Question about Craftsman YT 4000 42" Briggs Stratton 24 hp Gas Powered Riding Lawn Tractor
My craftsman riding tractor keeps blowing the fuse under the hood. sometimes it cuts for five minutes, sometimes it cuts for hours. i have no clue and suggestions would be appreciated.
I would try tracing the entire wiring to see if any are exposed and are touching metal.
Posted on Jul 15, 2010
Fuses keep blowing
Are all five fuses you replaced operate the same thing and if yes, what is it the fuse is issued for?
Jun 10, 2013 | Briggs & Stratton Garden
Craftsman garden tractor Mod # 917.257740 blows main fuse.
Try checking the battery - make sure it is not under rated - over rated and be sure the starter it's self isn't drawing too much amperage.
the battery may need replacing and for a temp fix - put in a larger fuse - say 50 amp.
Thanks for choosing FIX Ya
Gary @ Fix Ya
Jul 06, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Tractor keeps blowing a fuse
Check for a wire that has a bare spot on it rubbing the body of this mower. The vibration the engine makes shakes the wiring so it must have a bare spot somewhere under the seat or towards the engine
May 30, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have an 18hp 42inch cut Sears Craftsman, it will
You might want to checked your fuel line coming from the tank,sometime it will collaspe inside the line and not allow enough gas to get to the engine.
May 15, 2010 | Garden
Have a Craftsman , with 25 HP Kohler engine & 50in. deck. Just stoped running whlie mowiing. Now won't start, Sounds like battery dead. Checked seat safty switch by jumping eires, did'nt solve problem
My Briggs and Stratton did the same. Look under the hood along the wiring harness for a 20 amp automotive type plug in fuse. Mine was blown, but fuses blow for a reason. One of my headlight connections came loose and shorted to ground. If yours has that fuse look for a short.
Apr 16, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Snapper yard cruiser 33in. cut joystick blows
Unplug the engagement clutch[it bolts to the motors crank] and try to engage again.If the fuse does'nt blow you need a clutch.If it does still blow you need a switch or you have a short in the harness.
Nov 03, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
46" craftsman lawn tractor shuts off when engaging
check the wire from your clutch to were it plugs in. should be on your right side. some have a yellow cover. make sure the wire is not broken. check under your deck and make sure you don't have a large grass build up
Oct 13, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Fuse keeps blowing
check thwe stater up under the flywheel, sometimes they get dirt and grass up there and mess with the copper coil. also i had one one time that the stator had a bad wire one time and was blowing fuses also. all i did waS cut that part of the wire out and fix problem. good luck
Jun 21, 2009 | Garden
KEEPS BLOWING FUSE ON CRAFTMAN 19.5 BRIGGS, WHEN TURN KEY TO START
In my experience, and i have a good bit, when you turn the key and it always blows the fuse, the magnets under the flywheel are in direct contact with the stator (alternator). Both will need to be replaced...sorry
Apr 23, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Blowing fuse
youve got a short in the wireing ,prob right at the clutch peddle switch
Mar 08, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman YT 4000 42" Briggs Stratton 24 hp Gas Powered Riding Lawn Tractor Logo
358 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
john h
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
