Question about Samsung SyncMaster 205BW LCD Monitor
Flickering screen When I start my computer, the screen is black, power button is on... After 5 minutes the image appears, then rapidly goes out again... By the time 10 minutes have past since I powered the monitor, the image is flickering very rapidly (on and off), and it makes a squeky noise... the suddenly goes out... if i live it as that for another 5 minutes and then press the power button twice (to power off and back on), the image is flickering again, but then it stabilizes and stays on... what could be the problem...
  • Samsung Master
  • 1,684 Answers
The flickering problem you have is caused by a failing power supply. There are parts called capacitors that are failing and causing the power supply board to put out pulsing voltages until it can stabilize. We have a repair guide posted on our web site at: http://www.ccl-la.com/blog/index.php/samsung-214t-repair/ If you can soldethen you should be able to do the repair yourself. If you don't want to do the repair we offer a repair service for this unit. You can get details for that service here: http://www.ccl-la.com/blog/index.php/service-request-form/
I hope this helps, If so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Posted on Jul 15, 2010
Replaced battery. apple logo appears then disappears. then screen goes black. what now.
When screen goes black two possible problem are display assembly , power supply or battery connection are loosen.
ipad iphone won't turn on blank screen
Here you first remove battery check charging connector of battery 3 copper point which touch with pcb of your iphone. Clean it rub with cotton and insert battery again.
Charge iphone for 20 to 30 minute and power on it.
If this does not work then start your iphone in recovery mode and restore your iphone.
Start iphone in dfu or recovery mode.
For that first connect your iphone to computer via usb cable install latest itunes on your computer. Now press and hold sleep wake button or( in iphone 7 press and hold on off button) for 3 to 5 second and volume button for 5 second. Now your iphone screen goes black and on your itunes you will get pop up message that itunes is detected
Jul 27, 2018 | Apple Cell Phones
Acer aspire 5520
try f8 at the logo screen then disable automatic restart on system failure from the menu to find out what the error is
Jul 15, 2017 | Computers & Internet
My dell (monitor) it turns on few secons but the image goes off,
First you'll have to power off the system.
Please power on the system and as soon as you see the Dell logo please tap the F2 button 3 - 4 times.
The computer will go to the system setup. Check if the screen goes blank here.
If the screen stays on then try this.
1. Please power off the system.
2. Please power on the system and as soon as you see the Dell logo please tap the F8 button 3 - 4 times. You'll reach the Windows Advanced Boot Options Menu on the screen.
3.Select Safe mode with Networking.
4. Select Administrator at the log in screen.
5. Warning dialog box with the message Windows is running in safe mode. appears. Click the Yes button.
6. The desktop appears with the words Safe Mode appearing in all four corners.
7. Uninstall the video drivers and restart the computer.
8. Resintall the video drivers.
Rate if useful.
Aug 19, 2009 | Dell 1703FPs 17" TFT LCD Flat Panel...
My screens works for about 10 or 15 minutes and then goes out...
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Aug 03, 2009 | HP Pavilion dv2715nr Notebook
Screen goes black when plugged in
The high pitch sound is most likely a faulty inverter. Most defective screen are caused by a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :- To determine if you have a LCD screen or video card problem, read this and follow the instructions. Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case. The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills. Check out www.lcdparts.net for parts, repair service and DIY info.
Jun 12, 2009 | Dell Inspiron E1505 Notebook
My Screen goes black fter a few minutes
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :- To determine if you have a LCD screen or video card problem, read this and follow the instructions. Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case. The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills. Check out www.lcdparts.net for parts, repair service and DIY info.
Jun 10, 2009 | IBM ThinkPad T42 Notebook
Laptop screen goes black, no backlite
You could have a defective screen - a defective inverter or a CCFL lamp.
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
May 08, 2009 | IBM ThinkPad T23 2647 Notebook
Toshiba satellite a135 monitor goes black
  • Picture flickering with dim display.
May 03, 2009 | Toshiba Satellite A135-S2386 Notebook
Dell inspiron 6400 display goes off < 1 min after switch on time
If you see a very dim image or black screen or flicking image on the LCD screen it means you have a backlight problem.
The buzzing sound is most likely the inverter problem.
Mar 26, 2009 | Dell Inspiron 6400 Notebook
When monitor power button is pressed, a small white image appears and alternates briefly between an alalog and digital icon in black then the screen goes blank, no color.
My issue is similar.. however after trying a couple of times it will work. (yes everything is plugged in) It will function for a good 10 minutes before just powering off (blackout) screen.
If you attempt to turn it on after it blacking out, the blue led for the power button will blink a couple of times and it will remain off.
However if you wait 5-10 minutes and turn it back on, it will repeat itself...
I have it hooked up to a radeon X1650 graphics controller as a secondary digital controller, and its hooked up by VGA cable.
I also have two other displays besides this one (one primary and extended that dont have any issues whatsoever.. they continue to function while the syncmaster 193p takes its time snoozing.... please help.
Mar 17, 2009 | Samsung SyncMaster 193P 19" LCD Monitor
Samsung SyncMaster 205BW LCD Monitor Logo
700 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
