Question about Harman Kardon AVR 300 Receiver
My avr 300 goes into standby mode and cannot be turn on. How can i turn it on and what causes this things to happen?
Turn OFF avr 300 and unplug the ac power supply and also unplug the speakers terminals,input signal (optical ,coaxial,video1,.etc) after that you turn ON AR 300.
Posted on Sep 10, 2011
  • oran cs
    oran cs Feb 01, 2014
    i did that and still it dont power up and all the fuses ok... you know why?
Avr 745 goes back in standby mode when I try to turn it on
Please see my other answers for Harman Kardon issues. If you can't find them, please respond back here.
Dec 21, 2013 | Harman Multimedia AVR 745 Receiver
Denon AVR-3200 wont go into standby mode
Not sure what you mean by standby mode. The power button on most of the audio remotes I deal with merely turns the equipment on and off.
Nov 24, 2013 | Denon AVR-3200 Receiver
I'm unable to turn ON my harman kardon avr 300 rds which is always in standby mode
It probably needs a new servo switch. I would recommend taking it to a qualified technician for repair.
Sep 10, 2011 | Audio Players & Recorders
Avr 235 power at standby mode but sometime unable to power up, please help. A lot of thanks.
Open the unit and measure the voltage across the reset microswitch on the transformer board (with the unit in standby). It should be a hi signal, over 3 volts. If it is low, below 1 volt (when you can't turn it on) it is sending a constant reset signal to the cpu. Remove the switch and try again. If the problem goes away, the switch was bad. Its a service switch so you don't have to replace it.
Mar 25, 2010 | Harman Kardon AVR 235 Receiver
The receiver turns on and immediately goes to standby
The unit is going into protect mode. Lets hope it has done the job and the receiver has protected itself from failure.
Protect mode can result from speaker wires touching each other or the Amps metal case. Check that first.
It can also be caused by unstable ohm loads if too many speakers are connected to any of the outputs especially zone 2.
If you can remove all speaker wires and turn the unit back on. If it stays on, turn the volume down on the main zone and zone 2 if connected. Then reconnect speaker wires.
Nov 18, 2009 | Denon AVR-5700 Receiver
After turning ON the power/standby switch, the unit(receiver) display comes ON (green light) then after approx.4-5 seconds the display goes OFF and the unit defaults back to the standby mode (red light). I...
Is the red light flashing at first?
The unit may be going into protect mode. Lets hope it has done the job and the receiver has protected itself from failure.
Protect mode can result from speaker wires touching each other or the Amps2_bing.gif metal case. Check that first.
It can also be caused by unstable ohm loads if too many speakers2_bing.gif are connected to any of the outputs especially zone 2.
Nov 16, 2009 | Denon AVR-485 Receiver
Denon AVR 1603 goes to stand by mode
It has a blown channel, unless you are good at repairing them I suggest an authorized Denon service center. This Denon not only needs the shorted output transistors replaced, but a few resistors, a couple of driver transistors and a capacitor on the preamp board as well. alot of parts to be replaced. I have repaired about a hundred of these over the last few years and my shop charges about $200 for this repair, other shops should be about the same.
May 24, 2008 | Denon AVR-1603 Receiver
Stuck on standby
Unit is in protect mode there are a few problems that can trigger protect mode the most common is blown channel (shorted outputs). Sometimes one of the 15v regulators may go bad causing imbalance of supplys triggering protect mode. Also sometimes a bad solder connection could cause unit to go into protect also. I work for Denon authorzied repair center in Michigan if your nearby and Shipping to Michigan is economical let me know kstahl65@att.net
Feb 13, 2008 | Denon AVR-1804 Receiver
Startup
Going into protect due to either blown channel or probably a 15v regulator might be down which I have seen many times also. causing unit to go into protect.
Jan 21, 2008 | Denon AVR-3806 Receiver
Goes into standby mode
press the off/on buttun and keep it pressed in while pressing the standby button... it should fix it
Nov 26, 2007 | Harman Kardon AVR 320 Receiver
Harman Kardon AVR 300 Receiver Logo
508 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
