Question about Emerson Fans Emerson MW8115SS Microwave Oven
Emerson microwave trips the circuit breaker when we open or shut door MW8117W is the actual model#
MicrowaveSvc
  • 9047 Answers
SOURCE: No power
The door switches are designed to prevent the unit from running while the door is open. You probably have a blown fuse, and it's a white or dark grey ceramic fuse of 15A or 20A, available from local big box stores or appliance parts stores. The fuse is usually located on the floor of the chassis behind the control panel, or mounted in the same area as the door switches. Also, I'm really curious how the door switch got stuck while cleaning? That sounds scary...
Posted on Nov 13, 2006
  • 57 Answers
SOURCE: No Power Whirlpool MH7140XF
does it not light up at all? A microwave has a fuse on it. Probably accessible from the back panel. if not you would need to disassemble it. Most likely cause of this is slamming the door broke one of the safety switches the door has so the microwave knows when the door is open. And it shorted against something when it broke. It might have simply blew the fuse but then again you might have fried it.
Posted on Oct 01, 2007
SOURCE: microwave went bang and tripped
You probably blew the magnetron tube.
Posted on Jul 09, 2008
SOURCE: Whirlpool microwave Model # MH3185XP No power?
I just had a problem with mine and took the panel off and did find a fuse on the inside on the top portion of the unit. Try changing it and see if it works. Hope it helps.....
Posted on Jan 17, 2009
SOURCE: glass tray will not turn
try unplugging the micro and then plugging back on. It may need to recycle.
Posted on Aug 02, 2009
How can I stop my G9115SL microwave from tripping my circuit breaker?
I run into this problem when people are running their microwave off a 15amp line. Especially if it is sharing the line with another appliance like a refrigerator or large over head light or in my wife's case...the vacuum cleaner. Step one is to count the amps on the line. Step 2 is to replace the breaker. They do go bad but not often. Good luck.
Mar 27, 2015 | Emerson MWG9111SL Microwave Oven With...
Why does my Emerson MW8117W microwave turn on and start cooking when I OPEN the door?
The airbag module needs to be replace if the vehicle has not been in any kind of fender bender.
Aug 18, 2014 | Microwave Ovens
Emerson Microwave MW8115SS --
I would suggest you check the door switches inside the microwave oven just below the keypad, rectangular in shape. The switches are normally open or closed, set meter to ohms, unhook lead from one side and test with door open and closed. If readings are the same both ways the switch is defective. "check all switches"
Mar 19, 2012 | Emerson Fans Emerson MW8115SS Microwave...
We have a GE Profile microwave and every time we open the door it trips the breaker. We turn the breaker back on and use the microwave and as soon as the food is done cooking and we open the door - bam,...
For a breaker to trip, you have to have an over voltage condition that is usually referred to as a short. Since your unit works in the cook cycle and only trips the circuit breaker when you open the door the short has to be in the door latch switch or reset circuit. So it wouldn't be that hard to repair, but since it is 7 years old and not the most energy efficient unit, if you aren't able do the repair yourself, then I would replace it!
You can get an idea of how hard the repair would be by going to the searspartsdirect.com web site and putting in the model # off the ID TAG. Then look for the door latch assembly and that will give you an idea of the cost of the parts and get an idea of how hard it is to replace.
Aug 07, 2011 | Microwave Ovens
GE Spacemaker Microwave JVM1441 BH04 tripping circuit breaker
your power transformer for the magnetron could have a shorted primary power winding,the door safety interlock switch could be mis-adjusted,this normally blows the internal unit fuse,a shorted high voltage capacitor,or diode,a bare wire inside the unit,more than the microwave on that circuit or a weak circuit breaker in the house power panel
Jun 19, 2010 | GE JVM1441 Microwave Oven
Opening the door blows the fuse
more than likely you door safety switch has a short and every time you pull the door open the connections arc and trip the breaker or blows the fuse.
Aug 24, 2009 | GE JVM1190SY/WY/AY/BY Microwave Oven
Microwave turns on and counts down but won't heat up/cook
Ok just figured this out! It is a problem with the alignment on the lower door switch. I took the cabinet off and lifted up on the door switch slightly and voila! It works. You could probably fix this without taking it apart, just lift up on the door ever so slightly. I hope this works for you.
Jan 13, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Breaker tripping
Make sure it is plugged into a 20 amp circuit. If it is in a kitchen it should be a 20amp breaker if it trips a 20 amp breaker it needs to be replaced. If it is a new house and you plug it in in the kitchen and it trips a 15 amp breaker then the house does not meet code. ref Article 210.52(B)(1) NEC
Jan 18, 2008 | Emerson MW8107WA Microwave Oven
Tripping of circuit breaker
Check what other appliances are on your circuit. What goes off when the breaker is tripped. You may need to relocate the microwave to a different circuit. Try to stay away from the refrigerator or AC circuits.
Nov 03, 2007 | GE JVM1440 Microwave Oven
Emerson Fans Emerson MW8115SS Microwave Oven Logo
137 people viewed this question
Top Emerson Fans Microwave Ovens Experts
William Miller
William Miller
Owen Barnes
 Gary Gemmell
Gary Gemmell
Are you an Emerson Fans Microwave Oven Expert? Answer questions, earn points and help others
