Question about Minolta EP4000/5000 CS/PRO Copier
The copies come out solid gray pages
The pages are gray all over, and I can dimly see what I am trying to copy in the background. We recently moved the copier.
  • monaromine Jul 15, 2010
    I haven't tried it yet, but it sounds like what might have happened in the move
  • 942 Answers
Try to turn off your copier and reseat the toner which is inside of your copier. You may refer to the manual how to remove the toner. There is a big possiblity that the toner is the main problem in this issue. The mere fact that there are gray display all over your pages, the toner does not respond well. If you know how to remove and reinsert back the toner, that would be great. Then make sure the paper is on the edge of the opening tray to be able to lift the paper and print it perfectly. That is sometimes caused by paper jams unless there is a problem mechanically with the rollers of your copier. If all else fails, pls refer to Minolta for immediate repair..
Posted on Jul 15, 2010
Background on all white pages copies are gray
check printer settings or document settings back ground color settings
you can print a page color to any of the color bar settings so there is a setting that has been change to grey that is causing the problem
Dec 11, 2015 | Epson Stylus NX400 InkJet Printer
B&w/gray Scanning Is Okay But Color Scanning Problem
Run ink head cleaner routine. If you cannot the list make and model of printer. Thanks.
Dec 25, 2014 | Office Equipment & Supplies
Hello, I would like my pictures to have a white background. When I take the picture on a white background the background ends up looking gray. I am taking pictures of baby clothing and I want the clothing...
Exposure meters are designed on the premise that the scene is an average, middle gray, in brightness. If you take a picture of a white dog playing in the snow, the camera will try to make the picture come out middle gray (a gray dog playing in gray snow). If you take a picture of a black cat sitting on black asphalt, the camera will try to make the picture come out middle gray (a gray cat sitting on gray ground).
If the white background is dominating the scene, the camera will reduce exposure to try to make the entire scene come out middle gray. The solution is to meter on something else. Move in close and fill the frame with the subject, press the AE-LOCK button, then move back, compose the picture, and take the shot. For full details, refer to the "Shooting with the exposure locked --- AE-LOCK" section in the manual (page 52 in my copy).
If you're taking a lot of pictures, you might want to switch to Manual mode and set the exposure accordingly.
Dec 29, 2010 | Sony Cyber-Shot DSC-F717 Digital Camera
Want a B&W copy from colored sheet of paper w/o dark background.
It's never going to be perfect (unless the background is quite light in colour), because the copier basically "sees" the coloured background as "gray", and the darker the background the more "gray" it looks. Try setting the original type to "photo" mode, and then adjusting the exposure a little lighter/darker....that's all you can basically do.
Mar 25, 2009 | Canon imageRUNNER C5180 Color Copier
Each succeeding copy gets darker and darker
When was the drum replace? Recently? Could it be time again?
Was it a remanufactured unit?
Regardless of all that, It sounds to me like the drum is failing.
Feb 27, 2009 | Brother MFC 4800 All-In-One Laser Printer
Copies have gray background.
Have you had the optics cleaned resently? If not Iwould start with that and make sure you have the copier unpluged and don't forget to clean the two mirrors under the Black Box/cover. It could also,mean that you need a new OPC drum and blade.. It depends on how maiy copies are on the copier and drum...
Sep 04, 2008 | Toshiba 2060 Copier
Background copy gray
make a new layer. set ur desired foreground color and press ALT+BACKSPACE.
thank you!!!
May 27, 2008 | Adobe Photoshop Elements 2.0 for PC
Gray background, but copied text is visible
With toner being dropped I would take a close look at the cleaning unit next to the drum. Sometimes they become clogged or wear out. Inside the machine, can you see toner that has spilled or piled up? If so that is an indication of a faulty cleaning unit.
MM85
May 23, 2008 | Canon NP 7130 Black and White Copier
Gray backround
Does your scanner software give the option to choose different modes...grayscale, color, black & white?? This sounds like it's scanning in grayscale....if you can change it to black & white, the background should remain white.
Jan 24, 2008 | Epson Perfection 1670 Flatbed Scanner
51 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
