Question about Kenmore Elite HE4 Electric Dryer
Has power,insidelight works but nothing on control panel. Worked fine yesterday,had a lot of humidity and now it doesn'work.
  • 1,998 Answers
Hello, ok the bottom panel you can remove and inside that should be a tecnician sheet go through the tech sheet and try to perform the technical testing of the unit it should give you an error code also onthe same sheet it willsay what the problem is coming from another easyier way would be to get a multimeter and perform continuity tests on the hi the lo and the run fuses or relays the three of these relays are located onthe bottom of the unit hope this helps
Posted on Jul 15, 2010
My D-7 will not power up...when turn it on the power light weakly flickers (as well as the power sound) for only sec then nothing. Have cleaned battery connections, used charged batteries and even to
Sounds like electrolytic capacitor dried up needs curing, which is power on capacitor and left it absorb some moisture in humidity on power. Some time a few minutes, hard cases may take a few days.
Feb 08, 2012 | Konica Minolta Cameras
Worked fine yesterday - will not turn on today - kitchen
When you say the machine is dead do you mean you are getting no LED lights at all or do you mean it is not booting up? No power and no post are two different things. With no power you get absolutely nothing at all. With no post you may have some LED lights but nothing comes up on the screen. You said power and power supply tested ok. How are you testing it? I need more info please.
Feb 07, 2010 | IBM ThinkPad T40 2373 Notebook
The sound button on my keyboard doesn't work
Well, reinstalling the drivers would have been my first bet...If you use volume control on your keyboard a lot, maybe pop off the key and check under for dirt/grime?
Oct 16, 2009 | Sony VAIO VGC-JS230J/S PC Desktop
No power to machine - there is power to the plug
I had the same thing happen. I took the top off and realized that the power cord from the factory went out the back.....back in an opening.....across the back but on the inside and out another opening. The part crossing the back on the inside was near the motor and belt and was cut through the hot wire and ground. Someone has to be an idiot to run the wire in the design on the inside.
May 27, 2009 | Kenmore Elite 45986 Front Load Washer
PDW7880G-No power to control panel. Just stopped at the end of drain cycle
Solution Found!!
Checked for power to dishwasher. According to the manual, shutting off the breaker for more that 30 seconds resets the dishwasher. It did!!! The dishwasher works fine now. THANKS!!!
Feb 19, 2008 | GE 24 in. Profile PDW7880G Built-in...
No power to control panel after power surge
1. No power to the dishwasherMake sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
Replace if defective.
3. Timer
Replace if defective (note: uncommon problem).
4. Selector switch
Jan 05, 2008 | Maytag MDB7100AWB Dishwasher
Try turning the curcuit breaker off for a few minutes. Turn it back on and see if it resets itself. If not, the outage may have shorted out the main control panel.
Sep 30, 2007 | Maytag MDB7100AWB Dishwasher
Kenmore Elite HE4 Electric Dryer Logo
448 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
