Question about Samsung SyncMaster 914V 19" Flat Panel LCD Monitor
Samsung SyncMaster 914v monitor - blank completely pink screen
I have a Samsung SyncMaster 914v monitor attached to my laptop. I'm trying to view some video footage downloaded from a surveillance camera. The video file is from a proprietary software and has an mp4 extension. The monitor shows the video as completely pink (no picture) but the laptop shows the video fine. But - the laptop is stored under the desk and I can't view the footage on it without changing my whole setup, which I don't want to do if the fix is easy. I've been able to view these videos on this monitor before, although it's been a few months since I tried. The monitor doesn't seem to be dying. What is going on?
    President:
  • 567 Answers
Hi you need to check the cable that connect the monitor to the laptop for bent or broken pin
Posted on Jul 15, 2010
  • Hilton Bristol Jul 15, 2010
    you can do this by checking the part that connect to the laptop,usually when any pin is bend or broken or the cable is faulty this problem occur you will have to replace the VGA cable after a while parts usually go bad.
Pink and Green Horizontal lines across screen
Normally, horizontal lines on an LCD or LED monitor indicate a bad control board inside the monitor. However, occasionally the problem can be caused by loose or bad cable connections. The only things that you can really do is to disconnect both ends of the monitor cable and reconnect them firmly. Also, you can disconnect the monitor cable completely and just leave the power cable. With only the power cable attached, you can turn the monitor on and off. The monitor should have a "startup screen" or display a message that says something like "Video Cable Disconnected". If the green and pink lines are still present without your computer connected, then the monitor has gone bad. The good news is that Samsung SyncMaster monitors usually carry a 3 year warranty, whereas most monitors only have a 1 year warranty. You may be able to have the monitor replaced at no cost to you if it's less than 3 years old.
Jul 27, 2013 | Samsung SyncMaster Computers & Internet
Samsung Syncmaster 204bw has a red screen
A red or pink tint to the screen indicates that the back light bulbs are failing and are about to burn out. Its time to look for a new monitor.
Mar 17, 2012 | Samsung SyncMaster 204BW LCD Monitor
What adaptor do i need to connect a new Mac Mini with HDMI input to an older SyncMaster 914v?
I assume you mean HDMI output. You'd need a 'HDMI Female to VGA Male' adapter or a 'HDMI Male to VGA Male' cable.
Such as:
http://www.sourcingmap.com/17m-golden-plated-hdmi-vga-male-adapter-converter-cable-p-61779.html?currency=GBP&utm_source=google&utm_medium=froogle&utm_campaign=ukfroogle
I've no idea if that site is reputable or not, just did a search on Google.
Jan 20, 2011 | Samsung SyncMaster 914V 19" Flat Panel LCD...
Green power light is on....flashes lowly......black screen
It is a hardware problem so pls checked it from service center.
Oct 14, 2010 | Samsung SyncMaster 914V 19" LCD Monitor
Samsung syncmaster 914v monitor problem. Right side of display is darker image. Can see dots like a newspaper print or looking through a screen. When display is black it almost appears like an image is...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 15, 2010 | Samsung SyncMaster 914V 19" LCD Monitor
Samsung syncmaster 914v monitor problem. right side of display is darker image. can see dots like a newspaper print or looking through a screen. when display is black it almost appears like an image is...
This is likely the LCD panel itself - you are describing a left/right image error that can be only created by the left/right division by the LCD driver wrapped around the outside of the LCD panel.
If your monitor uses a separate circuit board to drive the LCD, it could be this driver board.
Either way, it will require an LCD panel - $$$
Mar 29, 2010 | Samsung SyncMaster 914V 19" LCD Monitor
My samsung syncmaster 914v isnt working when i plug it in and turn it on all it does is flicker every like 10 seconds
Ok, a few basic things to check/try.
  1. What colour is the power LED, does it change when the screen flickers?
  2. Is the power cable firmly seated.
  3. Is the monitor cable firmly seated.
  4. Try another power lead.
  5. Take a look at the plugs on the monitor lead, does it look like there are any bent/broken pins.
  6. Again, try another monitor lead.
  7. Try connecting the monitor to another pc.
If none of these have any effect, you'll need to take it in somewhere to get it looked at.
Feb 25, 2010 | Samsung SyncMaster 914V 19" Flat Panel LCD...
Samsung 914v 19" LCD pixels went out
hi,
your lcd micron tube in the panel had already worn out.
got to replace the panel
Jan 31, 2010 | Samsung SyncMaster 914V 19" LCD Monitor
Open Questions:
Samsung SyncMaster 914V 19" Flat Panel LCD Monitor Logo
52 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
