Question about Home
Air jets don't work on whirlpool tub
Air jets don't work on mastercare whirlpool tub. All I get is a clicking noise when I depress the bathaire button.
brainyass
  • 242 Answers
SOURCE: How can I unclog plumbing in whirlpool tub used to clean dogs?
Depending on how mechanically inclined you are, take apart the tub and clean everything out. No easy task, I know, but who want old dog hair floating around? That will be your best bet.
Posted on Oct 24, 2008
  • 14 Answers
SOURCE: Not all jets working on Hydrosystem Whirlpool Tub
I believe the below web site can help you with your problem. The jets are more then likely just turned off.
I hope this helps.
sanray
http://www.hydrosystem.com/hydro4/options/components/
Posted on Dec 27, 2008
PartsCenter
  • 125 Answers
SOURCE: my whirlpool bath tub has three jets that work & 3 jets that are
The suction IS the water intake. it takes the water from the tub into the pump and the water comes back out through the jets.
Posted on Feb 24, 2009
PartsCenter
  • 125 Answers
SOURCE: kohler whirlpool will not shut off and sounds like about to blow
Sounds as if you may need a new switch to turn the tub on/off. You can find one on our site www.uspartscenter.com
Posted on Mar 04, 2009
snap101
  • 117 Answers
SOURCE: can you cap off the jets of a whirlpool tub if you
you can but it's not worth the trouble of doing it! lots of fiberglass and you need to have access to the whole tub on the sides
Posted on Jul 29, 2009
I have a jetted tub and it won't turn off. I have a single button in the back right corner and i don't know what to do!
Right now you are having to turn it on/off by using the circuit breaker or just unplugging the pump right?
Is this a button you depress or an electric button like you would find on a microwave?
If it is a button you depress to turn it on/off then the problem is most likely the air switch located in the motor under the skirt of the tub.
If it is an electric button then it may be the control box under the tub that needs to be replaced.
Rod
US Parts Center
888-521-6183
Feb 02, 2014 | American Standard Home
Jets not working
Check your breaker in the breaker box. Is this an air tub or a water tub?
Nov 10, 2013 | Neptune Home
Jets won't stay running
When you push the air button down it sends a column of air to the air switch located in the motor. When there is not enough air sent by the air button on the top of the tub it will not make the air switch "latch" in the closed position and means you need a new air button.
In your case the air button is sending enough "air" however when the air switch is not "latching" in the closed position that means the air switch is bad and needs to be replaced.
Most air switch's can be replaced with a TBS-310
US Parts Center
Apr 19, 2013 | Jacuzzi NOVA 5 WHIRLPOOL WITH INTEGRAL...
We have a Kohler Purist Air Bubble Massage tub... the last couple days the dial has randomly started lighting up with the green light tracking down the middle and you can hear the motor or the jets on the...
This is sounding like a relay not working on the circuit board inside the control box. You will want to have a Kohler service center send someone out to have it checked. You most likely need a new control box.
Aug 14, 2011 | Kohler K-1110-AH-0 Purist whirlpool with...
New whirlpool bath installed pump working no air coming through jets
I would guess there could be one of two problems. First, open the access pannel so you have acces to the motor and air tubes. From your actuator that turns on the jets, there should be a small tube (probably clear) that goes from the actuator to the motor. this tube controls the jets, make sure it is connected, finding the small nipple that this tube connects to on the motor can be difficult and they are often not connected when you buy the tub or come loose during instalation. If that is OK, check to make sure the Air Inlet pipe is not blocked. there should be one (maybe 2 but usually 1) of the large tubes that circle the tub undernieth that is open on one end. It is probably the tube that is the highest off the ground. this should not be connected to anything, it almostt appears that the water would rush out if you don't connect it to something, but that is where the air comes in for the bubbles. good Luck
May 07, 2011 | Home
I have a Royal Whirlpool bathtub. After I fill the tub with water, I push the button for the jets to start and the jets only work while i am pushing the button. The button is a air button. Feels like I am...
You have a bad neumatic switch. Or a small hole in the air line. Try pushing the button fast and hard to see if it will stay on. if so , it is a hole in the tube. if not it is your neumatic switch
Mar 23, 2011 | Home
Water coming out of adjustable air vent behind wall of tub
one or more of the jets are turned off. i would suspect someone is plugging the jets off which causes water to go backwards in the system and the water goes out the air controls. solution: check the jets to make sure the jet faces are turned on and/or tell someone to quit plugging off the jets when they are in the tub.
Mar 03, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Whirlpool tub, jets come on and won't shut off. No water in tub.
Is it a jetted tub, or a air bath tub with holes or jets in the floor? If it has holes or jets in the floor, the control box is bad and needs replaced. If it is a jetted tub, there may be a water level sensor, if so the sensor may be bad causing the tub to turn on.
Jun 13, 2009 | Whirlpool 5"x36" White Bathroom Drop-in ...
Power switch for whirlpool tub
the easiest thing (maybe) is to install an air switch kit on the side of your tub. Here is a link to the part. Basically you install an air button on the side of the tub, install the air tubing from the nipple on the underside of the air button to the nipple on the box that plugs into an outlet under the tub. The pump plugs into that same box and the air tubing from the air button pushing onto the nipple on the box. When you push the button on the tub it will turn the pump on/off. Air Switch Kit
Jan 17, 2009 | Whirlpool 5"x36" White Bathroom Drop-in ...
Sep 28, 2008 | Home
Home Logo
48 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
