Question about Sony LBT-XGR6 CD Shelf System
PROTECT PUSH POWER IT KEEP SAYING WHAT TO DO - Sony LBT-XGR6 CD Shelf System
  • 3 more comments
  • Anonymous Apr 20, 2008
    when push on apear "push power protect"
  • cheachea22 Jul 23, 2008
    my stereo keeps saying "Push Power Protect" and it freezes what can I do? It is a Sony LBT-LX50 Thank You
  • Anonymous Jul 31, 2008
    al iniciar el aparato todo esta bien, solo, que al tratar de realizar alguna oporacion de radio, cassette, compac disc, etc..., el aparato se bloquea con la leyenda de protect push power.
    que hacer??????????
  • Anonymous Aug 06, 2008
    protect push power what should i do
  • Anonymous Oct 04, 2008
    i have a sony dav-hdx500 and the push power protector keeps flasinh on the screen what do to
My Sony audio set keeps saying push power protect and the set freezes what should i do? Please help me solve this problem.
Posted on Sep 10, 2008
My stereo did the same thing, everytime i turned it on the screen would say "protect push power" 1.) first check and make sure that all the speaker input and outputs are properly connected, 2.) unplug and plug the system back in 3.) the top of the system needs adequate ventilation, so anything stacked on top of the machine must be removed and then blow into the top and it should work fine after a few tries. At least this was what the case was with mine, and I have a LBT-XRG6 it is 8 years old.
Posted on Oct 01, 2010
Fizzo,
If the audio power amplifier IC is Ok, you must check the resistor connected to it. Those resistors are usually low resistance value and it might be changed for a long time use.
I hope it could be helped for you.
Please email me for negative or positive result(gsanchezjr@yahoo.com)
Have a nice day!
Gil
Posted on May 05, 2008
Push power protect
Posted on Jul 23, 2008
  • 3 Answers
Check for fusible resistor around the ic amplifier maybe its open a value of 1 ohms
Posted on Feb 03, 2012
2 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: when its turn on it
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Posted on Jan 22, 2011
Why is my hifi saying push power protect
Probably some condition caused your system to enter protect mode. You are being prompted to push something, perhaps a circuit breaker, to restore normal operation.
May 19, 2016 | Audio Players & Recorders
My Sony home system keeps saying PUSH POWER PROTECT... (no speakers are hooked up,but did it when there where)
more than likely you have a Shorted Amplifier inside the unit which will require you send it into sony for repairs.
Feb 27, 2011 | Sony LBT-XG500 Shelf System
Polaroid a544 saying protected card why
The SD card has write protect switch on the side, push the switch tab towards the card end with the gold contacts. This will turn off the write protect.
Nov 27, 2010 | Polaroid A544 Digital Camera
Protect push power
audio amplifier IC fried need to be replaced
Jun 01, 2010 | Sony MHC-GX555 Mini Hi-Fi System Shelf...
"Protect" and "Push Power"
i have a sony component push power protect, i have already replace IC but still protect push power
May 02, 2009 | Sony Audio Players & Recorders
My Sony LBT- LX30 stereo is saying "PUSH POWER PROTECT" when I try to turn it on. What does this mean?
You probably have a blown amp ic or the output transistors. But disconnect the speakers and turn it on could be a bad speaker if it turns on.
Jan 12, 2009 | Audio Players & Recorders
Push protect problem/ sony MHC-VX33
push power protect is error signal shows problem in power amplifier board, mostly power amp out
IC STK402-100S found deceptive.
contact nearest Sony service center for proper repair.
Sep 29, 2008 | Sony MDS-JB940 Mini Disc Player
Sony LBT-XGR6 CD Shelf System Logo
2,405 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
