Question about Intel Motherboard
New build with a msi 890gxm mother board, AMD Phenom II, and 4 meg of ddr3 crucial memory on two sticks. It will not boot up to the bios screen not will it boot thru my hard drive. I have removed all peripherals including hard drive but no boot to screen. When I go back to my old computer the hard drives boot correctly.
    Master:
    Sergeant:
  • 383 Answers
Reset the bios, until the defect is resolved by msi
Posted on Jul 15, 2010
Custom computer build, foxconn motherboard, computer wont start
Not trying to be condesending but start simple and work your way up.
1. strip dow board to;
a. known good older processor
b. known good single memory stick
c. known good power supply
Test
move memory one slot over
Test
Move memory over one slot
test
move memory to last slot
test
You have tested the variables if still not working you have a bad mother board.
contact foxconn for replacement.
Feb 28, 2012 | AMD Computers & Internet
I want to know the graphic card slot in the motherboard ASUS M2N68-AM-SE2. Whether it supports DRR1, DDR2 OR DDR3.
Hi, you can see the list here:
http://www.asus.com/Motherboards/AMD_AM2Plus/M2N68AM/#specifications
At this site you also find drivers.
Remember to select your operating system
AMD Socket AM2+ / AM2 Processors
for AMD Phenom™ FX / Phenom / Athlon™ / Sempron™
AMD Cool 'n' Quiet™ Technology
AMD64 architecture enables simultaneous 32-bit and 64-bit computing
Support 45nm Phenom™ II CPU Chipset NVIDIA Geforce 7025/nForce 630a
System Bus 2000/1600 MT/s Memory 2 x240-pin DIMM, Max. 4 GB, DDR2 1066/800/667/533 ECC,Non-ECC,Un-buffered Memory
Dual Channel memory architecture
*DDR2 1066 is supported by AM2+ CPU only Expansion Slots 1 x PCIe x16
1 x PCIe x1
2 x PCI
Storage Southbridge
4 xSATA 3 Gb/s ports Support RAID 0,1,5,10,JBOD
ATAPI support ,AHCI mode
LAN RTL8211CL Phy Gigabit LAN Audio ALC662 High Definition Audio 6 -Channel CODEC
USB 10 USB 2.0 ports (4 on back I/O, 6 on board)
1 x PCIe x1
2 x PCI
Storage Southbridge
1 x PCIe x1
2 x PCI
Storage Southbridge
1 x PCI-E x16 Graphic card slot.
Aug 25, 2011 | ASUS M2N68-AM SE2 Motherboard
Id like to buy a msi nf725gtm-p31 mobo but am unsure if it supports am2 processors and ddr2 can u pls advice thanks
Here are the specs of the motherboard, both answers to your questions are "Yes". Happy purchase and have fun with it !
CPU
• Support socket AM2 for AMD® Athlon 64/Athlon 64X2 CPU / AM2+ for AMD® Phenom CPU / AM3 for AMD® Phenom II / Athlon II CPU . (95W only)
Please refer to CPU Support for compatible CPU; the above description is for reference only.
bult_ar_org.gifHyper Transport Bus
• HyperTransport 1.0 supporting speed up to 1000MT/s
bult_ar_org.gifChipset
NVIDIA® nForce 630a & GeForce 7025 chipset
bult_ar_org.gifMain Memory
• Supports Dual Channel DDR2 667/800
- 2 DDR2 DIMMs (240pin / 1.8V)
- Supports a maximum memory size up to 8GB.
bult_ar_org.gifSlots
• One PCI Express 1.0 x16 slot.
• One PCI Express 1.0 x1 slot.
• Two PCI slots (support 3.3v/5v PCI bus interface).
bult_ar_org.gifOn-Board IDE
• One IDE port by NVIDIA® nForce 630a & GeForce 7025 chipset
- Supports Ultra DMA 66/100/133 mode
- Supports PIO, Bus Master operation mode
- Can connect up to two IDE devices
bult_ar_org.gifOn-Board SATA
• Two SATA II ports by NVIDIA® nForce 630a & GeForce 7025 chipset
- Supports storage and data transfers at up to 3Gb/s
bult_ar_org.gifRAID Function
- SATA II 1~2 supports RAID 0, 1 mode by NVIDIA® nForce 630a & GeForce 7025 chipset
May 12, 2011 | Computers & Internet
I CANNOT LOAD WIN7 I cannot get my system to boot from a CD disk (Win 7 Ultimate) I set the BIOS to boot from a CD device - the priority is set for CD first. All other values are default. In...
try to reset bios if does't work try using a usb dvd drive (external dvd drive) remember you do not will be able to read a dvd CD(WINDOWS 7 CD) using a cd burner.
you will need a dvd drive.
Feb 07, 2011 | ASUS Computers & Internet
What motherboard will replace a msi k7t turbo2?
This is an obsolete part; as such, you will have a hard time finding it at any retailer, whether brick and mortar or online. However, all hope is not lost-try E-bay
http://computers.shop.ebay.com/i.html?_nkw=socket+a&_sacat=1244&_trksid=m270&_dmpt=Motherboards&_odkw=&_osacat=1244
You will have to look for a board that supports S-Dram memory, because that is what your MSI K7T Turbo2 uses.
My advice would be to skip this entirely; I would replace the whole board/CPU setup, and pick up some memory. You can get an Athlon II quad core and mobo for $165.98 USD (Asus /AMD). Pick up 2 GB of Kingston DDR3 RAM for $56
http://www.newegg.com/Product/Product.aspx?Item=N82E16820134790
and you essentially have a whole new system for $222
Just my opinion on this-I don't think that spending the amount of cash you would have to in order to replace an obsolete board is worth it.
You might try this, instead:
AMD Athlon II x2 Regor (2.8 Ghz, dual core) @ 56.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103688
ASRock M3A770DE AM3 AMD 770 ATX AMD mobo @ 59.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148305
Total $174.97 + shipping USD
Given you 3 ways to go and my advice-good luck!!
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157176
Crucial 2 GB Ballistix 240 pin DDR3 1600 Memory for $57.99
Feb 03, 2010 | MSI K7T Turbo2 Motherboard
I bought a MSi 790gx-g65 mobo and an AMD Phenom II x4 940 which is am2+. Everything I've heard about this mobo is that it's am2+ and am3 capable, will the Phenom II am2+ I just bought work in this mobo?
Yes it will, but you'll need to update the bios to the latest one in order to be sure the processor is recognized. The 790 chipset will make that board an excellent performer with the Phenom 940. Give it as much dual channel ram as you can afford, up to the max of 4 gig for a 32 bit O/S or 64 gig for a 64 bit system.
Nov 10, 2009 | MSI AM3 790GX-G65 Motherboard for AM3/AM2+...
I havea GA-MA790X-UD4P AMD 790X; GbE; PhnII;DDR2 1333+; ATI FireX
It will support DDR2, of 1066 (backward compatible) and up to 16GB. If you put in two sticks, be sure they match in speed to get the best performance. It's also dual channel, so matching size will also be a good thing.
Mar 14, 2009 | Intel Motherboard
Intel Motherboard Logo
134 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
