try each 1 by 1)
black screens of *****'.
the lack of flash codes, Implies Power pack is dead. or CPU overheated, and selfshuts down. that fan going dead tells
me the power park is dead.
http://pcdied.com/#black-screens
May 01, 2017 | HP Pavilion dv5020us Notebook
My dell studio 1555 slipped off my nighstand while it was on. i caught it but it hit the nightstand. immediately i started to hear a faint beep sound mid laptop to thr leftside. i shut down and tried to...
unfortunetly sometimes with a fall of that nature you could have very possibly damaged the actual hard drive which if that is the case would require replacement of the drive.
Apr 10, 2011 | Dell Studio 15 Laptop
Error 2000-0142
Hi there!
The error code you have there means that the Drive Self Test failed. You can try to power down computer, disconnect and reconnect hard drive from the system board. Run the diagnostics , if no error occurs then it's a cable/connector issue, if it failed with the same error, replace you hard drive,
Hope this helps!
May 30, 2010 | Dell Inspiron 1525 Laptop
Doesn't turn on, Mute and 2 volume lights constantly flashing
Your Pc motherboard is faulty, have a system engr look at it for possible reapirs." it won't boot ecept it is work on. Good luck
Feb 07, 2009 | Dell Computers & Internet
Dell Studio 1535 Notebook Logo
2,033 people viewed this question
Clive
Clive
Alun Cox
