My Frigidaire front load washer does not come on when I pull the know out. The "door lock" light comes on and it makes a sound but nothing happens. I can advance it to the end and it will spin a bit in the gentle cycle. Is it worth it to have someone come out and look at it? It is 7 yrs old.
  • 5,081 Answers
Yes the door lock maight faulty and just need to replace that and get going...It is worth to get it fixed....
Posted on Jul 15, 2010
There are four lights on front of the washer we replaced the door lock and the sensing light is on. water goes into the machine but nothing else happens. we also cleaned out the pump what do you t
I appreciate your inquiry, terri buttafuoco!
Based off the information you have provided you have replaced the door lock on your Frigidaire washer and it is still not operating properly. It sounds like a possible problem with your control panel or wiring harness. I would recommend reaching out to a professional for proper diagnosis and repair to avoid any unnecessary part purchases. I hope this is helpful. -Matt
Oct 25, 2014 | Frigidaire ATF6000ES Front Load Washer
MY FRIGIDAIRE FRONT LOAD WASHER WONT FILL WITH WATER OR SPIN . HAVE TRIED CLEANING THE DOOR LOCK & UNPLUGGING IT FOR EXTENDED PERIODS OF TIME.
Sounds like the fill water solenoid has bust, they are cheap to replace and fairly easy. make sure you disconnect from power supply and water supply before trying.
Jan 30, 2014 | Frigidaire GLTF2940ES Front Load Washer
FRIGIDAIRE FRONT LOAD WASHER WON'T START. DOOR LOCK WILL NOT LOCK. DOOR LOCK LIGHT IS OFF. PULL START HANDLE OUT/ NOTHING. HEAR CLICKING WHEN TURNING SELECTOR SWITCH/BUT WILL NOT LOCK DOOR OR TURN LIGHT ON...
Good Morning REDS, thank you for your inquiry!
I understand that your door indicates it is open and your washer will not operate. Try resetting the unit by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn on the washer. Select a normal cycle, confirmed the latched is securely latched and verify if the washer will start. If the washer will not operate then it possibly have a faulty door lock assembly or a communication problem with the control board. At this point, it would be advisable to contact an experienced appliance repair tech to assist further.
Sep 11, 2013 | Frigidaire ATF6000ES Front Load Washer
I have a Frigidaire (ATF6000ES) Front Load Washer all lights come on and wont work.
Sounds like either the control board is faulty or the door latch sensor is not allowing the control board to communicate to the rest of the unit.
Aug 23, 2012 | Frigidaire ATF6000ES Front Load Washer
Door lock light is on door is not locked and
Make sure you are allowing the washer to completely finish its cycle before opening the door. It is normal for the door to lock at the end of a cycle. The locking mechanism keeps owners from opening the door before all of the water has been drained. If the door on the washer is locked, select the "Drain" or "Spin" options on the front-load washer. This will completely drain the water from the system and unlock the door, allowing you to open it.
Thank you !!
Jun 19, 2010 | Frigidaire GLTF1040A Front Load Washer
I have a Figidaire Affinity front load washer. The problem that I am having is I close the door select wash and then push start and dr is on the screen. Can you tell me what is happening?
dr means the door switch is not closed. Thus meaning the door lock assembly is bad and needs to be replaced.part number is 131763245 and price is $48.99
Nov 01, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Affinity Door Lock
under 1st yr warr, sure if thats he issue they would cover, it, a clogged drain pump may cause the same problem though , not being able to drain water , the pump would just hum.
Dec 03, 2008 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire LTF2940ES Hums
Sounds like the belt may be off. Was it moved with the shipping braces out? It may have caused some internar damage. You might check to see if the hum is coming from the door lock area. If the lock is out it won't let drain or spin.
May 16, 2008 | Frigidaire GLTF2940ES Front Load Washer
Washer filled with water then stopped
Same problem- quick fix- to release door anyway. Found the service manual online...First unplug power cord and remove bottom front panel. Reach underneath on the right side of the machine- there will be a white round plastic disk that you can pull downward to release the door lock and remove your wet clothes. I found a pen lodged inside which may have caused the 'glitch'. When I ran it again it did the same thing and locked at the same place. The service guy had to replace the door lock mechanism to permanently fix the problem.
Apr 16, 2008 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire Front Load Door Lock Broken and Noisy FWT449GF
Its looks like a lid switch issue. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Good luck!
Sep 08, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
